my friend
too faced same kind of problem ............ all the best.. click here to download
his ps3 get stuck and never turns normal soon
.....until its been restarted
if you are also facing exactly same problem
then dont worry
Go to this site and fix your problem by
downloading repair guide.........
Ok emergencie eject is turn on hold eject turn off the power in the back switch flip it back on while still holding the eject button THIS CAN DAMAGE THE DISK DRIVE AND MAY NOT WORK DEPENDING ON THE ERROR
SOURCE: ps3 jammed disc
Unfortunately their is no step by step or guaranteed method to fix this. Here are a few things you could try: turning it off and on, press/hold the eject button, resetting while holding the eject button, shaking or tapping it a little while trying to eject it, holding it different ways ex. face disc opening down towards floor while gently tapping and pressing the eject button. Essentially do whatever you can to get the disc to jar loose, >but whatever you do, don't for any reason stick anything in the slot or try to open the case <Doing this will void the warranty for sure! If none of these work your last resort would be to return it for a new one (providing you still have your receipt and it's less than a year old) or take it to a costly repair guy.
SOURCE: System wont load or eject any discs...
Remove the disc drive from the console. Remove the cover very carefull. Take the top part off (remove the 5 screws) and open the disc drive like a book.
Carefull remove the guide mechanism (the front part -1 screw).
The clicking noise is caused by the fact that the left side mechanism that raises and loweres the deck when the disk is inserted or ejected is stuck. Carefull push back the piece of plastic with teeth located on the left side of the deck (as you are looking at the disk drive the oposite side with the lens driving motor) until it clears complete the plastic round gear that drives that part.
mount back the guide mechanism, and the top part.
Attached the ribbon cables to the unit , power the console and keep the eject button pushed for about 10-15 seconds.
That will reset all the gears and stuff.
Worked for me when I experienced that issue.
SOURCE: disc wont eject and ps3
Hi, best thing to do to eject disk is
1.power of the console
2. hold the eject button and the power button down at the same time
3. then reach around to the back of the console and put the switich on
4. hold for ten seconds and thhe disk should come out
hope it helped!!!!!.
