Question about Microsoft Xbox 360 Console
Picture but no sound
I left my xbox 360 on overnight inside a cabinet with the door closed.  This morning it was extremely hot and now the sound doesn't work.  The picture and connection to xbox live are fine.  Any suggestions?
    Scholar:
  • 31 Answers
Red ring is not the only problem with Microsoft Xbox 360. This amazing device also has some more common problems like Audio but no video problem, disc read error etc. Microsoft is providing extended warranty only for red ring problem. Means you will have to spend some money to get this problem repaired also if you plan to send your xbox to Microsoft, you will have to wait for 3-4 weeks to get back your favourite Xbox. There is one more option in the form of DIY guide, this guide explains solving No Video problem with step by step instruction, so any novice can fix this problem
Posted on Mar 14, 2009
  • 92 Answers
Make sure you try it with different tv's as well, my tv messed up and i thought the video from my xbox was messed up, but it was just the tv. also try switching the ports, (put the red where the white goes and the white where the red goes, leave the yellow alone)
Posted on Jun 28, 2008
Door closed and auto open
the door isn't closing all the wy then xbox has a trigger so if the disc ge
t bumped out of the slot and the door is opening it will make it close back so it doesn't break the disk or the door same with closing then reopening check make sure there isn't anything inside perveting the door from fully closing
Sep 20, 2013 | Microsoft Xbox 360 Console
My xbox 360 turns off in the middle of a game
It's overheating. Probably dirty inside or vents plugged. Try cleaning it inside. There are pictured turtorials at Llama.com. Then use a small house fan beside the unit blowing towards the intake side, same side the usb ports are on. Keep fan on as long as your playing, and make sure unit is out in an open area, not inside a closed cabinet. Good Luck.
Feb 20, 2011 | Microsoft Xbox 360 Console
Ge spacemaker xl1400 model# jvm141obc Turntable still turns..but while making grinding sound Please help
My wife noticed a strong smell of something burning inside our home. Luckily we were home. The microwave was NOT on...and the turntable was turning and making that grinding sound. When I opened the door, the turntable kept turning....all digital lights were OFF. The microwave does not work. I am extremely angry that this unit was able to continue to grind unnoticed. If we were not home, I assure you that this would have caused a kitchen fire. The upper inside portion was extremely hot to the touch and the cabinet on top of the over-the-range microwave was also very hot. This would have easily caused ignition and a subsequent kitchen fire. I am going to report this to the UL.
Feb 10, 2011 | Microwave Ovens
The two fans are going crazy
Xboxs 360 that were first released when the console was released run very very hot. They are built with less efficient chips
These chips do run hot and the xbox knows it so its running the fans super hot. That is the reason the older consoles are so much louder than the newer xbox 360s.
Just make sure you keep the 360 in a well ventalited place. I know entertainment centers with doors that close are a no no unless the door is open.
May 31, 2010 | Microsoft Xbox 360 Console
My xbox keeps staying on for 2 minutes then blinks 2 lights on the left
its the over heating problem in your x-box. Sections 1, and 3 are flashing red
- Overheating
Alternatively Overheating can be cause by the console locking up or "freezing" after a set amount of time. Lockups that occur at a specific point in a game are generally problems with the game itself and not caused by overheating.
THINGS TO TRY
1. Let the Xbox 360 console cool.
Note You may have to wait several hours for the console to cool enough. Do not turn on the console when the console is hot.
2. Verify that the console has sufficient ventilation and that the fan is operating.
PREVENTION SUGGESTIONS
To try to prevent this problem, use the following precautions:
* Do not block any ventilation openings on the Xbox 360 console.
* Do not put the Xbox 360 console on a bed, on a sofa, or on any other soft surface that may block ventilation openings.
* Do not put the Xbox 360 console in a confined space, such as a bookcase, a rack, or a stereo cabinet, unless the space is well-ventilated.
* Do not put the Xbox 360 console near any heat source, such as a radiator, a heat register, a stove, or an amplifier.
DO NOT EVER PUT YOUR CONSOLE IN THE FREEZER OR OUT IN COLD WEATHER
Some people think that doing this might help "fix" an overheating console, in fact doing so could cause even bigger problems. Electronic devices like your console are made to function at and around room temperature, extreme cold temperatures can often cause just as many problems as extreme warm temperatures (such as overheating). Also if the console is located in a dramatically cold area while running, the difference in temperature between the hot console and cold air can create condensation which in turn will short out your console making the situation far worse. Condensation will happen more quickly if your console is overheating due to the greater difference in temperature. In short... DON'T DO IT.
A more aggressive Solution to overheating is to improve the cooling system of the console. The best solution is to replace the thermal compound. If you attempt this you do so at your own risk. If you're console is still under warranty it is recommended that you contact MS for a replacement before attempting to fix it yourself.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Feb 28, 2010 | Microsoft Xbox 360 Console
After playing a game for 10 min. or less playing on an xbox 360, the screen turns off and the xbox has 2 red lights on the ring of light the console
Hi. This two light error code is signaling that the console is overheating.
Alternatively
THINGS TO TRY
Nov 02, 2009 | Microsoft Xbox 360 Console
My son's xbox 360 was working fine yesterday. His friend was playing on it for about 5 hours. When he tried to play this morning - the sound came on but no picture. He has disconnected everything and re...
Hi Mom, the bad news is your sons X-box is in need of an x-clamp replacement. It happens when the x-box gets too hot and causes the clamps to warp. The good news is that it is a fairly common problem and is usually relatively inexpensive to fix. I would recommend finding a game store who repairs these in your area.
Aug 10, 2009 | Microsoft Xbox 360 Console
Xbox 360 Wont Read Games or DVD's
take out your hard drive and then turn it on restore factory settings and plug it your hard drive back in
Feb 21, 2009 | Microsoft Xbox 360 Console
Xbox 360 door will not stay closed
take the faceplate off then open and close it,
also make sure there is nothing blocking the door and there are no other discs in the tray.
Nov 16, 2008 | Microsoft Xbox 360 Console
XBOX 360 STAYS OPEN / EJECTS GAME AFTER DOOR CLOSES,
sounds like a faulty sensor on the xbox rom drive,
if its still under warrenty, bring it back...
x-b-m
Mar 04, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
