Question about Whirlpool GS6NBEXR Side by Side Refrigerator
Water in door
Please advise how to repair the water in the door. There is no water coming out.
  • Anonymous Jul 06, 2008
    water is not comiing out o o door
  • 481 Answers
The first thing i would check is the water line in the refrigerator side (it may be frozen). it is located behind the plastic pans in the bottom rear of the refrigerator. this water reservoir chills the water b4 it reaches the dispenser. if the refrigerator gets a little too cold then this small water line could freeze up and block the water flow.
another cause could be the water valve in the back of the refrigerator. it is actually a dual valve, 1 for the ice-maker and 1 for the water dispenser.
Posted on Jun 28, 2008
Heater is not working AC is fine Air is coming quite nicely, Heater is not working check with mechanic he says circulation of water is fine may be some electric issues, please advise
You have what is called a blend door that is inside of the air box that switches air flow between the heater core and the evaporator core. It sounds like either the actuator motor or the blend door itself might be either stuck or bad. Depending on what you are working on, this could either be a hard job, or a very hard job to repair.
May 23, 2016 | AC Cars & Trucks
I have a code error on my fisher & paykel front loader washing machine code C on can someone advise how to fix. cheers in advance
try leaning against the door when pressing the start button. door/lid switches have a habit of failing or getting out of adjustment
Sep 06, 2015 | Fisher Washing Machines
My mieleg575 ,please advise on why a gush of water comes out of the steam outlet once cycle finishes and door is opened fully
It is probably because of the solenoide is not working, so the steam is not getting out of the machine and condenses again in the door, and then when you´re opening the door all the water comes out of the door, you can check if all the moveable parts are still moveable if they are then it is the solenoide, replace solenoide and problem should be solved
Feb 01, 2015 | Miele Dishwashers
Lights come on, door is closed, light load, but door will not lock so machine can begin filling with water. LFT7000ESO MODEL.
Good Afternoon Friend,
I understand that that you are having trouble with your Frigidaire washer, model# LFT7000ES0, and the door will not lock and begin filling with water. The model number you have provided, comes up as an invalid number. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed successfully. If you do need more assistance, I will please ask for the model number of your washer. Typically you should be able to find this located inside your appliance around the edges where the door meets your washer. Hope this is helpful.
-Best Regards-
May 26, 2014 | Frigidaire ATF6000ES Front Load Washer
When I turn on the GE PotScrubber dishwasher with water, water is leaking out from disher please advise. According from one repair guy, it is related to pump issue please adivse
first try to look and see where the water is coming from,,,the bottom of the unit,,,,or the front of the unit...remember the door has a seal all the way around it and it has to seal correct and make sure the latch is all the way in lock postion
Feb 19, 2011 | Maytag Dishwasher
The water is not coming out of the spout in the GE smartwater plus refridgerator, the ice is dispensed. I can her the water being sucked into the filter, but it isn't coming out. Please advise.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Your water line could be frozen in the door. You can disconnect the line at the bottom before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does, leave the door open till it thaws.
Jan 02, 2010 | GE GSH25KGPWW / GSH25KGPBB / GSH25KGPCC...
Indesit idl 705
Hi greggyboy70,
I'm Harvey the master Plumber.
Your question is: you turn your dishwasher on, the heat comes on but no water comes through, can i please advise???
This may sound stupid but first make sure no one turned the water off to the d/w. If OK then you likely have a clogged or failed solanoid valve. The d/w must be removed for replacement. I don't recomend this for the average homeowner. You might consider utilizing our Repair Directory to find a repairman.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 14, 2008 | Indesit 24 in. IDL700 Built-In Dishwasher
Fisher and Paykel fridge buttom freezer with water dispenser
Please advise where the dispenser is leaking? If it is dripping out the front of the door, then I suggest you run the water dispenser to flush about 3 liters of water. Does the noise stop when you open the fridge door?
Jul 01, 2008 | Fisher and Paykel Active Smart® E522BR...
Water won't dispense from side by side fridge
check for water at bottom of door going in, if there water line in door or tank in door freezing. only fix to replace door. ck with dealer to get fixed under warranty
Jun 11, 2008 | Refrigerators
Whirlpool GS6NBEXR Side by Side Refrigerator Logo
65 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
