Question about Dometic Rooftop RV Air Conditioner
Temperture? how cold should the air be coming out of the ducts?
  • cudock1 Jun 29, 2008
    but i need to know about what it should be, right now its only about 51
  • 828 Answers
A 20° F differential temperature is considered satisfactory.
Posted on Jun 29, 2008
  • James Helmer
    James Helmer Jun 30, 2008
    If your temperature coming out of the ducts is at 51°F you are doing very good. An example of a 20° Differential would be with a room temperature of 76 and an outlet temperature of 56. The outlet temperature depends on many factors such as humidity level, outdoor ambient temperature and indoor temperature. Humidity level in a house must be reduced before the temperature can come down. Heat content of air is directly related to the moisture content of the air. (Grains of moisture per pound of dry air). Thus air outlet temperature will not be a constant.
  • James Helmer
    Glad we could be of service in resolving you question.
2003 ford expedition i just got it a week ago and the front heat works great but the back vents only blow cold air. How do i fix this?
With the car parked and engine idling, turn the ventilation control between windshield defroster and "open air ducts" to front and rear vents. Listen to pinpoint where the valves are that open and closes the air ducts. It sounds like the air duct to rear vents are blocked, and the cold air in rear air duct is coming from "outside ventilation." The air vent to allow hot air to the rear vent is stuck in "open ventilation" mode, like when you're driving in spring or summer months.
Nov 29, 2013 | Cars & Trucks
I have a Ruud air conditioner model #13AJA36A01757. The temperture out of the vents is only 70 degrees while it is running. Outside unit, low side is very cold, and the high side is not hot, not even...
If your vents are in the floor, you need to inspect your return air ductwork, you may have some air leaks pulling hot attic air in thru the vents. If the supply vents are in the floor, the return duct may run through your attic, if the duct work is uninsulated or pulled apart, it will pull hot air thru the return, causing a mixture of cold and hot air, giving you a warm air movement through the ductwork. Many service men will not catch this problem. You need to turn the unit on, go up in the attic and visibly inspect the entire return air. I hope this helps you. mark
Aug 14, 2011 | Ruud Heating & Cooling
Where is the location of IAT sensor on Ford Fiesta?
depending on the year & engine
intake air temperture (iat) will be mounted in air cleaner housing, or air tubing/duct work
coming into engine
Jun 27, 2011 | Ford Focus Cars & Trucks
Heating system do not work. It started a couple of weeks ago. When set at 70, it produced no warm air. cold air would come from the vent/duct. when increasted to about 76, it would produce heat. Now it do...
I have the exact same problem. Started occasionally blowing cold air. Now I can't get the hot air to come through. Could it be a flapper door that open and closes depending on the tempurature setting?
Jan 04, 2011 | 2006 Lincoln Mark LT
Engine code 25 is on changed it twice sensor and it wants to turn off when i come to a stop and it floods out and turns off its 89 s10 2.5 liter
Dec 29, 2010 | 1988 Chevrolet S-10
There is no heat in my car, it keeps over heating
Check the system for an air bubble.
Start the car cold with the radiator cap off. Let the car come to temperture and squeeze the upper radiator hose and see if you can work out any trapped air.
You may have gotten the wrong stat too. It happens.
You may want to pull it and test it out of the car to be sure it opens at the right temperture.
Jan 07, 2010 | 1996 Chevrolet Cavalier
Runs on a/c all the time no heat
this problem is caused by a failed air temperture control blend door actuater motor, this little device moves the door inside the ducting back and forth to give hot warn or cold air, the most oftern stick in the cold air position.
Oct 15, 2009 | 1997 Ford Explorer AWD
With AC on cold, Drivers air full hot & passenger side full Cold
that is a good possibilty, but before I pulled the trigger I would try this first. unhook the battery for 5 minutes, rehook it, now turn the key on, wait for 2 minutes, now start the truck and see if the doors now work. sometimes this works, its worth a try.
Sep 26, 2009 | 2005 GMC Sierra
Cold air coming from the intake of the central a/c unit. The unit is switched off and it is winter, so why would cold air come from the intake
Thanks for your question,
Just a couple of questions first, is your ducting insulated ? is there a fresh air intake on your system ? if either of these is the case, the first would be that you need to have your duct insulated, it is good practice to have them insulated as it will save you money down the road as to not have as much heat loss or cold air from the duct escaping into the home, second if you have a fresh air intake, alot of times that is where fresh outside air would be coming in from, there should be a damper on the venting, if there isn't I would suggest having one installed, normally it is installed on the return side of your ducting. Hope that was helpful, please leave some feed back as to how we did, thanks again,
Jan 23, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Central Air Conditioning
It sounds like a restriction in your ducting. Feel the A/C vents in the hot rooms to see if cold air is blowing out of them. If the ducts are restricted, then it is possible that the air conditioning coils are freezing up from lack of circulation. Inspect the ducts if you can to see if there is any restriction.
Note that even if you feel air coming out of the ducts, it could be ambient as opposed to cold. The best thing is to measure the air temperature coming out of the ducts. It should be around 20 degrees colder than the ambient air at the intake of the A/C.
Sep 03, 2008 | Computers & Internet
Dometic Rooftop RV Air Conditioner Logo
43 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
mike cooper
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
