Question about Toshiba 42HP95 Television
Turned off by itself, blinking red led at front
42HP95 just turned off by itself, then red LED is blinking. Unplugged overnight, still blinking LED. Everytime I re-plugged power cord, heard clicking sounds from back but still won't turn on, blinking light at front.
Please give solution and if parts are needed, where can I get them. Thanks.
  • 1 more comment
  • Anonymous Jul 21, 2008
    same problem
  • tsioc Oct 18, 2008
    Tv was off overnight, woke up in morning to find power light blinking, tv won't turn on. I unplugged, then when I plugged back in I heard clicking sounds from the back, then the red light started blinking again.
  • Anonymous Dec 02, 2008
    I have the exact same problem. Red light blinking...clicking sounds when unplugged...goes back to the same thing.
    Mine is a Toshiba 57" HD Rear Projection...not sure the model #.
  • Toshiba Master
  • 19,396 Answers
The clicking sound is the internal protection switch that kicked in because a fault had been detected.
First ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem on dvd with no receiver box connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the Monitor goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic chargesaccumulating on capacitors, or because of a wrong voltage read by themain chip on your monitor controller board. this started the protectioncircuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occurr are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing statebecause of the video cable.
Try moving the video cable, and if the cable is not built in, then also try a replacement cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Posted on Mar 15, 2009
Why no picture?
Probable power supply failure
Apr 14, 2016 | Insignia Televison & Video
Nec vt540 vt540k
probably needs filters cleaning or a new lamp replacement.
Oct 07, 2013 | NEC VT460 Multimedia Projector
Tele turned itself off, red light blinks 4 times then pauses and blinks 4 times again.
You can try unplugging it for a while and then plugging it back in, but according to the manual, the standby LED:
Lights up red when your TV is in PC power saving mode. If the LED blinks in red continuously, this may indicate the TV needs servicing.
(Operating Instructions, Page 22)
Mar 05, 2011 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
TV won't turn on. Blinking red light on front of TV.
I'm troubleshooting the same problems here. The flashing red LED indicates a fault has occurred. I found one the three fans inside not running (the smaller of the three). I plugged in the other two fans in it's socket and they do come on, but the smaller one does not. I took the fan to my bench and applied 12V and it does not run. I'll have to replace the fan and see if the tv comes on.
Al
aoraha@gmail.com
Dec 20, 2010 | Toshiba 42HP95 Television
The front LED flashes red & blue when I turn it on. What does this mean?
LED Indicators - LaCie 2big Network
The LED indicators above the drive bays and the front LED indicate drive status and activity.
During Startup
  • Front LED – blinks red/blue until both disks are powered on, then turns solid blue.
  • Rear LEDs – blinks red/blue until corresponding disk is powered on, then turns solid blue.
NOTE: If the device is not able to initiate the boot process following disk startup, the front is solid red.
During Bootup
  • Front LED – solid blue
  • Rear LEDs – solid blue
NOTE: If a disk is failing, both the disk’s corresponding rear LED and the front LED will be solid red.
During RAID Synchronization
  • Front LED – solid red
  • Rear LEDs – The LED corresponding to the original disk will be blinking blue and the one being synchronized is blinking red
  • Once both disks are synchronized, their corresponding rear LED and the front LED will be solid blue.
Apr 06, 2010 | LaCie 2 TB 2big Triple Interface External...
I have a Philips Plasma tv 42pf5321d/37 with sound but no picture
Thats the great sound of Exploding capacitors on either the power supply board. or another one in there. Now the set is in fault protection. It tried to warn you with the RED blinking LED that there was something amiss by shutting itself down. When you unplugged you reset the error and allowed it to do it again.
Best Regards and Smper Fi
Jun 23, 2009 | Philips 42PF9630A 42 in. Plasma Television
Toshiba 42HP95 TV turned itself off, red light blinking
has overheating issue try vacuming out the top and rear of tv. fan could be dead
Jun 02, 2009 | Toshiba 42HP95 Television
Toshiba plasma 42hp95 tv will not turn on red led lights blinking
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
Feb 23, 2009 | Toshiba 42HP95 Television
Toshiba 42HP95 Plasma tv
http://www.fixya.com/support/t101749-tv_turned_itself_off_turn_back
Worked for me, was ez, and I am a huge skeptic and not very "TV technical."
Dec 23, 2008 | Toshiba 42HP95 Television
Televison & Video Logo
357 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
