My Harmon Kardon AVR 144 had sound via all the connection but now it will only play the radio and none of the settings were changed. I tried checking for shorts in all the speaker wires and power supplys, but nothing. Do you have any solutions?
    President:
  • 624 Answers
Since it does work with the tuner, your speakers and speaker wires can not be a problem.
Since you have also checked all the settings, it is not that either.
What this does sound like to me, and I have been repairing A/V receivers for over 17 years, is a problem on the input board with a switching IC. These units have electronic switching not mechanical. It is stuck in the tuner mode and there is nothing that can be done by the end user to fix this except to reset the unit. Unplug it from the A/C output and let it sit for at least 4 to 6 hours. Even longer if you are not in a hurry. That way if the problem is just a software glitch in the microprocessor it will return it to the factory preset condition.
If this does not help you the only way to get it working properly would be to have it serviced by a professional. You would need a multimeter, O-scope and soldering iron to check it yourself. If you have those tools and know how to use them I can guide you thru troubleshooting it. if not just take it in.
If I can be any further help just let me know.
Dave
Posted on Jun 28, 2008
Harman kardon avr 1500
Try using the RCA outputs once and see if that works..One other thing don't use the phono input on the receiver as it could damage the amplifier
Feb 16, 2018 | Audio Players & Recorders
Trying to connect samsung smart tv to harmon kardon avr 330 with toslink cable, but i'm not gettting any sound through the receiver to speakers
The inputs may be assignable on the Harman Kardon. Make sure you have selected the proper analog or digital input type for the cable you are using. For more information, or should you have further questions, please visit my website at audioserviceclinic.com. You may contact me directly through the website. Thank you.
Dec 14, 2013 | Harmon Kardon Harman Kardon Avr 330 5.1...
Harman/Kardon AVR 3650 3D A/V Receiver
Make sure TV's HDMI port is working if it is working check it with a new HDMI cable changing the HDMI cable will fix the problem
Dec 15, 2017 | Harmon Kardon Harman/Kardon AVR 3650 3D...
My Harmon Kardon AVR 430 will not play sound and displays "unlock" when optical is selected
Try resetting the system. While unit is in standby mode press and hold the tone button on the receiver untill the unit turn on. This should reset the system to brand new out of box condition.
Mar 20, 2013 | Audio Players & Recorders
Distortion with HK AVR 144
This sounds like the amplifer is playing up. If the distortion is on more than one channel, you are looking at a faulty part common to both channels. If on one channel only, perhaps something in the pre-amp or power amp sections. Have a look inside, you might find a burnt resistor, which would cause it.
Dec 21, 2009 | Audio Players & Recorders
Problems with setting up Harmon Kardon AVR 146????
in what display i need to put reciver when i use the optical digetal
Oct 19, 2009 | Audio Players & Recorders
Harmon kardon 745 displays "unlock" no sound for tv or movies
I also had this UNLOCK message on my Harman Cardon AVR 130.
The reason for this error was - in a hurry I've plugged the optical input into optical OUT! Double check that your connections in the back are correct and hopefully it fixes your problem.
Cheers,
Sergey
Jan 11, 2009 | Harman Kardon AVR 130 Receiver
Humming noise
Usually Humming noises come from frequency interferance.  In this case it is being caused by your input sources.  A smiply solution is to replace the cables and or seperate the source cables away from any electircal cords or sources.
Jan 07, 2009 | Harman Kardon AVR 225 Receiver
Cannot get dts from my Harmon Kardon AVR 300 via my Blue Ray
I'm not sure if this solution is still necessary however:
I own a H/K AVR300 and have a PS3 hooked up via HDMI to the TV and Optical TOSLink to the receiver. I have no troubles selecting between DD 5.1 and DTS 5.1. I can even select trueHD whatever format but I can't detect an audible difference, I think that mode might be downgraded back to regular DD5.1...
Hope this helps...
Mar 23, 2008 | Harman Kardon AVR 300 Receiver
Avr 35 volume control
Are you using the two small silver touch + and - controls that are set close to the bottom of one sound stick? They are very discrete and easily missed. (I did at first.)
Nov 29, 2007 | Harman Kardon Harmon Kardon SoundStick II...
105 people viewed this question
 Grubhead
Grubhead
