Question about Jenn-Air 36 in. CCGP2720P Gas Cooktop
Broken griddle control
The griddle control was broken and anytime I plug the unit in it blows the breaker and sparks at the griddle switch. I have left it unplugged and light the burners with a lighter.
Doe anyone know the part number of the item to replace (griddle switch) and the directions to replace?
  • goade-k Feb 02, 2009
    I have the same problem with my jen air gas cook top. In the instructions that you were sent (which I have a copy of also) I can not see where it shows how to get into the control panel and replace the actual control knob.
  • creativedata May 04, 2009
    I have the same problem, but I can not figure out how to get the front panel off the cooktop. The instruction manual doesn't seem to cover that. Perhaps I am missing something?
    Thanks Brent
  • 59 Answers
Hello
It sounds like you have a short. Replace the switch is very simple. Here are the Owners Manual and the Instalation Instructions.
  • Owners Manuals (1)
  • CCGP2720P.pdf (942.48 KB)
  • Posted on Jul 26, 2008
    The indicator light for the stovetop remains on despite all the knobs for each element in the off position. One of the elements is still getting power and heating slightly despite all controls in the
    Hello friend, thanks for your post!
    I see that the indicator for your cooktop continues to remain on for your Frigidaire range. It sounds like it could be a potential issue with your switches or control panel. I would recommend a reset on your range which you can do by flipping the household circuit breaker off for ten minutes. I hope this is helpful. -Matt
    Oct 11, 2014 | Frigidaire Gas & Electric Stove/Oven/Range...
    Meat does not brown in gas oven
    Hello - Try resetting the unit by either unplugging it or flipping the household circuit breaker off. Wait approximately two minutes and turn the range back on. Select a normal bake cycle and if issue continues then the unit may possibly have either a faulty element, bad communication error with the main control board, oven sensor, or mechanical thermostat. I strongly suggest contacting a professional to move forward accurately. They also usually warranty their labor just in case something else may turn out to be the root cause of your initial problem and it does work out better to your advantage.
    Oct 28, 2012 | Frigidaire Gas & Electric Stove/Oven/Range...
    The male plug on the griddle is broken.
    They are not that hard to replace and you can easily buy the part online...
    Here is a tip about how to buy appliance parts online.
    How to Buy Appliance Parts Online
    http://www.fixya.com/support/r3907570-buy_appliance_parts_online
    heatman101
    Apr 23, 2010 | Jenn-Air JED8230 Electric Cooktop
    Thermador cooktop ignitors won't stop clicking
    I have the same range top. I am looking for the switch assembly. Do you know where I can buy this part? Please email me if you do. prboardman@yahoo.com
    Dec 30, 2009 | Cooktops
    I need a Thermador griddle control/ignitor & a light switch knob
    We are Thermador factory authorized service and parts suppliers. Just contact us at:
    http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
    and we can get your ignitor and light switch out to you asap.
    We look forward to working you. Thanks, Ella
    Nov 10, 2009 | Thermador 37 in. SGSX365 Gas Cooktop
    My problem with my AKT3650 is the unit sparked and threw a breaker at only one control. Even turned off the unit will throw a breaker and spark. I was thinking it was just one of the switch components -...
    So doing anything will throw the breaker? Must have a shorted wire either going to ground on the cooktop of where the cord wires in at the cook top. Dont know exactly but be looking for wiring with insulation gone and rubbing the frame or each other
    Sep 03, 2009 | Amana AKT3650 Electric Cooktop
    Old Thermador cooktop continues to spark even after turned off
    sounds like you have a bad switch. maybe on the large burner.. some of those switches can be replaced without the whole harness.
    Dec 22, 2008 | Thermador PSC364GDZS Gas Cooktop
    Thermador Gas Range - Griddle ignition will not spark
    I have a Thermador Gas Range PG364GDBS - Oven, 4 burners, and center griddle. All are gas. The four burners and gas oven work fine. The griddle just stopped working, no spark. Turning on the griddle control, the gas valve opens(hear it), gas flows (smell it), but the ignitor will not spark (no loud or faint spark that I can hear). I got a replacement ignition device (mount at the burner) thinking it might be the problem, but still no spark. I checked the AC voltage at the terminal and measured 39 VAC between the terminal and ground. Not sure if that is the correct voltage. Any insights or advice would be great.
    Dec 07, 2008 | Thermador SGS36GS Gas Cooktop
    Both burners turn on when only one is needed
    I just had the same problem- when I replaced the whole cartridge.
    I repalced the infinite switch- do the one that gets the hottest- or do both.
    It is easy to do- just write down the wiring diagram - make sure all power is off- cost of new switch was about $37.00
    This solved the problem- however make sure to check the sizng on the new switch shaft as my old knob would not fit properly on the shaft of the new switch.
    good luck
    Jun 20, 2008 | Jenn-Air JED8230 Electric Cooktop
    Jenn-Air 36 in. CCGP2720P Gas Cooktop Logo
    273 people viewed this question
    Top Jenn-Air Cooktops Experts
    Dan Webster
    Dan Webster
    jason
    Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
