Question about Pioneer Audio Players & Recorders
Pioneer sx-205 gives a overload warning and cuts in and out when tuner or cd is playing
  • Anonymous May 09, 2009
    same
    President:
  • 624 Answers
Does it play normal on any sources, or do you only have the tuner and CD for available sources?
There are many different things that can cause this type of problem.
It could be bad solder connections on in the amplifier circuit or power supply, it could be a bad speaker or a bad output channel inside the receiver if this happens only when it gets turned up loud.
The overload warning happens when the amplifier circuit has excessive current or DC voltage on the outputs. Unfortunately the only way to determain if it is the speakers is to change them with other known good speakers and see if it still happens. But before buying any speakers you need to have the receiver ruled out as the source of the problem.
It can also go into overload if you have the wrong type of speakers connected, or too many speakers connected. Each speaker jack should only have one speaker connected toit. If you are using for example, 4 speakers connected to the "A" speaker jacks meant for just 2 speakers, it will create a load to the amplifier that the amplifier is not rated for.
Look on the back of the receiver and it will have listed the proper impeadance for your receiver. Most will say:
8 ohms or more "A" or "B" speakers
16 ohms "A" and "B" speakers
That means you must use 8 ohm or higher ohm rated speakers if you are using only speakers"A" or only speakers "B", but can not use 8 ohm speakers if you are using speakers "A" and "B" at the same time. Then they must be 16 ohm speakers.
Two 8 ohm speakers in one speaker jack is a 4 ohm load, that is why you can not use more than 1 speaker per speaker jack.
I hope you found this information useful, and if I can be more help just let me know.
Dave
Posted on Jun 28, 2008
My pioneer overloads and cuts out
this unit draws alot of power if you have too many things plugged in on the same circuit then it will shutdown and reset itself. unplug reciever and plug straight into the wall
Nov 13, 2011 | Pioneer SX-315
How can I control volume on my Pioneer SX-205 receiver from the couch?
There is a couple ways you can do this.
1.you can use the maufacture remote control, or if you dont have one you would need a universal.
2.If your receiver is hidden, or behind closed doors than you will need a radio frequency capable universal remote
Jan 07, 2011 | Pioneer SX-205 Receiver
Blown Fuse / SX - 205 / Pioneer reciever
Check the area where the fuse was...it's usually marked on the board or next to the fuse holder. Check the size also, 2 types 5x20mm or 1/4x1 1/4 in. Usually slow blow.
Mar 30, 2010 | Pioneer SX-205 Receiver
Pioneer Receiver SX-205 flashing ''overload''? Nothing in owner's manual troubleshooting chart.
usually it is a technical indication of the output being shorted. disconnect all speaker wires and try again. still blinking?
Mar 06, 2010 | Pioneer SX-205 Receiver
It gives an overload message regardless of what l have turned on
Check that the speaker wires are securely connected to the binding posts, and if you are using bare strand wire on them that there are no loose strands that can touch the chassis or other terminals or other wires.
Also check that your speakers are of a compatible Ohm rating for the unit. If you have any equalizer, tone controls or "bass boost" effects enabled, turn those off. They all require more amplifier power, thus possible overload can result.
Feb 08, 2010 | Pioneer SX-205 Receiver
My Pioneer Receiver (SX-255R) won't play anything. I only have a CD player connected to it. The screen only says "Muting." I've tried unplugging it for 30 minutes and re-connecting. Still says...
Just to be sure we are talking the same unit I have included the link to the user manual for SX-255R
http://www.pioneernz.co.nz/Site/Pronto/Files/user_manuals/SX255R%20USER%20MANUAL.PDF
Suggestions
1. have you tried to press the Muting button on the remote unit.
(item 11 remote unit diagram)? does it make any diffrence - what if the button is stuck?
2. Have you tried to play the Tuner radio - what happens then? do you still get Muting.
3. You mentioned something about speaker wire coming out.
I understand that Pioneer receivers shut off if any of the speakers is faulty, ie, correct impedance is not showing at the speaker input point.
Usually the newer units give an "overload" message. It is possible this could be happening and the SX-255R gives the "muting" message instead. Some people have reported very minute shorts where strands of the speaker wire touch the body and it causes "overload".
One way to check is to remove speakers wires one by one and see if the "muting" goes away. Then you can check the offending speaker if that is what is happening.
Good luck
Please do drop a comment to say how you progressed.
Dec 26, 2009 | Pioneer SX-255R Receiver
Overload
Have you checked your wiring connections? Wires could possibly be touching each other making it short out and giving you that "Overload". If not that then I would say it could possibly be a fuse that has gone bad inside. ??? Just some suggestions. The reason I say that it could be the wiring is because when I hook up a system and the wires accidently touch each other it overloads the system past a certain volume. Again I would check my wires first and move on from there.
Dan Colton, Ca
Sep 24, 2008 | Pioneer SX-205 Receiver
755 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
