Question about LG enV VX9900 Cellular Phone
Plz help hey my charge port on my env broke but i have the piece how do i charge my env do u know
  • ddomo1965 Jun 28, 2008
    k thanks is there a way i can charge the battery
  • 983 Answers
If the charging port in the handset is broke then do as i say below
if you are good at opening the handset then open it and just have a check whether the charging port is directly attached to the circuit board or it is separate from it ....
if it is separate from the circuit board then you need to buy a new charging port which is compatible to your handset & you can replace it easily ....you will get the spare parts in the shops ...
if the charging port is attached to the board then you need to contact the technician ..
he will replace the port or he will make an alternate arrangement(if the spare part of the port is not available)....
you can only replace the port if you are good technically ...
what you must do is first you must remove the solder from the board of the port then remove then replace the new one then solder it correctly at the points where the solder is needed with the board ...
to do this you must be highly aware of the servicing ... if you are not or if you are less aware then dont try this any single mistake may spoil the board ...
so then it is better to contact the technician ....
any way it is not so much costly it is just a matter of some bucks so you can just contact the technician if you have no idea about opening the handset & servicing it.....
any doubts you can reply me
i am always here to assist you
thank you
bye
please rate my solution as per your satisfaction
Posted on Jun 28, 2008
  • Dileep Keshavanarayana
    Dileep Keshavanarayana Jun 29, 2008
    there is a temporary way to charge the battery but you need to open the handset for that first ...
    after that near the charging port identify the positive & negative terminals then extend a little wire from there connect that to battery terminals correctly ..
    by this you will be able to charge ....
    or you can do one more thing just take another charger & cut the pin & identify the terminals then connect it to battery terminals (for this you need to remove the battery ...)
    do it with care if you connect to battery wrongly then short circuit may occur in battery & battery will be dead ......
    this is the difficult way as i think for you ....
    please rate the solution
Phone won't charge
Its the phone , and lg knows of the problem .
Jul 20, 2009 | LG enV VX9900 Cellular Phone
Envy charge port keeps breaking
Although today's electrinics are nicer to look at than things were 5 years ago, they're also more fragile. You must treat things like egg shells if you want them to last. I've had the same cell phone for 4 years, mi wife has been through 7.
Feb 17, 2009 | LG enV VX9900 Cellular Phone
My enV will not charge!
Hey i think i just figured out the problem to all the port charging issues for the envy and envy 2 phones with verizon. its not the phones, its the charger cord! the part that goes into the phone. it gets pulled out over time from pulling the cord out of the phone all the time. get a pair of pliers. grab the end and push the metal end of the cord against somthing hard, push it back in so it is at the appropriate depth. this should make it charge properly again!
Jul 17, 2008 | LG enV VX9900 Cellular Phone
Verizon Wireless EN V LG needs help
you can get the new piece of the charger port & can be replaced that by soldering the wire to the circuit board ........
any way the charger ports are available at very very cheap rates ....
buy the one which is compatible for your phone & replace it ......
thank you
bye
rate my solution
Jul 07, 2008 | LG enV VX9900 Cellular Phone
Broken charger port
i have the same problem with my enV my friend stripped the wires to my charger at the part where you plug it into the phone so now to charge my phone i tape the red wire to the positive on the battery and the black wire to the negitive there will be a shiny metal goldish color thing (there like 4 lil gold bars) on your battery that looks like this --> (negative) | | | | (positive) | - | | | + | tape the wires on the outside were the symbols are - and + and try not to let it toch the middle bars on the battery or it wont work and dont cover the little bars up with tape put the battery back in the phone making sure the wires dont move to much and it should charge sometimes you got tape the battery onto the phone to make sure it doesnt pop out but its what i do and it saves you money on having to go buy a whole new one or if you know someone with the same phone give them your battery to charge it :)
Apr 18, 2008 | LG enV VX9900 Cellular Phone
Won't charge
Same thing happened. The charging port is broken.
Apr 15, 2008 | LG enV VX9900 Cellular Phone
Charger port
Go to www.factorydirectcellular.com. They sell a battery charger that doesn't require the battery to be attached to the phone. This will work for the LG EnV phone. $17.00 + $3.95 shipping. Case closed.
Apr 01, 2008 | LG enV VX9900 Cellular Phone
Env help plz
The reason the phone won't charge is because the internal power port pins are broken off of their solder joints to the main board inside the phone. Wiggling it helps at first because the pins can still touch their connection points but after a short time that will cease to help. Google "cell phone repair". It usually cost around $50 to get it fixed with a new power port installed. Turn-around is usually 2-3 days.
Mar 05, 2008 | LG enV VX9900 Cellular Phone
Charger port problem
http://www.accessorygeeks.com/universal-travel-charger.html
or google BTC-UNI
iT'S little cheesy but hey for $10 and free shipping I can eat a lot of cheese.
Just plug your battery into this little clugy thing, plug the thing into the wall, wait until battery is charged and then put your battery back into your phone...presto...for this kind of money who cares if the VX9900 has a dead battery charge port.
I bought two, they were on sale for $7 each. It's ugly and takes a bit of patience but it works.
Feb 26, 2008 | LG enV VX9900 Cellular Phone
Charging
sounds like there is something stuck in your phone or a piece of your charger broke. You can try and buy a new charger or bring your phone to verizon to check it out
Aug 21, 2007 | LG enV VX9900 Cellular Phone
LG enV VX9900 Cellular Phone Logo
80 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
