Question about Sony Playstation 3 (PS3) Console
How do you access the fan? - Sony Playstation 3 (PS3) Console
    Master:
  • 497 Answers
Just a moment
Posted on Jun 28, 2008
My laptop keeps overheating. I have tried disabling a lot startup programs and deleting files. Can you please help me with this?
You didn't mention what make and model laptop you have but here is a general solution. Laptop overheating issues almost always involve fan blockage, or a bad (non-functional) fan. Some are easier to access than others. Look at your laptop and see if you have access from the bottom. You could possibly even access by removing the keyboard. IF you can access the fan you should clean out any lint or dust that is causing blockage of airflow (some dis-assembly may be required). KEEP IN MIND that if you remove the fan heatsink assembly you will need to re-apply thermal paste or compound to the area between the CPU and heatsink.
My guess is you will find that you have a strip of lint blocking the airflow between the exhaust of the fan and the heatsink fins.
Apr 28, 2011 | Computers & Internet
Er FF. Have replacement fan. How to access
Unplug the refrigerator from power. Remove the rear cover in the freezer. You may have to remove shelf brackets or the ice maker. Pull the rear cover forward and out of the way and disconnect the wire harness to the fan. Should be 2 screws holding the fan bracket in place. Remove these screws and pull the fan assembly out. You now have access to fan.
Feb 20, 2010 | LG LRSC-26922 Side by Side Refrigerator
Freezer works great fridge only cold intermittently
Check for proper operation of the fan located in the freezer compartment. The fan is located behind an access plate. You should be able to hear the fan if it's running. You can access it by removing the plate. The fan should be turning. If it's not turning, you will need to replace the fan motor.
Oct 17, 2009 | Refrigerators
ASUS M50SV fan cleaning
Usually if the fan and heatsink is not accessable from the bottom of the laptop behind a vent then the fan is accessed by removing the keyboard.
Aug 12, 2009 | ASUS NB | M50SV-A1 RTL PC Notebook
Can't Access stripped wires in ceiling fan after falling
You don't want to mess around with this and risk a fire. It would be best to replace this fan.
May 25, 2009 | Hampton Bay 24002 Ceiling Fan
Access to the circulation fan Kenmore upright freezer
There is a panel on the lower back wall inside the freezer.
Remove it to access the fan motor.
Mar 21, 2009 | Kenmore Freezers
How do I change the bulbs for this fan?
twist the glass on the bottom counter clockwise
Jan 11, 2009 | Hampton Bay 24002 Ceiling Fan
Oven fan zannusi zbf360x
Remove rear panel in back of oven, there you will see the fan,remove fan blade,usually left hand thread, and remove screws that hold fan, if they are not accessable from inside the oven then you will have to remove oven from housing, and remove rear outer panel to access fan screws and connections.
Remove fan and replace in reverse order.,don't forget the nut that holds the fan is a left hand thread.
Plz rate this solution.
Thanks.
Dec 14, 2008 | Zanussi ZBF360X Electric Single Oven
Fan error of IBM T30 Laptop
Hello Crazyswanz
In order to access the fan, 5 other areas of the laptop must be removed first. These are detailed in the "ThinkPad Computer Hardware Maintenance Manual" found in PDF format from the following link from IBMs website : ftp://ftp.software.ibm.com/pc/pccbbs/mobiles_pdf/92p1840.pdf
(If that link is broken, the manual can be found by first visiting this webpage on their site : http://www-307.ibm.com/pc/support/site.wss/document.do?sitestyle=lenovo&lndocid=MIGR-42308)
The instructions on how to access the fan are listed on page 81, however you best check whether this is covered, and would validate your warranty before accessing the inside of your laptop.
Hope this helps!
David
Nov 12, 2008 | IBM ThinkPad T30 2366 Notebook
AC blower fan
What has most likely happened is the blower fan stem is loose on the fan motor shaft. The hard part is getting access to the motor and fan. Usually it is under the dash on the passenger side. It is an easy fix once have access.
Jul 06, 2008 | 1994 Volvo 850
Sony Playstation 3 (PS3) Console Logo
13 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
