Question about Dell Inkjet 720 Printer
Dell Inkjet Printer (not sure its a 720, but it's similar)
I am trying to print addresses on envelopes, using the Microsoft Windows envelope printing function under "tools." Even though I've programmed the settings to make the printer print my envelope addresses in black, it always prints them in pink. What can I do?
    Problem Solver:
  • 37 Answers
Switch the pink cartridge with the black one.
Posted on Aug 19, 2008
SOURCE:
How to print both return address and to address on ?size 10 envelopes
Open Microsoft Office Word.
Open File > Page Setup > Paper size > Envelope #10 (in Office Word 2003)
or
Open Page Layout > Size > Envelope #10 (in Office Word 2007 / 2010)
Then type the address like usual typing and print it.
I've found website to do this manually, but I'm not sure what the printer is. You can check out in here :
How do I print on thicker paper, labels and envelopes?
Hope this help, and if you feel helped, RATE please !
Jan 19, 2011 | Lexmark Z600 InkJet Printer
Printing envelopes
HI,
Try this one.Make sure the HP paper size setting needs to be "plain paper," not "automatic.
Aug 17, 2008 | HP Photosmart 3210 All-In-One InkJet...
How to print envelopes?
use the hp software ..and use the envelopes templates in the setup of the page ..or ...just open Microsoft office word ..and select the mailings and in the left side will be the envelopes template ..(office 2007)
Jun 03, 2010 | HP DeskJet 940c InkJet Printer
How do I print an envelope with my MFC 240C?
Printing envelopes is tricky. In the MFC-240C, you have to place them face down (with the flap side facing up), and it's best to load one at a time because sometimes the printer has problems pulling it when there is a stack of envelopes in the paper tray.
Make sure the fences are snug against the envelope when you load it. If you get a lot of jamming when trying to feed envelopes, you may have to run it with the flap open -- sometimes the closed flap sticks up just a bit and gets caught as the envelope is fed through the machine.
To orient the addresses correctly on the envelope, you'll need to use the correct settings, depending on which program you're printing from. In Microsoft Word 2003, for example, there is an Envelopes and Labels option under the Tools menu (click on the Letters and Mailing submenu) that you can use to enter the addresses and make sure they line up.
Apr 15, 2010 | Brother MFC 240C All-In-One InkJet Printer
Can't address envelopes using Microsoft Word 2007 & Windows 7
Excellent question. Wish I had the answer. I have the same problem with the MFC-7440N. I hook up my old HL 1240 and it prints them fine, so I now use two printers - one for envelopes and one for normal printing. I contacted Brothers and was told that it was not the printer, but the Application. If so, then why does my old Brothers printer work? They do not have the answer.
Feb 24, 2010 | Brother MFC-7440N Laser Printer
I have a Dell Printer 720 and envelopes won't print.
make sure in the control panel the options are clearly marked for envelope printing
Jun 06, 2009 | Dell Inkjet 720 Printer
Dell 720 only prints red on envelopes
hi!!!
what type of printer ur using?
because the other color of catridge nozzle might have been clog
this are step that you need to do!!!
1.perform maintenance of your printer in the setting
2.clean up the nozzle.
3.remove the cartridge clean with alcohol or solvent use cotton buds.
4.if doesn't print again replace your cardridge.
or email me ronaldsuboc@gmail.com
Sep 18, 2008 | Dell Inkjet 720 Printer
Envelope Feeder is not accepting the command
> Home > Support & Drivers > Knowledge Base
Solution --> Phaser 4400 Printer: Printing envelopes
Printing EnvelopesEnvelopes can be printed from the optional envelope feeder, the Multi-Purpose Tray, or Tray 1, 2, or 3.
Guidelines for envelope printing
  • Use only paper envelopes.
  • Do not print on the back of the envelope.
  • Never use envelopes with windows, metal clasps, or exposed gummed surfaces.
  • Keep unused envelopes in their packaging to avoid the effects of moisture and dryness, which can affect print quality and cause wrinkling.
  • Envelopes may wrinkle depending on weight and stiffness of the envelope.
Many applications include a tool for creating an envelope document. For example, Microsoft Word includes an Envelopes and Labels feature in the Tools menu. Be sure to:
  • Select faceup.
  • Clear Clockwise Rotation.
  • Select the feed method with the image centered and the stamp on the envelope to the upper left.
caution_image88x30.gif Never use envelopes with windows, metal clasps, or exposed gummed surfaces; they can damage the printer. Damage caused by using unsupported envelopes might not be covered by your printer's warranty.
note_image33x30.gif Note: The heat from the printing process can melt certain types of envelope glue. If the envelope flap sticks shut after printing the test print, tuck the flaps inside the envelopes when printing the remaining envelopes. Printing envelopes from the envelope feeder
  1. Insert the envelopes into the envelope feeder. For more information, refer to the Trays section of the Trays and Paper Guide on the Interactive Documentation CD-ROM.
    • Place the side to be printed faceup.
    • The top of the envelopes should be toward the left of the printer.
Feb 19, 2008 | Xerox Phaser 4400B Laser Printer
Dell 720 Printer not printing envelopes.
I got the printer to print envelopes again. I completely uninstalled the printer, then reinstalled it by simply pluging the USB connection in. After I had first uninstalled it after the envelope problem started I had been using the 720 printer CD to reinstall it, and it still wouldn't print envelopes. I looked for and found the printer installition instructions and saw that I didn't need the CD to install it. (It was causing a software conflict). The Dell 720 Printer came with my Dell Dimension E310 PC new and the printer software was already on the hard drive. All I had to do was plug in the USB cable, and the printer was up and running like new again. Don't forget, if you don't want Dell to monitor your printer use, DO NOT check the box to allow that when it comes up during installation, other wise you'll get that icon showing up. Hope this helps. Chuck
Jan 09, 2007 | Dell Inkjet 720 Printer
Dell A920 won't print envelopes
I have(had) the same problem using the Dell A920 printer on a Dell compunter running XP. After spending a hour trying to find a solution on the internet, I finally found a solution on my own. When ready to print a envelope. Go to File/Print Click Properties button In lower right hand corner, check "Print Color Image in Black and White" box Click OK button Click OK in print pop up When finished, repeat to uncheck "Print Color Image in Black and White" box to allow for color printing.
Dec 02, 2006 | Dell A920 InkJet Printer
Dell Inkjet 720 Printer Logo
376 people viewed this question
Top Dell Office Equipment & Supplies Experts
David Patricia James
Marvin
Marvin
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
