Question about Fuji FinePix S7000 Digital Camera
Dead batteries when fully charged
Says batteries are dead even when plugged into a power source. (via USB to laptop) It is so dead that the lense won't even retract. I have new rechargable batteries that were fully charged. I have tried several sets of batteries. What do I do?
  • 3 Answers
Does it work with "no batteries" - only plugged into power source? check your usb cable by trying to power up something else.
Posted on Jul 10, 2008
Tomtom
My 2 year old TomTom gps Via 280 will suddenly not turn on
Jan 16, 2014 | Tomtom GPS
The S107 helicopter charged up successfullyfirst time using an Apple USB mains adaptor. I then tried charging it up from a computer USB and it would only partially charge with the machine turned on and the...
Is helicopter off when charging? Will not charge when powered on.
Light on charger should go off when plugged into helicopter.
Also, are you running battery dead? This will destroy a Li/Po battery. Never fully drain battery. Run only until you cannot maintain altitude. Land and power off. Cool for 10 minutes. Charge. Cool for 10 minutes. Skipping either "cool-downs" will also destroy your battery, albeit slower than the full discharge which can sometimes kill a Li/Po battery in only 1 or 2 cycles especially when they are new. Have any friends with a cell phone or laptop (Li/Po batteries also) that they hate because "it's always dying" or "the battery only lasts like 4 hours" whether or not they know why, it is ALWAYS because they rarely charge them fully, especially for the first few charges which are crucial, and the often run the things dead until they won't even turn on.
Back on topic, I use and recommend the usb power adapter. When plugged in using the USB wall adapter, does the charging light still stay on? Certainly if "yes", and still likely if "no" sadly, this to me sounds like a fried battery, which, if it, as I suspect, was caused by frequent or early full discharges and/or hot charging/flying... then you're screwed. The batteries are cheap but quite tricky to replace. Need a steady hand and a needle tipped soldering iron and solder barely thicker than hair.
Hope I've helped,
PvT
Jan 04, 2011 | SYMA Toys industrial New Syma S107 Mini...
Mv acer aspire 3623WXCi turns off when i unplug the power cord with battery attached, is the battery dead and do i need a new one?
when you plug the power cord check and see if the battery shows that its charging ,if the charge level is low allow it to charge fully ,after its fully charged remove the power cord and see if it will go of again .if it goes off then you know the battery is dead if not it might be of low charge or not properly fixed.hope this helps
Sep 17, 2009 | Acer Aspire 3623WXCi (NBACERC1500XX1) PC...
Laptop Charge troubleshoot
This can be due to a dead cell in the battery pack,Could also be the charger is going bad or shutting off prematurely.
Please rate this a fixya
Feb 13, 2009 | Sony VAIO VGN-FJ270/B Notebook
No power
Make sure you have an original OEM charger for the MDA. Many of the knock off chargers don't provide the right amperage for the device. What happens is that since the phone is completely dead, it can't regulate how many amps the battery should get during the charge and an incorrect charge current won't charge the battery. I'm guessing that someone sold you a Motorola RAZR charger or another knockoff made for the RAZR. This might charge your phone when the battery is working, but not when it's DEAD. Also you won't have luck plugging it into a computer USB cable because, again, the phone can't tell the computer what charge to send and most computers only produce <0.5 amps in the USB port.
Get a charger that states it is an OEM (original eqipment manufacturer) device or one that is specifically designed for the MDA (or Cingular 8125). eBay is full of them.
Bad charger (probably won't work for a dead battery)
Good Charger (correct amperage and designated for the MDA)
Jul 08, 2008 | T-Mobile MDA
Garmin c530 Streetpilot
I just called tech support at 1-800-800-1020 and I was told that the battery on the unit may be so low that it won't power on even with a power source. The unit actually uses more power than it's taking in from the car charger. I was told to plug it into the computer using the USB cable and give it a few hours to replenish the battery. Apparently it should be plugged into the computer ever so often to keep the battery from getting too low.
May 09, 2008 | Garmin StreetPilot c530 GPS Receiver
Battery and software question
You need to have a battery pack inserted in the camera even if you are using computer USB power for webcam use. If your battery is dead, then you are out of luck. Browse battery problem section for my solution to dead battery of this camera.
Nov 03, 2007 | CHE-EZ v:u Digital Camera
Fuji FinePix S7000 Digital Camera Logo
135 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Fuji Camera Expert? Answer questions, earn points and help others
