Question about Canon Cameras
I have a Canon Rebel Xti and today I was shooting pictures with a new lens and I pressed the shutter and it did not release and it is stuck. I tried to turn off the camera but it still shows that it is on. Thanks for the help
    Champion:
  • 216 Answers
If the camera does the same without the lens mounted, it's probably a defective release switch. It'll have to be replaced by a repair shop for around $130.
Posted on Jun 29, 2008
My Rebel XTi has what seems to be a stuck shutter button? The shutter will fire w/o the lens on but will not fire once I put my 50mm back on. I recently did a sensor cleaning. Could that have something to...
Will it fire if you take the lens off AF and set it on M? If so then your release switch may be bad - I see a lot of that. Also there is a screw that comes loose that may be shorting out the auto-focus sensor flex connector. The bottom right screw on the back circuit board always comes loose/out on XT and XTi cameras.
Aug 01, 2013 | Canon EOS Digital Rebel XTI Digital Camera
How to release a stuck sutter on canon 400d
Wow, four days ago.
I would think that the camera has dropped the shutter by now.
There is a mode in the camera that holds the mirror up out of the way for sensor cleaning but this is defaulted as soon as the power is shut off and then turned back on again.
Or the camera was set in manual mode "Bulb" and is waiting for the next command from the photographer to "drop" the shutter "takes a second press of the shutter button.
The lens may be loose (unlocked) and giving a bad command to the camera.
The Canon 40D has a shutter capable of 60,000 actuation so if you are close to this I'd say the shutter has been shot out of it.
Also sometimes the shutter release button sticks and gives the feeling or appearance of a stuck shutter.
Shutter switch also known as a release button have been an issue sometimes where dirt and oil from a person hands get down into the button.
To release shut the camera off, take the battery out, remove and reinstall the lens, shift the taking mode to "P" program or full automatic green box.
Apr 29, 2011 | Canon EOS 400D / Rebel XTi Digital Camera
My Canon Rebel XTi seems to randomly take shots and more often not. Any idea what could be causing this?
If the camera appears to be working properly in some pictures and not others I'm going to suggest you look at your Shooting Modes. It's very possible that the mode dial has been turned to the TV mode which is Shutter Priority. With the Rebel having a shutter speed of 30 seconds to 1/4000 you may click the shutter to take a pictures and the camera appear not to take the picture. A few seconds later the shutter closes and the mirror drops. This also can happen if you are in the Night Portrait mode. The length of time my be longer if the lens cap is immediately placed on the lens.
Change your mode to "P" program until you become more familiar with the camera functions and settings
Dec 10, 2010 | Canon Rebel XT / EOS 350D Digital Camera
While taking photos today during a football game, after about 20 shots, my camera continued what seemed to be regular picture taking, but when I checked the shots in playback mode, the screen is blank! Any...
the shutter most be out or the mirror most be out of timing. if the shutter is bad then it will cost around 180 but try this first turn on the camera take the lens off and hold the mirror with your finger up and press the release switch it should click twice then put on the lens and shoot hopefully it will fix it if it didn't its the shutter
Sep 21, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Dark pictures using flash
You could try increasing the exposure level (press AV+/- while rotating the selector wheel to the right) but this will increase the time the shutter is open and increase the possibility of picture blur. Only other thing to do when shooting indoors is to change to a high ISO - 1600 for instance. This reduces the time the shutter is open so working together with the first suggestion you may not notice any difference!
If still too dark, you need a faster lens - you can pickup a 50mm f/1.8 lens quite cheap - this is an excellent indoor lens as the low F number means it lets in lots of light. The fixed focal length means you will have to move around to frame the shot, but they are indispensible for indoor work and a lot cheaper than a f2.8 zoom.
Feb 07, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
Take picture 3/4 of frame is black
Take the lens off the camera and look through the lens. Is there anything obstructing the light?
Now have a look inside the camera body. Same thing, anything there that looks like it shouldn't be? If look up into the cavity you should be able to see the focussing scren clearly - any obstructions there?
Finally, with the lens off, switch on the camera and go through the menu until you find the sensor cleaning option. Select this. The internal shutter will open and allow you to see the CCD sensor. Have a look and make sure it is also free from obstruction.
You will need to switch the camera off to release the shutter.
Put everything back together and check the pictures again.
If still no joy, then it sounds like the CCD sensor is faulty and the camera needs a repair from an authorised Canon repair centre.
Jan 14, 2009 | Canon EOS 400D / Rebel XTi Digital Camera...
I have a canon rebel xti. Some of my images are soft...not too soft, but a little. If I upgraded to canon 40 D slr, would my pictures be sharper, like around someones eyes, assuming I keep the lens,...
I have a Rebel XTi and take professional images. It could be that your lens isn't as sharp as it should be or your sharpness settings in the camera are set low.
Sep 22, 2008 | Canon Cameras
Canon E0S 400D locks up
is it still in warranty? send it back to cannon, there is a problem with this model doing that.
Mar 17, 2008 | Canon EOS 400D / Rebel XTi Digital Camera...
Cameras Logo
32 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
