Question about Akai Televison & Video
The tv will power up but no picture I can here the fan on on the power light is green indicating i have power what can i do to fix this problem
  • sylviajfelde Jun 28, 2008
    the model # is
    PDP5016H
  • Akai Master
  • 8,617 Answers
Please post the model number and I may be able to help you. Please respond to this same post so I will have acces to your symptoms when you post the model number of your set.
Posted on Jun 28, 2008
  • Sonny Berry
    Sonny Berry Jun 28, 2008
    Do the on screen displays function? Is so it is most likely the Main Video PCB. If the on screen display doesnt work it can be either the control PCB or the Z-sustainer PCB. I would highly recomend getting the service manual from the following link, they will email it to you and they will help you diagnose which board it actuall is and they will have the parts available as well. Here is the link and they provide free tech support to all their customers .
    http://servicemanuals.vstore.ca/
No sound and no picture
The green indicator merely lets you know that power is getting to your TV. The absence of picture and sound could be due to power supply failure
May 18, 2013 | LG Televison & Video
Turn tv on. green light solid display, no picture or sound
The flashing green light is likely indicative of a self-test failure, indicating the TV has detected some sort of internal fault. With no picture or sound, one strong suspect is the power supply. Flat-panel TV's have an internal DC power supply that converts the inbound AC current, and when these fail, or are unable to supply a minimum level of power to the set, it can behave as you describe, providing only enough power for the green light to illuminate.
Jul 28, 2012 | LG 50PG60UD 50 in. HD-Ready Plasma TV
My Misubishi WD-52631 DLP TV is off sudenly. I turn it on again, but no picture, no sound, nothing happened. I reset it, nothing happends. the green power light blinks for a while, then shut off itself....
Tv LED "LAMP" light indication is blinking?And ur tv projection lamp inside ur tv been used like 1 1/2 or 2 years.Yes.The tv projection lamp require changing,tv projection lamp life are ended.
Apr 19, 2011 | Mitsubishi WD-52631 52" Projection HDTV
Powers on but no picture or sound
i need a screen off a 47inch magnavox if u coudent fix urs and ur interested in selling me ur screen let me know
(47mf437b/37) noe28cervantes@yahoo.com
Jan 04, 2010 | Toymax Magnavox 47MF437B 47 in. LCD TV
Toshiba 51H94 wont power. The light blinks green 3 times/sec
This problem was resolved by doing the following: turned power off to circuit; unplugged tv; removed back "grate" and vacuumed out dust; vacumed fan on right back side; spun fan manually a bit; jiggled fan connection near power cord; plugged back in and it worked. I suppose there was a loose fan connection, and the TV wouldn't power on without a functioning fan.
Aug 03, 2009 | Toshiba Televison & Video
Vizio P50HDM No Picture/No Sound
this is most likely the sustainer board(s) problem. Replacing the sustainer boards should correct this problem for you. you can get the parts at vancebaldwin.com
May 29, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
replace the sustainer boards should correct this problem. New sustainer boards may cause red and green pixilation. If this happen, replace control board and TV is as good as new.
Apr 05, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
No Picture - Lamp Indicator Blinking
This may be the main power supply, or the lamp supply. This is providing that the new lamp is okay.
The service tech will swap out the modules to service the set.
Jerry G.
May 15, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Televison & Video Logo
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
