Question about Samsung SGH-D500 Cellular Phone
Lcd screen no back light on the screen. thanks
  • frank1966 Jul 09, 2008
    My cell phone is a samsung sgh d 500e
    i can turn it on
    i can't make any call's because the key to say ok for the pin won't work.
    Thank's
  • DASEP
    DASEP May 11, 2010
    Which cell phone you have?
    Can you make a call?
    Does the phone turn on?
  • 96 Answers
It sounds like the phone is damaged. If you have insurance, the cell phone company can replace it for a new one. If you have no insurance, the cell phone company can run a check on it and let you know what is the problem and how much to fix it.
Artgirl
Posted on Jul 09, 2008
Samsung UN55EH6000 has audio, but no backlight LED as seen with flashlight test.
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Feb 29, 2016 | Samsung Electronics UN55EH6000 - 55in...
I have a Technics PR-305 Digital Piano The LCD screen back light has gone dimmer is there anyway to fix it to make it brighter or would I have to Forget it?
Yes. LCDs require back lighting.Think of an LCD as a window blind. It has to open to let the sun shine through, or close when you don't want the light. The LCD, works much the same way. it opens for light(in this case, not he sun, but a man made light, bulb, LEDs, etc. When your back lighting goes away, the display is darker, or completely dark. You will need to repair whatever method is used for back lighting. If you require additional assistance, or would like to inquire about a repair, please visit my website at audioseviceclinic.com. Thank you.
Jul 26, 2014 | Technics Audio Players & Recorders
Hi, when i switch on my LCD, screen is coming blank, with clear sound and after few seconds the LCD is switched off automatically.
In that case or symptom,the problem is either come from the power supply or back lights inverter board.The screen or the display is totaly black when the back lights is not working. The inverter board have blown surface mounted fuses that my cause of shorted transistor,transistor or leak capacitor.Thanks.hope it will help you..
Sep 03, 2011 | Panasonic Viera TX-32LX70 32 in. LCD TV
I shut my computer down, I then traveled about 10 minutes in a car. When I arrived the computer had not been dropped and nothing hit it. When I attempted to turn it on it booted all the way. I could hear...
It is for sure that a damage is done on the LCD and it needs to be checked on HOW THIS HAD HAPPENED.
It seems that if the laptop was not shut but the LCD display door was made to stay OPEN while you were driving then the motion/vibration could have damaged the LCD or the linking wires to the LCD panel. Check carefully on the hinges of the laptop and see if there is any cracks. Also if there is display on an external monitor then the PC is working fine . You can open the laptop and ccheck if any connector of the LCD panel is loose. If no the LCD is a suspect and You must take an opinion from HP. Claim for warranty if the time limit is within.
Jul 13, 2011 | HP Pavilion dv4-1140go Laptop
The green light comes on but the screen wont light up, meaning the tv wont turn on
hi,
You have to check the back light of your lcd TV. All lcd screen have a back light to illuminate the pixels. you can conform is the back light is faulty or not by watching the lcd screen nearby. Watch can you see any image (negative image) on the screen. you have to look very closely. if you see any image on the screen then the back light or the back light inverter is faulty.
You have to check the back light inverter board. Normally in lcd monitors you can see three circuit boards. power supply, mother board, and the inverter board. If available then try to replace the inverter board. There are high voltage transformers in this board. There is a chance for its winding get short. You will not get the transformer in open market. Try for the inverter board .
ok
Jun 09, 2011 | iSymphony LC24IFH7PB LCD TV
My tv has sound but has a black screen
hello thanks for sharing your problem to FIXYA...you have problem to the heater of of your CRT it have no ac supply to lights up your screen I teach you how to fix that problem..
first remove the cover of the unit.next,find wheres the fly-back.secondly, check open resistor in the secondary of fly-back that comes directly on the CRT socket its called heater..the supply of of heater should 5-7volts ac thank you this solutions help you if your TV is CRT
if your TV is LCD your problem is on the back-light of your unit you can replace it on your on by removing the cover of unit then look for the back light inside next.remove and replace a new one for LCD only
http://shop.ebay.com/i.html?_nkw=flat+panel+lcd+back+light&_armrs=1&_from=&_ipg=
if my solution helps you don't forget to vote and rate me thank you
Mar 06, 2011 | Televison & Video
Touch screen shows wear and tear
LCD will be replaced as there is no cure for wear and tear on its surface. Required LCD part number is appended below:
A1334748A... FTS BLOCK ASSY (35STMG07)
Available in Sony Parts Store for $154
If you are handy with electronics stuff repair then can replace it easily, remove side and bottom screws and take apart front and rear cabinet of camera. Unlock connector that holds lcd flexible connection wire, remove solder connection of back light source plate from lcd flexible wire, solder back light connections in new lcd flexible wire and insert it in jack on main board of camera.
Local camera repair shop will help you to replace lcd if you feel uncomfortable doing so.
Thanks.
May 19, 2010 | Sony Cyber-shot® DSC-T200 Digital Camera
I have no picture. Sound & Signal are working
It seems back light inverter board is not producing voltages to lit the back light inside lcd panel to show the picture on lcd screen.
Please replace back light inverter board to get tv fixed. Local tech will help you if you are not familiar with tv repair.
Thanks.
Apr 03, 2010 | LG 42LB4D 42 in. LCD HDTV
LCD Back light
I shows your screen is not properly touching the contacts i think those contacts need to be cleaned with acetone available at maplin or pcb cleaner from philips the assemble again it solves prob coz that contact isnt giving signal to turn light off.
Dec 16, 2009 | Cameras
LCD screen is blank (Dell Latitude C610)
I would say that it is a faulty backlight. The CCFL is a huge pain to replace on its own, but is much cheaper than replacing the whole LCD assembly, which does come with the inverter.
Apr 23, 2008 | Dell Latitude C610 Notebook
Samsung SGH-D500 Cellular Phone Logo
21 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
