Question about Dryers
Kenmore Dryer My dryer shuts off in the middle of a cycle. You have to turn the timer all the way around to restart. This happens every 5 to 10 minutes. I have replaced the control board and the heat sensor. Could the timer itself be causing the problem?
  • tesmgb74 May 02, 2009
    Kenmore dryer shuts off after 10-15 minutes. Replaced Thermister and thermal shutoff, coils are heating, Any suggestions?
  • tesmgb74 May 11, 2010
    How can you test the timer to determine if it is the problem
  • 481 Answers
Yes it does sound like the timer itself. sometimes if the timer has a bad contact then the timer will loose power as it goes around. by turning the timer around 1 time it resets the contact and it starts up again.
Posted on Jun 28, 2008
Kenmore Series 80 electric dryer will turn itself back on after shutting off. I believe I can hear the timer continue to run after it shuts off.
if the timer pointer continues to travel around on to the next cycle all by itself after it has reached the end of a cycle you definitely have a problem with the timer. now however if it does that "and" starts to run on its own you also have a bad push to start switch as well.
good luck, have fun.
Aug 03, 2010 | Kenmore Dryers
Gas Dryer stopped
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Jun 16, 2010 | Kenmore 74972 Gas Dryer
My kenmore electric clothes dryer model #110.86984110 shuts down in the middle of a cycle. After a while I can restart it and will run for a little while longer.
when was the last time you cleaned out the dryer,could have a blocked vent line,blocked blower wheel duct where the filter slides into and vac out the inside of dryer,go outside and make sure the air is blowing the flapper fully open,might have to blow the line out with a leaf blower,if the heat can't escape the dryer over heats and shuts down, could have a bad timer,thermostat, or you also could have a bad motor that would also heat up and shut down if it's bad, but try the clean out first and go from there,good luck
Dec 05, 2009 | Kenmore 64902 Electric Dryer
The dryer was running then in the middle of the cycle it stopped. Cleaned the vent and tried to restart it and nothing? Please help me????
most of the time when that happens it's from a weak motor,it overheats and shuts down till it cools off then will start again,how old is the dryer?mike
Apr 19, 2009 | Kenmore Dryers
Kenmore 68702 electric dryer heat doesnt shut off
If the dryer completes the cycle bit does not shut off, then you have to replace the timer control assembly.
If instead the dryer hangs at the middle of the cycle and does not advance, check the thermostate.
If the dryer does not heath and does not advance, then check the heating element, the thermostat and the fan.
Mar 06, 2009 | Kenmore Dryers
Dryer only shuts off and restarts during cycle
Get a new timer. It is not that expensive and the wiring is fairly simple.
Jan 14, 2009 | Dryers
Kenmore Elite Heavy Duty King Size Capacity Quiet Pack II Dryer shuts off
If the venting is clogged this will happen. And that is a good thing because it is a safety measure built in to prevent fires. There is a thermostat that can tell when your dryer is over-heating,(usually caused by clogged venting by lint) and this devise tells the heating element to turn off so as not to create a fire. Clean out venting, inspect thermostats and element, replace if neccesary. You may only have to clean out the venting.
Nov 27, 2007 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
121 people viewed this question
Top Dryers Experts
