Question about Sony Ericsson Walkman W810i Cellular Phone
W810i not charging
I plug in the charger not sign of charging is as if the phone dont recognise the charger is in,i put my tounge on the charger and current is in it,so wats the problem
  • hizzalol Oct 03, 2008
    i have a w810i and every time i put my phone in charge it says "charing problem please disconnect the charger" Why ??? what is the problem with my phone ???
Basicly there are 3 pins on the top of your phone (take the battry out and you shall see them on the far end) get a pair of tweezers and push the clips in and hold for a while ... slot your battrey back in and put it in charge it should work :)
Posted on Oct 03, 2008
My W810i stopped charging after it fell in the toilet lol.
Thats right, it fell in the toilet. BUT, I took a deep breath, took it right out, pulled out the battery, sim card and then dried it off using a hair dryer (cold air) for about a good hour, all different locations (opened up the phone, took out screws etc).
It worked, but the phone wouldn't charge. THAT is when I thought S&#*, the phone finally is going to go. BUT then I came across this post. I simply looked at the pins on the phone where the charging connector hooks on. Cleaned the two locations where the charger makes contact with the phone and guess what. Everything is flawless. Thanks for posting the above, and hopefully my post will help others as well.
vicster80 at hotmail dot com
Posted on Sep 04, 2008
I have 2 W810i and that happened to one of my chargers - couldn't fix it just had to use the other charger! :( maybe it's a common fault with the chargers that they just stop working, or maybe it's the connectors on either the phone or the charger that need cleaning if current is still getting through.
Posted on Jul 01, 2008
My W810i Phone charging sometimes stops suddenly while charging , tried master reset,its not affected ,please advise Thanks vish
Please check that your charging terminal is free from any fungus type material.Due to excess use carbon builds up on the terminal. Use any old toothbrush to clean it. If this is not the problem then change your charger.
Sep 15, 2011 | Sony Ericsson Walkman W810i Cellular Phone
Phone wont turn on. Red light on top when plugged into charger
the battery is completely dead, try to charge with some external charger. if still same then software corrupted need to reflash the phone.
Mar 15, 2011 | Sony Ericsson Walkman W810i Cellular Phone
My sony ericsson w810i phone is not charging through charger but is charging with data cable. The charging jack has been recently replaced. What is the solution for this?
sony ericsson phones have their own two-prong charger/data plug. You will need to purchase another AC charger, or you can purchase a plug that has a female USB and use that. Good luck!
Nov 06, 2010 | Sony Ericsson Walkman W810i Cellular Phone
The phone won't charge
check bettery by touching it with tounge after removing from phone if it is charge it if give u little current otherwise ur battery is damaged and if battery works then charger is damaged in some cases charging ports were damaged
Mar 18, 2010 | Samsung SCH-u740 Cellular Phone
Chager port not proper work
You cna take the phone and have the charging port service and clean
Sep 08, 2008 | Sony Ericsson Walkman W810i Cellular Phone
I miss my sony walkman
i think it is the time to change your charger ,because the problem seems to be only with your charger,so try by changing the charger
Aug 05, 2008 | Sony Ericsson Walkman W810i Cellular Phone
My handphone W810i
You need to have the charger port on the phone service or chekck to see if it needs replacing.
Jul 12, 2008 | Sony Ericsson Walkman W810i Cellular Phone
My fone
it wont charge may be bcoz there is some problem in charger or there is a problem in battery..
this may also happens if you are not using the charger which is specified for that cell...
try changing battery first from any of your friend s cell ..
if problem persists then change the charger and try ..
if the same problem persists then the charging IC is gone i think so just take your cell to technician .......
Feb 14, 2008 | Sony Ericsson Walkman W810i Cellular Phone
W810i doesnt turn on or connect via usb
Charge the phone until it has finished charging, The first thing to do is to make sure that the phone is charged. Attach the charger and charge the phone for about 2.5 hours. Please note that the battery icon may not appear until after the phone has charged for 30 minutes. When the battery icon has stopped “flashing” the phone is fully charged.
Jan 17, 2008 | Sony Ericsson Walkman W810i Cellular Phone
Sony Ericsson Walkman W810i Cellular Phone Logo
593 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
