Question about Whirlpool Refrigerators
How do you change the water filter on a fridge?
  • Anonymous Feb 07, 2009
    where is the water filter at?
How do I change the filter in my refridgerator
Posted on Jan 31, 2009
I have a frigidaire gallery series side by side and everytime the fridge says the water filter needs to be changed now it leaks a good bit of water from the bottom of the fridge.
There is an O ring that will leak water into the overflow pan under the fridge. I'd clean the pan too to eliminate bad odors. You must shut off the water supply before changing the filter element. There is no shut off valve built into the filter or its housing.
Aug 08, 2015 | Frigidaire Refrigerators
Ice tastes bad
If It were me I would change the filter in the fridge, that always worked on mine.
Dec 03, 2013 | LG LRFD22850 Bottom Freezer Refrigerator...
How to change the water filer on a rf4267hars 25.5 ft
You must shut the water valve to change the water filter. If you don't havewater valve near the fridge, shut the main water valve for few minutes. If you turn the water filter to change without shutting the water valve, lots of water flooring the fridge and you do lots of work to remove the water inside the fridge. Shut the water valve, and then replace the filter. Then turn the water valve.
Apr 02, 2013 | Samsung RF4267HARS 25.5 Cu. Ft. French...
I changed the water filter in my Whirlpool refrigerator, model #EDVHEXVQ01. I then tried to reset the filter light, but it did not work. Should I do something different to reset it or did I do something...
Hi
I guess you changed the filter with the fridge plugged in, you need to switch off and unplug the fridge, switch off the water. Then switch on the fridge and bleed the water line for 5 second intervals every 5 seconds for 1 to 2 minutes.
That should solve the problem
Regards
Gordon
Apr 20, 2011 | Whirlpool Refrigerators
I have a GE MWF water filter that is dripping water into the refrigerator. Fridge is about 8 yrs old and have changed many of the MWF water filters. 1st time with this problem.
Many times fines from these filters become dislodged and plug up the filter housing. If you have the bypass plug for the filter, install it and run a couple gallons of water through fridge to flush the system completely. The install the filter again. Make sure none of the water lines feeding fridge are pinched or kinked and valve is on all the way.
RJ
Nov 30, 2010 | General Electric GE SmartWater Household...
Water filter question
WOW! I'd say that the filter is definately due for replacement.
The manufacturer recommends the filter be changed every 6-8 months, as with ice and water dispensers in the door, folks tend to use the chilled water and ice more often, hence you get alot of gallons of water thru the fridge each month.
Once you replace the filter, you'll need to flush out the lines, (see the instructions with the new filter) to get rid of any loose carbon in the filter element, but once you done this, you should also notice better water flow and better tasting water and ice cubes too.
I tend to change my ice/water filter on my fridge every year when I change my smoke detector batteries. That way, I don't forget, sort of like my personal "once-a-year" house task list to change batteries, filters, resetting timers, etc., etc.
It's a good idea to change these smaller filters at a minimum of once a year, as they are no longer providing the filtration you want, and can actually be letting some of the contaminents fow out and into your water and cubes.
Hope you find this Very Helpful and best regards!
Aug 20, 2009 | KitchenAid KSSP48QMS Side by Side...
How do i change lg fridge water filter
have just changed the filter on our lg fridge, it's not easy: the filter is external, at the back of the fridge. the fridge has to be pulled away from the wall and then the filter can be seen.
Aug 14, 2008 | LG Refrigerators
Refrigerators Logo
231 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
