Question about Sony Playstation 3 (PS3) Console
Nonresponsive ps3 I turn on the console and I get a green light on the front and one little blip of the hard drive light and about one or two seconds where it seems like everything is running, then it all goes quiet. If I put a dvd or a game in the drive, the blue light turns on, but that's it. I have no audio or visual, which is not a problem with the cables as I have also tested it with my cables which I know work. Any ideas?...I'm stumped.
  • GTRacer Aug 04, 2008
    Same here - I get the green light/HDD flash/hard lock every so often but I also get normal powerups and then a random freeze requiring a power-down. It will freeze on the XMB, in a PS3 title, a video, or PS2 title.
    Yes, my Blu-Ray drive will accept and eject a disc even when it's acting up. I think the BD has its own controller board so it doesn't depend on the main unit to run the mechanism.
    Every once in awhile, video freezes but everything else continues. For example, in FFXI I can type commands and hear the results but the screen won't update.
    I initially thought it was overheating, since it only happened after some time powered on. I cleaned the system thoroughly but now it locks up sooner, sometimes. It has even locked up on the first powerup of the day.
    It has *NEVER* done what overheating is supposed to do - flash the red light and power down automatically. And the system is in open air with all vents clear.
    None of this happened until shortly after I updated to 2.41 FW (never did get 2.40). I managed to keep it alive long enough to get 2.42 also but there's really no difference. I have not modded this system nor tried any kind of software/FW based exploit. Totally stock, latest FW.
    System is a launch-month 60GB with about 2,000 hours of use.
  • plambey Aug 04, 2008
    GTRACER i have the exact same problem as you, and its only started since i updated to version 2.42 i think..........your problem been resolved yet?
    Problem Solver:
  • 32 Answers
Your tv sucks get a new one
Posted on Jun 29, 2008
My playstation turns on and the green light comes on but it turns to flashing red in about three seconds. It never comes up on the screen
It could be a failing hard drive...Try to remove the hard drive from the system and restart it without the hard drive if you can at least get to the main menu then it is your hard drive that is causing the problem.
Feb 27, 2011 | Sony Playstation 3 (PS3) Console
My ps3 turned off during a game, when you try and turn it on the light on the power switch goes green for about 3 seconds then switches off again and has a red flashing light
Your PS3's problems are actually being caused by a connection error between the hard drive and motherboard. Without a correctly working hard drive connection your PS3 is unable to function and goes into shutdown mode, with the flashing red light warning.
So in order to fix the blinking red light on your PS3 you will need to repair the connection between the HDD and the motherboard.There is actually a rather simple way that you can do this yourself; while your PS3 console is switched off, locate the hard drive enclosure on the end of your console. Remove the plastic cover plate, then using a screwdriver unscrew the hard drive itself from its socket. Carefully remove it completely, then put it back in again. Tighten the holding screw, then restart your PS3
Feb 03, 2011 | Sony Playstation 3 (PS3) Console
I was playing a game and then the power was cut off and than when the power was back on i wanted to turn on the playstation 3 and it went on but the light was blinking only green... is it my hard disk,...
No, a blinking green light has nothing to do with your hard disk. I have encountered a few similair problems with my own PS3 and one thing has always solved those problems. hold down the power button on the front of your console for about 8-10 seconds, this will automatically reboot your device and restore it to the factory settings. remember, the green light is your friend, its the Yellow light you need to be cautious of.
Aug 20, 2010 | Sony Playstation 3 (PS3) Console
My ps3 80GB counsel is not turning on. i turned i***. n it won't turn back on. All i get is a green light for like a second. Than yellow light.. After that.. It just keeps flashing red. Tried to take hard...
I had the same problem with my PS3
it ended up being the Red Light Of Death witch can be a problem with the soldering on the motherboard of the console what you have to do is go to a repair shop that specializes in reflowing the motherboard of your console.
i hope that i could help!
Jul 17, 2010 | Sony Playstation 3 (PS3) Console
When i turn on my ps3 the light on the front goes green white red
Send it in for service at a Sony playstation service center.
It is possible you have a hard drive problem, but you will basically need to buy a hard drive and install it to find out.
Apr 21, 2010 | Sony Playstation 3 (PS3) Console
Cannot start. hard disk not found
try the following:
1.Unplug it, then just try to use it again. Also you can reset the PS3 to default settings by holding in the touch sensitive power button for around 10 seconds untill it beeps.
2.Take a screwdriver and unscrew the blue screw and then pull out the hard drive. (Don't unscrew the other screws, just the Blue one).
To pull out the hard drive you need to take the little metal handle and pull it to the right, then pull it out towards you.
After you take out the hard drive, just put it back into the PS3.
To put the hard drive back into the PS3, use the little metal handle on the front of the hard drive and push it to the left while the hard drive is inside the PS3.
Apr 20, 2010 | Sony Playstation 3 (PS3) Console
My PS3 turns on and then turns off 3 seconds later. my PS3 will not stay on for longer than 3 seconds.
I need to know what the lights on the front do. Do they flash? Before it shuts off do you see a yellow light? Green light?
Oct 24, 2009 | Sony Playstation 3 (PS3) Console
The light on the ps3 gose green yellow and the flashs red
the yellow light in the front of the ps3 means that it is accessing the hard drive in the ps3 the green light means thst it is connecting/trying to connect to a wireless /wired internet connection
Sep 13, 2009 | Sony Playstation 3 (PS3) Console
Hi got a mk1 ps3 i can turn it on but with in
Jul 15, 2009 | Sony Playstation 3 (PS3) Console
No response...
Have you tried resetting the defaults?
Have the machine in standby mode (red light), then press and hold the power button 10-15 seconds after it turns on and let go after you hear a second beep. The screen will flash a few times then it will be reset to standard TV settings. If that doesn't work then it's very probable that the video chip has blown or come unsoldered. I hope this helps. Complete directions can be found at under support. Good luck to you.
Jul 03, 2008 | Sony PlayStation® 3 (60 GB) Console
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
