Does the whining noise come from the motor or the brush area? If it's from the brush area, it's probably the belt. Check to be sure the belt is not worn. Sometimes belts will glass up and slip. Also, check to see if it is still completely on as it should be. You may need to replace the belt.
I woHope this helps, if it does, please place a vote for me. Thanks,
Most likely it's just the fan that is making the noise rather then the motor. The way the Kirby vacuums are designed, anything hard that's vacuumed up such a coin, or other hard things can break the fan.
In order to check and see if it's your fan, remove the front part of the vacuum that contains the roller brush and belt. If you're not sure how to do this, here's a video that shows you how to change the belt, but will also explain how to get the front bell shaped housing off:
Once you have the front cover off, look inside the vacuum directly behind the motor shaft. You will be able to inspect the fan here. Turn the motor shaft which also turns the fan, and see if there's any cracks, or if the fan blade is broken. I think most likely you'll see the fan damaged somehow.
Here's a video repair that we've put together that explains step by step on how to replace the suction fan on your Kirby:
Part 2:
Hopefully this helped you fix your Kirby. Please be so kind and rate the repair, or leave feedback if this was helpful to you. Thanks so much,
PUll the roller brush out and make sure it turns freely by hand. If not clean all hair and debris off the roller brush, you might also remove the end caps (one at a time) and clean the hair out from the bearings underneath the cap (in the shop I use WD-40 and a non-serated pairing-knife). Replace caps they only go one way. If you can not free up the brush you'll have to replace it.
If the brush spins freely probably just need a new belt they stretch out over time.
The carbon brushes in the motor need to be replaced. Very IMPORTANT....... DO NOT run the Kirby anymore until you get this fixed. If you do, the armature will be in danger of being damaged. (and that part is expensive!) The carbon brushes are reasonably priced, and you can use this online guide to get to them and change them. It's a guide for replacing the power switch, but it will help you change the carbon brushes too. Hope I've helped...
Marci
