Question about Linksys Wireless-G Broadband Router
How to restrict access
I have a linksys wireless network, with 2 desktops and a laptop using it. i would like to make sure nobody else can use it.
  • 689 Answers
There are several ways to restrict access, You can put WEB or WPA key, Or alternately you can use MAC address filtering. You can go to router menu by typing the IP address on your browser, Its usually 192.168.1.1 go to wireless menu and choose MAC address filtering. You can choose to allow only, add the MAC address of your computers.
Good Luck
Posted on Jun 28, 2008
    Scholar:
  • 176 Answers
Check the manual ...
- give all u;re comps. a static IP address (and limit the possible IP's to u;re 3 computers, just 3 IP;s)
- also set u;re router to accept only those MAC's, so no other computer can make proper contact with the router, and so with u;re network ...
but again, check the manual, u should find all u have to do to secure u're network there ...
How do i make sure nobody else is using my internet without my permission?
You need to set up a network password to keep others from piggy-backing onto your internet connection and to secure others from accessing your data. I can walk you through the process if you give me your router''s manufacturer and model.
Jun 26, 2011 | Computers & Internet
I have a linksys wrt54GX2 wireless G router and I would like to use it as an access point to pick up our internet signal from downstairs. The modem in use is wireless motorola SBG900. I have a desktop and...
With that particular model you wont be able to use it as a wireless bridge. You can however run an ethernet cable from the modem to any point in your house. the SBG900 i believe has wireless built into it, so you may need up with 2 wireless networks.
Hope that helps.
Feb 05, 2011 | Linksys WRT54GX2 Wireless-G Broadband...
Im trying to hook my desktop up to the wireless router so that me and my dad (both with laptops) will hook up wirelessly. I tried reseting Linksys Broadband Wireless G Router and made sure all of the...
Try: Clarify - the desktop is connected with an ether net cable? Is working? Install router software on desktop to manage router. Trying to connect desktop wirelessly? Wireless card installed? Radio activated? Network detected?
Dec 31, 2010 | Linksys BEFW11S4 Wireless-B Broadband...
Having trouble with initial connection to an existing wireless network wireless router is a cisco wireless-n broadband router and we have 2 laptops and a printer on a wirelss network already
Follow these instructions to connect to a wireless network using the Linksys Wireless Manager.
Step 1:
Launch the Linksys Wireless Manager. To learn how to access the Linksys Wireless Manager, click here.
Step 2:
In the Connect to a Wireless Network screen, locate the name of your wireless network in the list.
NOTE: If your wireless network is not in the list, click here to learn How to Connect to a Hidden Wireless Network. If your wireless network supports Wi-Fi Protected Setup kb17673-005_en.png, click here to learn How to Connect Using Wi-Fi Protected Setup.
Step 3:
Select your network. Then click Connect.
Nov 01, 2010 | Linksys WUSB54GSC Compact Wireless-G USB...
How do I make my router access secure?
look on the bottom of your router there is an ip adress, go to it and enter the password located on the same sticker the ip adress is on. Once you access this page you are in the router's setting, go to security and select the settings you want.
Mar 05, 2010 | Linksys Wireless-G WRT54G Router
HP Laptop does not connect to internet unless directly
Hello dstoller,
You description is very confusing to sort exactly what is or isn't happening.Let me try to sort out what you have:
You have a Laptop
You have a Desktop
Desktop has a printer attached
You have a DSL modem with a wireless router
Laptop via ethernet: Good
Laptop via wireless: Not Good?
Desktop via wireless: Good
Not sure exactly what you are needing help with...
- Vincent
Still not sure what
Nov 22, 2008 | 2wire (1000-000005-002) 802.11g/b Wireless...
Setting Up a Wireless Network
You can still use your existing Linksys router with your cable modem. In fact the router your have is designed to work with DSL/Cable Broadband connections.
1. Make sure to properly connec the devices in your network. Modem will be connected to the Internet port of the router. Then, laptop will be connected to one of the 4 Ethernet ports of the router. For initial setup of your router with modem, you need to hardwire laptop to the router.
2. Press and hold reset at the back of the router for about 15 seconds.
3. After 15 seconds turn off the router and then turn off the modem. Wait for a minute.
4. Power on modem and wait for the lights to be ready.
5. When modem lights are on, turn on router.
6. There should be 4 lights on. Power should be steady green. Internet, WLAN and Ethernet port.
7. Checked if you have Internet connectivity on your laptop while it is wired to the router.
8. If Internet is working, disconnect laptop from wired connection to the router and check available wireless network that laptop can detect.
9. The default wireless network name that the Linksys router broadcasts is "linksys". Connect to it which is an unsecured wireless network.
10. Once you are successfully connected, check Internet.
Hope this helps!
Nov 16, 2008 | Linksys Wireless-G Broadband Router
Cannot connect to WRT54g
think you have to connect a cable to the ethernet adapter of your desktop in order for you to connect to the wrt54g. uless you have a wireless lan on your desktop. also check your channels. and manually config your router through 192.168.1.1.......
Aug 31, 2008 | Linksys (WIFIDESKTOP) Wireless Adapter
What are the step for setting up you computers to a network using a Linksys router. I have a 2 PC's and a laptop that I would linke to net work together. My first computer is connect to the Wireless-B...
Hi Ed, if your using windows you can open network connections & run network setup wizard. Follow the instruction for a home network for the wireless PC's & notebooks. Once the network is setup for all PC's than you can install the printer cd software in the PC's that you want to access the printer. Each PC & notebook will have access to the printer through the network.
The PC that that is connected to the printer needs to be shared.
Open printers and Faxes. Right click once on the printer & left click sharing. Agai follow the instructions.
Lastly,I strongly suggest you setup security for your wireless. If you do not anyone close can tap into your network connection. Follow linksys instruction to setup security. If you run into a problem you can call linksys for free advise from a pro. Their number is listed in the manual.
http://www.linksys.com/servlet/Satellite?c=L_CASupport_C1&childpagename=US%2FLayout&cid=1175238819816&pagename=Linksys%2FCommon%2FVisitorWrapper&lid=1981627773H10
Good Luck! Take your time.
Have more questions, feel free to ask.
Mike
Apr 04, 2008 | Computers & Internet
Networking question
Ok, you have several options. Go to a website such as bestbuy.com. Type in linksys and look of wireless access points, wireless usb adapters or a wireless desktop adapter. I would go with the third one.
Mar 30, 2008 | Linksys Wireless-G Broadband Router
Linksys Wireless-G Broadband Router Logo
123 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
