Question about Bissell Carpet Cleaner Powerbrush Deep Cleaner Vacuum
Bissell Carpet Cleaner pro heat- water doesnt come out
There is no water shooting out. The brushes are going, but when i hit the trigger that releases the water, nothing happens.I've only used this 4 or five times and i tried cleaning it out, but still nothing.
  • 11 more comments
  • dlrut Aug 07, 2008
    When I press the yellow trigger, no water comes out. Please help!
  • yurok1 Aug 20, 2008
    I have the same problem. The motor runs but no water comes out. Would like to find a repair shop in rural northern Ca. or southern, Oregon
  • Anonymous Aug 20, 2008
    Won't spray water you name it i've checked it or replaced it still won't work repair shop time.
  • bjhe727 Sep 04, 2008
    trigger on handle will not dispense fluids onto floor. Used for less than 6 mos. Can't return to store. Where can i find repair shop - this is still under
    warranty.
  • smokeyd4 Sep 07, 2008
    No water or shampoo coming out. Brushes turn and have suction.
    Looking for a repair service in Las Vegas Nevada.
  • dep27rn Sep 22, 2008
    I have the same problem as mentioned about the water not coming out. However I have taken this thing apart and tried to see if anything was obviously preventing the water form coming out. I put it back together and much to my surprise, it started to work. I hauled it all the way up three flights of stairs and started to clean my rug and after about 30 secs of working fine, NOTHING. No water, No soap and No brushes turning. What can I so to fix this. I am at my wits end...................
  • Anonymous Oct 04, 2008
    When powered up, the motor goes on and everything appears to be fine but no water shoots out.
  • Anonymous Oct 11, 2008
    No water coming out so I took the four screws out and looked at the hoses for clogging. did't see anything else wrongso I put it back together and it started to work. Then let tank dry out in the sun, husband ran over it with Harley!!! Do I fix it with a new tank or find one on ebay?
  • dfraleys Nov 30, 2008
    Every thing is working fine except the sprayer.
  • iambear Dec 17, 2008
    I have the same dang problem and have cleaned all the tubing. it works fine for a minute. Then no water or soap. The upholstery or hand tool part works fine. My machine is 3 months old. used 4 times. I think Bissell made a defective machine. My old Bissell I wish I had back.
  • Anonymous Apr 29, 2009
    I have the same problem with the same machine that I have used only once. No water comes out. What a piece of junk.
  • jrbjr May 09, 2009
    water does not come out
  • Anonymous Mar 19, 2014
    used for first time,cleaned half carpet ,then wont push foreward
The screw that is located in the center of the handle, that holds the assecory hose holder must be tight. My screw was missing, put one in and cured the problem. Sounds stupid but it worked. Got this idea off the Bissell web site. Also if you have a pump belt it may need replacing.The cover is on the side of the machine. Go to the Bissell web site and look up by your model # and name of machine. There are several quick fixes that you can do yourself. Why pay for expensive repairs when the Bissell site will help you for free. Good luck.
Posted on May 06, 2009
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 4 Answers
Check the bottom of the Water Tank and the Formula Tank to make sure each has a black or red rubber gasket attached. The rubber gasket sometimes sticks to the base of the unit and detaches from the tanks. When this happens, the tanks don't seat properly.
Posted on Jun 10, 2009
I have a model #7920-P Bissell proheat pro-tech rug shampoer and floor cleaner wirth heat flow indicator, perfect pass indicator smart temp ready light upright model. The vacuum, heat, power brush perfect pass indicator all work. the flow indicator and sprayer do not function. I have cleaned all of the filters on the unit plus just about every inch of tubing on the unit.
The trigger mechanism does not seem to be applying the liquid cleaner to the front sprayers. Ther fore , the unit does not pick up any cleaner solution.
Posted on Oct 18, 2008
  • 3 Answers
If water comes out the hose but not the base then the heater is most likely blocked, the heater is located at the upper part of the machine and u can gain access to this by removing the caddy and taking out the 2 screws at the back of the machine where the caddy was
Posted on Feb 08, 2011
Were to add water
Posted on Sep 02, 2008
Would suggest that something must be wrong with lever you press to get water,could be something broken,or something worked loose.check bottom of tank,maybe something clogged.Wish you good luck.
Posted on Jun 28, 2008
Brushes don't rotate on proheat2X,
How to Replace the Belt & Brushroll on Bissell ProHeat 2X ...
? 2:11
https://www.youtube.com/watch?v=Jj_43IHz9U4
Dec 28, 2012 - Uploaded by eVacuumBags
How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... How to Replace Bissell Deep Cleaner Pump Belt orBrush Belt - Duration: 1:44. ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
Brushes Will Not Rotate Deep Clean Essential - YouTube
? 0:53
https://www.youtube.com/watch?v=gbEXY5jkWSc
Apr 9, 2015 - Uploaded by BISSELL
If your machine is turned on and in the upright position yourbrushes will not turn. ... How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
bissell pro heat 2x brushes wont spin Questions & Answers ...
www.fixya.com > Forum > Tags
... bissell pro heat pet 2x and my brushes won't turn or operate... check the belt belts ok brushes won't turn/rotate turn dial on bottom front on the water tank to ...
Feb 03, 2016 | Vacuums
I have a pro heat turbo cleaner and the water does not come out when the trigger is depressed
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will give you all the information you need to fix your Bissell Proheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
Sep 07, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
My Bissell Pro Heat 2X steam cleaner is not releasing the water
Have you tried cleaning out the small filterfrom the reserve tank? Also, check the tank/resevoir valve is operating properly, when you take it out to fill try to make water release from tank.
Apr 29, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
Bissell pro heat steam carpet cleaner, not releasing water.
That means that you need to replace the pump belt. Here is the belt you need and a manual you can view:
Bissell 7901 Belt and Manual
Mar 01, 2010 | Bissell 7901-1 ProHeat Scotchgard Upright...
Bissell Pro-heat 2x model 8920
There is probably a bad solenoid in the machine that controls the water out to the floor, you would be better off taking it to a repair place because it is a big mess of hoses and wires.
Jun 29, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
Bissell pro heat 2x multi surface carpet cleaner making spots
maybe there's not enough vacuum or it hasn't been primed enough. I have a proheat that drove me crazy till I started leaving the heat switch on. I get wads of carpet fiber that mat around brush and spit out on the carpet, so I frequently remove them. I'm just wondering if after you empty the water, it may not have built up the suction. Good luck! hope this may be helpful
Jan 13, 2009 | Bissell 1699 ProHeat Clear View Upright...
Bissell 1698 PowerSteamer ProHeat Upright will not work. The brushes spin, the soap comes out, but no water is getting to the carpet.
You may try the trigger assembly may not be releasing the water , your brushes spin and the soap comes out but no water – it may have come unhooked or broken, also the water line could be plugged, clogged or pinched and not releasing water to the brushes -- you may try the owners manual for the trouble shooting for the item or check the Bissell website listed below or the customer service phone number of 1-800-237-7691 – the website has a list of trouble shooting listed right on the website I you enter the Model number and hit trouble shooting
http://www.bissell.com/
By Phone Customer Service:
(800) 237-7691
Hours:
M-F 8:00 a.m. - 10:00 p.m. ET
Saturday 9:00 a.m. - 8:00 p.m. ET
Apr 15, 2008 | Vacuums
Bissell Carpet Cleaner Powerbrush Deep Cleaner Vacuum Logo
1,719 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
