Question about Lenovo Computers & Internet
Wireless setup how to manually set up a wireless network on Lenovo Y510 for Vista home
  • 298 Answers
Chuan,
You can try these steps, Go to your control panel, then go to network and sharing center, On the left handside, under Tasks click on manage wireless networks. From here click the Add button and click on Manually create a profile, and from there you put all of the wireless settings needed.
Posted on Jun 29, 2008
Can not connect ipad to router
If your Linksys wireless router is already setup with a wireless network, do the following to connect the ipad to the network:
Tap the Settings icon on the home screen of the iPad. Go to General, then Wifi. Once in the wifi section, you should see available wireless networks. Choose the network that is setup on the Linksys and connect to it. Enter the password if you have one set on the wireless network and tap join.
If your linksys is not setup with a wireless network, consult the manual for it to configure it properly.
May 06, 2011 | Linksys Wireless-G WRT54G Router
Wireless radio on Lenovo Y510 turned off even though the slider switch is switched on and lights up. How can I turn on wireless radio?
Hi There and Welcome to Fixya!
Another way to turn on the wireless radio on your Lenovo Y510 is to press and hold the "Fn" key, then simultaneously press the "F5" key.
This is an alternative way to switch the wireless antenna on or off without using the physical WIFI switch.
Hope this helps,
Thank you for using FixYa.
Aug 21, 2010 | Lenovo IdeaPad Y510 Notebook
Download webcam drivers
Download Here
For complete and updated driver just follow the link
*Brand: Notebook
*Family: IdeaPad Y510
*Operating System: Your Operating System
*If the driver for Windows 7 is not available you can use the Windows Vista Driver. Just make sure to check the version of the OS for Win7 32bit download Windows Vista 32bit Driver for Win7 64bit use Windows Vista 64bit
*You can also use Option 3: Lenovo Smart Downloading
*After Installing the driver press F5 + FN to enable the wireless switch
Thanks for using Fixya
Jul 19, 2010 | Lenovo IdeaPad Y510 Notebook
Cannot turn on wireless radio on Lenovo Idealpad
Press FN+F5 button together on the keyboard to have the settings for display pops up on the screen. Check if the radio button was turned on both for wireless and bluetooth connection. If the radio button was off, just click ON and that should set the wifi to turned on. Always make sure that the wifi switch was set to on as well.
If this didn't fix the problem, kindly reinstall the wifi adapter driver by downloading the driver from the manufacturer's website. after reinstallation kindly reboot the computer.
Please leave comments if you have any other questions.
Cheers~
Jun 19, 2010 | Lenovo IdeaPad Y510 Notebook
Print server for vista, D-link DI-704p
I can recomend to your network setup is WPS54GU2
Wireless-G PrintServer for USB 2.0
******************************** Before configuring the wireless settings of the printserver, make sure to know the following settings on your D-link router: SSID, and wireless security.
Configuring the Wireless Settings on the Printserver
The wireless settings of the printserver can be configured using its web-based utility. Make sure the printserver is set to a static IP on the network.
NOTE: Make sure the printserver is already working when hardwired to the Dlink router before attempting to use it wirelessly on your network.
Step 1:
Access the printserver’s web-based setup page. Open a web-browser such as Internet Explorer.
NOTE: If you're using Mac, use Safari to access the printserver's web-based setup page.
Step 2:
Go to the address bar and enter the IP address you've assigned to the PrintServer.
NOTE: To assign the PrintServer a static IP address, click here.
Step 3:
When the printserver setup page appears, click Wireless.
Aug 01, 2009 | D-Link DI-704P Router
I have wireless network but computer shows no network found. All the drivers are ok and updated. laptop model y510 ideapad ----44q
first you have check the configuration in your device and check the Input value if your input value and service provider input value doesn't mach than you have to correct it
Jul 06, 2009 | Lenovo IdeaPad Y510 Core-2 Duo: Y510...
How to install the hardware drivers and set the wiresless internet access in lenovo y330 series
Broadcom Wireless Driver (Windows Vista)
http://consumersupport.lenovo.com/en/DriversDownloads/drivers_show_661.html
Broadcom Wireless Driver (Windows XP)
http://consumersupport.lenovo.com/en/DriversDownloads/drivers_show_326.html
Intel Wireless Driver (Windows Vista)
http://consumersupport.lenovo.com/en/DriversDownloads/drivers_show_310.html
Intel Wireless Driver (Windows XP)
http://consumersupport.lenovo.com/en/DriversDownloads/drivers_show_1263.html
Just download them and run the setup file to install the drivers :)
If you found this helpful , please rate my solution below
Kind Regards
1234s282
Jul 02, 2009 | Lenovo 3000 N100 CoreDT2080 VB PC Notebook
Laptop cannot find wireless signal
theres a possibility that you need to manually create a network inside the Y410 itself,you can ask for assistance from your ISP
Jan 19, 2009 | Network Associates Symbol Wireless...
Setting up wireless network
moz-screenshot.jpgDear Friend,
The diagram for setting up a small and simple network setup diagram.
Feb 05, 2008 | Lenovo (41N3008) 802.11a/g/b Wireless...
Try to setup home wireless network to share two home computer
Connect the home wireless network router box to the main PC through an ethernet cable with the PC powered off and the home wireless router powered off, then power on the PC & the router. Vista should locate the new wireless network and follow the windows vista network setup procedures. After the wireless network has been detected you then while the second PC's power is shut off you connect dongle adapter to the PC power on and XP will locate the new adapter. You will probably have to enter your networks pin for the connection.
Get back to me when you complete these steps.
Try next time contacting me through an online chat session. We can resolve the issue quicker while chatting together.
Nov 20, 2007 | Hawking Hi-Gain Wireless 802.11g/b...
Computers & Internet Logo
292 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
