Need drivers for disk FireLite - Computers & Internet
    Genius:
  • 1,011 Answers
Dear Sir/Madam,
Click this link for drivers......
http://www.opendrivers.com/categorycompany/1375/1660/storage-smartdisk-free-driver-download.html
Thanks
Good Luck
"Don't forget to rate the Solution"
Posted on Jun 28, 2008
Wanto erase all data from firelite backup drive
You could try data rewriting software to erase your data, like AOMEI Partition Assistant Erase hard drive feature: http://www.extend-partition.com/help/wipe-data.html first you need to connect this disk on your computer and then download the free version of Partition Assistant to use.
Sep 25, 2012 | FireLite (USBFLB80) Hard Drive
Reconfigure firelite for PC
you will need to reformat the drive. it sounds like it was just formatted for MAC only.
to do this open computer management and select disk management under storage. select the firelite drive and click format. please note these are settings for windows 7.
Feb 13, 2012 | SmartDisk FireLite 40 GB Hard Drive
Im trying to access my firelite external hard drive (model USBFLB80) that has been sitting around unused for a while. I have a new computer, which is a mac, now and only used it with a windows pc before. I...
Hi
A USBFLB80 is not a hard disk controller, it's an external USB hard drive and does not require any driver when used in Windows ME/2000/XP. This device is plug and play in Windows XP providing you have a working usb port to plug it into.
May 29, 2011 | FireLite (USBFLB80) Hard Drive
Hey there not sure if both usbs on this dual cable are to be plugged into my PC. The drive keeps flashing a blue light but my computer is not recognising it.
In most case's only one USB needs to be connected, but you need to load the driver for it from the disks which you would have received for it.
Hope this helps.
Thanks
Jason
Oct 14, 2010 | Verbatim 160GB USB FireLite: The "drive...
I have a firelite smartdisk portable hard drive usbflb40. I need th driver for it. Where can I down load it. Thanks
http://drivers.softpedia.com/get/Other-DRIVERS-TOOLS/Others/SmartDisk-FireLite-Driver.shtml
there you go!
Feb 25, 2010 | FireLite (USBFLB80) Hard Drive
When I plug in the usb connection for my smartdisk firelite 30 gb, it is not being recognized by my pc
I am sure tha that you have verified that the FireLite has power and the USB connectors are secure both at the Firelite end and the computer end.
If all that is in good order, then you can follow these instructions.
When you plug in your drive you need to do the following to see if the drive is connecting to the computer.
Right Click on "My Computer"
You will get a menu, chose "Manage"
You will then get a Computer Management window.
On the left side of the window will be a menu.
Under the Storage section, chose "Disk Management"
This will open in the right side of the window and will show you your main hard disk, CD-Rom disks and any other disks connected to your computer.
If you see your Firelite hard drive, then it is connected. The drive may need to be formatted. This window should tell you if that is the case. If you see the firelight and it shows that the disk is unformatted, you can right click over the large section on the lower left window which is located to the right of the smaller area that describes the disk. You will get another menu that will allow you to formate the disk. You can also assign or change the drive letter assigned to the Firelight using that same right click menu.
I hope that you have found these directions helpful. Please contact me if you need clarification on any of the instructions I have written here. If the Firelite is not visible on this Manage Computer Window, then you may have a defect with your Firelite Drive.
Please let me know if I can assist you further.
Thank You,
Brian
Jan 28, 2010 | FireLite (USBFLB80) Hard Drive
Firelite 30gig
Click on the link, or copy past the link, open the page scroll down and you will find Free Driver Download SmartDisk FireLite USB Driver Windows 98SE
this will work for win98 as well as 98SE (second edition) too.
http://www.opendrivers.com/driver/226844/smartdisk-firelite-usb-driver-windows-98se-free-download.html
Please let me know if it worked will be appreciated.
Regards
Moses
Jan 17, 2008 | FireLite (USBFLB80) Hard Drive
Firelite wont mount on my computer
look at its format, (NTFS) or (FAT32)? and check the DRIVER for the hdd to see if it has any complications or errors, this is easyest fixed by deleting the HDD driver in Device managment and then restarting the computer. good luck.
Oct 09, 2007 | FireLite (USBFLB80) Hard Drive
My computer stopped detecting my hard drive
Hi, Based on your post/description: 1. Tried on 3 different computers - no go, so it's not a PC problem; 2. Tried replacing the cable - no go, so it's not an interface problem; 3. That leaves you only with the Firelite itself. An external hardrive would consist of 2 main parts, the electronic board and the hard disk itself. The board seldom (if ever) fails. Its function is to provide conversion/interface from the SATA/IDE connectors of the HD to the out USB/Firewire. The HD more often than not fails. Most external storage uses a standard HD inside the enclosure. Your possible options: a. Claim warranty/replacement; b. Replace the HD only; c. Physically remove the HD and connect it direct to a desktop either as IDE or SATA and run manufacturer's diagnostic and/or third party recovery software; d. Seek services of professional data recovery firms (if data/files are mission critical); Hope this be of some help/idea. Post back should you need further information. Good luck and kind regards.
Sep 03, 2007 | SmartDisk FireLite 40 GB Hard Drive
Computers & Internet Logo
77 people viewed this question
David Payne
David Payne
