Question about Epson Aculaser C1100 Printer
Fuser error E537
How do you correctly replace fuser, what about the lever settings thanks
  • Epson Master
  • 691 Answers
Get a service manual from HERE and follow the routine to remove/replace the fuser unit.
Posted on Jun 28, 2008
EPSON ACULASER C1100 When running a given Message Service Req Error E537 Please help me
E537 is the Fuser error check the latch lever of the fuser assy is set incorrectly
Oct 09, 2010 | Epson Aculaser C1100 Printer
Service req E537
E537 is a Fuser Unit error, it most likely requires replacing but first try a few simple checks. Lift the scanner unit upwards out of the way and open the top rear cover to expose the fuser unit. Check that it is seated properly and that both "latches" are in the locked position. Try unlocking them and removing/reseating the fuser (there is a small plastic hinged piece on the L/H side of the printer that needs lifting to allow removal). If all of this fails you will need to replace the fuser unit. A google search should turn up a stockist in your area as they are listed as consumable items.
Please take a moment to rate this solution. Thanks.
Mar 20, 2009 | Epson ACULASER CX11NF All-In-One Printer
Epson Aculaser C1100 E537
Hi there
This suggests a fuser error. This is the hot unit at the rear top of the machine.
Steps are as follows:-
1. Open COVER FUSER.
2. Draw out the COVER RH boss from the hole on COVER FUSER while pushing
COVER RH outward, and remove COVER FUSER.
After removal check coninuity across heater lamp amd thermistor terminals. If either shows anyhing more than 13 Ohms then you need to replace your fuser unit.
Anything more than that requires hands on technical expertise.
Good luck
ivorpits
Dec 20, 2008 | Epson Aculaser C1100 Printer
When turned on, displays a E537 error code. Solution?
error 537 is a failed fuser. You will need to replace it before you can use the unit. cost of a fuser is about $450 retail.
Gremlin11
Nov 12, 2008 | Epson ACULASER CX11NF All-In-One Printer
Photoconductor and error 537
Perhaps a copy of the parts diagram and/or the multi part service manual might be of more help.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 14, 2008 | Epson Aculaser C1100 Printer
Error 537
i think that is a memory related error: http://support.epson.ru/products/manuals/000836/alcx11_ug_en.pdf good luck:
Sep 30, 2007 | Epson Aculaser C1100 Printer
Epson C1100 Service Req Error E537
E537 is listed as FUSER FAIL: ? Control Thermistor detected a temperature exceeding the specified temperature. Safety Thermistor detected a temperature exceeding the specified temperature. ? The Control Thermistor did not detect a Ready even though the specified time elapsed from Main Lamp ON at Warm Up. ? The Main Lamp continues to stay lit even after time specified for the Main Lamp elapsed after the Control Thermistor detected a Ready. ? The Control Thermistor detected a temperature below the specified temperature even after the specified time elapsed from Main Lamp ON at Warm Up. ? The latch lever of FUSER ASSY is set incorrectly. You should replace the fuser unit. If the error remain after changing the fuser you need to take the machine for service as the error may relate to the power supply units.
Aug 25, 2007 | Epson Aculaser C1100 Printer
Epson Aculaser C1100 Printer Logo
413 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
