Question about Panasonic KX-T7730 Corded Phone
One touch dialling
HELP! I was trying to set up one touch dialling and have ended up setting the phone so when I press line 2 it automatically rings another ext within the office. How do I cancel this? I have read the manual and it only shows how to set up and not to clear one touch dialling!
  • office968 Jul 24, 2008
    Yes I have the same problem.
  • 30 Answers
To return to it original settings, press prog button then press the button that you want to change, press 0 and enter its original button assignment
Posted on Jul 25, 2008
When following the instructions for progamming one touch dialling, the result end with a message saying 'not valid' when trying to use the number - can anyone help?
Press Program Press the button to store Press 2 then your outside line access code (usually 9) Then dial in the number to dial Press Store
Oct 03, 2013 | Panasonic KX-T7730 Corded Phone
I set the One-Touch Dialling to CO. Please teach me how to cancel this setting.
The only buttons you can set to CO are the left side buttons with lights, so assuming that, press PROGRAM the button dial 2 STORE. That clears the button. Now, just in case you lost the sequence of buttons for outside lines, from the bottom press the left side buttons and read them. If they're not in 1234 sequence, dial 0x STORE to restore the CO line that belongs there.
Carl
Jul 01, 2011 | Panasonic KX-T7730 Corded Phone
How do I reprogram the phone to ring when a new call comes in, default to a certain line, and show caller id when a call comes in.
The answer to the Caller ID question:
Depend on the type of system that the phone is connected to. Late model Partner ACS equipment will display Caller ID info between the first and second rings, provided that the telephone line is plugged into a module that supports Caller ID.
The answers for the other 2 questions are taken directly out of the Partner ACS Programming Guide which is available for free download at Avaya's website.
Ther answer to the incoming call line ringing question:
Again, depends on the system. For the Partner ACS:
1) Press FEATURE 00 at extension 10 or 11.
2) Enter the number of the extension to be programmed for Line Ringing.
The green lights next to the line or pool buttons show the current Line Ringing settings for all
lines or pools assigned to the extension. (If a line or pool is not assigned to a button, the green
light next to that button is off.) The following ringing options can be shown by the green light
next to the line or pool button:
? Immediate Ring - on steady
? Delayed Ring - flashes slowly
? No Ring - flutters quickly
3) Press the line or pool button until the button light shows the correct setting (the setting for the
currently selected line or pool also appears on the display).
4) Continue programming, or exit programming mode.
Line selection:
For incoming calls, the line selection (hunt sequence) is set by the local service provider). For outgoing calls....again....it depends on the system. For the Partner ACS:
1) Press FEAURE 00, SYSTEM PROG, SYSTEM PROG, CENTRAL PROG at extension 10 or 11.
2) Enter the number of the extension to be programmed for Automatic Line Selection.
3) Press **.
4) Press the line, pool, or INTERCOM buttons in the desired order. The valid entries for Automatic
Line Selection
depend upon the type of extension:
? Key Extension: Outside system lines, Left Intercom (the factory setting)
? Pooled Extension: Pool 880 button 1, button 2, Left Intercom, Right Intercom (the factory
setting), Pools 881-883, individual lines
For each button pressed, a display similar to the following appears:
5) To exit Automatic Line Selection, press **.
6) Press CENTRAL PROG and enter a new extension number, or exit programming mode.
Changing line ringing and line selection are tasks that are normally reserved for the Administrator of the telephone system.
Jan 06, 2011 | Lucent 18D Corded Phone
How do you save numbers for one touch dialling?
Press PROG the button and dial 2 + 9 + the number and STORE.
If your outside line access code is something different, insert it instead of "9".
carl
May 20, 2009 | Panasonic KX-T7630 Corded Phone
I have a hp 2200 all-in-one printer. For some
if it sends ok, then it has probably been switched to "manual receive" form "automatic mode"
Apr 21, 2009 | Office Equipment & Supplies
I have a dect 225 phone and lost the manual. How can I change the phone settings so that I can change to touch tones instead of the old fashioned dialling sound?
1. Press the MENU key.
2. Select SETTINGS and press the OK key.
3. Select DIALMODE and press the OK key. The current setting is displayed.
4. Select TONE or PULSE.
5. Press the OK key to confirm.
Nov 16, 2008 | Lands Phones
Fax pick up
Greetings Nana,
I believe that you can specify how many rings should occur before your Kodak 5500 Ai Printer automatically answers an incoming call (default = 4).
If you have a dedicated fax line, set the Rings to Answer to 1 or 2.  If you have a shared line for voice/modem and fax, set the Rings to answer to 3, 4, or 5. This setting only applies if Answering Machine Mode is set to OFF.
When the Answering Machine mode is disabled, Rings to Answer applies and your AiO printer answers the call. When your AiO printer detects a fax tone, it receives the fax. When a voice call is received (no fax tone), the call is ignored.
1 Press Menu to display the main menu. 2 Press scroll down until Fax Settings is displayed. 3 Press OK to display the Adjust Fax Settings menu. 4 Press scroll down until Rings to Answer is selected. 5 Press right or left arrow to change the number of rings.
Give it a try, Nana, but let Kodak know if you need additional help. They will be there for you.
Ron Baird the friendly Kodak guy
Sep 28, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Receiver dosen't pick up line that is ringing
go to programming section 5
You want Automatic Line Selection
Press feature00
left intercom button press twice (system program)
press right intercom once (central tel program)
enter # of extension to be programmed (intercom #)
press **
press line buttons in desired order line1 line 2 etc and
end with left intercom then press**
enter feature 00 to exit programming
Dave
Aug 26, 2008 | Avaya Corded Phone avaparp18d
STORE NO FOR ONE TOUCH DIALLING
press prog. button then press the one touch button, press 2 then 9 or 0 (depending in your line access no.) enter the contact no. then press store button.
Jun 26, 2008 | Panasonic KX-T7730 Corded Phone
Panasonic KX-T7730 Corded Phone Logo
178 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
