Question about Smeg FAB28
Smeg fridge i tured my fridge off to do some cleaning ,for about 15 minutes and then i turned it back on again but now the compressor has failed to start upabout 3 hrs . the compressor is quite warm to the touch.
    Genius:
  • 1,122 Answers
Did you unplug it or turn the thermostat off?let me know-mike
Posted on Jun 28, 2008
My GE Profile Refrigerator (model PDS20MBSBB) is making a clicking noise. The thermostat display turns off while this happens. When it comes back on the fridge gets really cold and then slowly gets
needs new control board wr55x10942. condensing fan not running or running slow. it get to hot then the compressor relay cut off compressor to protect it once cooled down enough it starts back running.
Oct 09, 2014 | GE Refrigerators
Smeg FAB28QRI thermostat not restarting fridge unless I hit side of fridge! Do I need a new thermostat?
It could be a loose wire on the terminal of the compressor. Also check for loose wires on the thermostat. If that is ok, the thermostat could be bad because it is a temperature controlled switch that turns the compressor on or off.
Jun 14, 2014 | Smeg FAB28QR1 Retro Fridge with Freezer...
Smeg CR330SE fridge/freezer hi there fridge freezer has stopped cooling in both compartments. light still comes on in the fridge and the compresser at the back is very hot.... any ideas???
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 01, 2011 | Smeg CR330SE 1 Bottom Freezer Refrigerator
Ice forming in the top freezer, leaks in the bottom refrigerator section
Sounds like the defrost circuit of your fridge has failed. If you remove the back panel of the freezer compartment, you will see the evap coil encased with ice. Normally the defrost circuit will turn off the compressor and turn on a heater to warm the coil to about 45 degrees to melt any frost build up. After about 40 minutes the compressor will kick back in to keep your fridge cool again.
The typical failures are that the defrost heater burns out. If you have an older fridge, the defrost timer fails to advance, causing the fridge to stay in cooling or defrost mode.
May 27, 2011 | Kenmore 18.2 cu. ft. Top Freezer...
Fridge/Freezer
Probably be cheaper to get new one, it has probably had the compressor fail or a leak in the cooling system.
Sep 16, 2017 | Smeg FR148A Refrigerator
First gathered water at the bottom, thought that is was due to something touching the back. Stopped fridge, cleaned it, started it again. Light on but no familiar noice of the engine starting again. Engine...
Don't know the model/brand off the top of my head...
But: If the compressor is warm/hot, but nothing is happening, I ask this:
Even if the fridge is not cooling, is the compressor running, or dead silent?
If silent, but warm, do you hear a "Click" every so often ? Maybe 3 to 5 minutes apart, followed shortly by a 2nd click ?
If so, most likely the compressor has seized, and this is the over-current trip acting (thermal, so it needs time to cool).
Big problem if it is the compressor (expensive).
The only other thing that might cause a similar occurrence, would be if the compressor has a Start capacitor. If this has died, the compressor will not turn - just sit there getting warmer, as the over-current trip acts.
If it was a dead thermostat, the compressor wouldn't get power, and would be cold.
Dec 12, 2009 | Smeg Refrigerators
The fridge/freezer is making buzzing noises that go on for 10/15 seconds every 5 minutes or so. Both fridge and freezer have heated up to 49 and 26 degrees through the night. Help!
ur compressor is trying to start but the safety is turning it off may have a bad compressor but try this first might get it working again -(safety click sound) disconnects power when compressor gets to hot or is drawing to many amps--stuck--comp gets hot unplug unit and clean with a vacuum carefully under where comp and fan are this is the condenser area after cleaning or 1 hr plug in and check for start and that condenser fan is working may be reason for overheating-if still not working compressor needs service
Nov 04, 2009 | Maytag Freezers
I have a 2 year old SMEG FAB 32 Fridge/Freezer and the freezer section has suddenly lost temperature. Upper frdige section is fine but freezer not. I have emptied, kept door shut, turned dial up but no...
I have a 2 year old SMEG FAB 32 Fridge/Freezer and the freezer section has suddenly lost temperature. Upper fridge section is fine but freezer not. I have emptied, kept door shut, turned dial up but no success.
Any suggestions on what the problem might be?
Wouldn't expect problems on a SMEG just 2 years old.
You could have a bad thermostat or the refrigerator could be low on Freon, make sure you clean off the exposed coils on the back of the fridge and underneath to free it from dust and dirt – use some type of a blower for underneath and the coils you can vacuum off or wipe off the coils, if not call a service tech to have a look @ the refrigerator – it might have a bad compressor
Apr 14, 2008 | Refrigerators
Every 2 mins the compressor tries to go on and after 15 seconds stops.
If the compressor tries to go on every two minutes, then the relay is functioning.
1. If the compressor has failed, it might be getting hot and tripping the thermal overload to shut itself down. It will cycle like you say and will be unable to cool the fridge.
2.It's also possible that you have lost refrigerant from the system. When the compressor goes on, the pressure drops below a threshold value. The system sees that there is not enough pressure, and shuts down. Once the pressure rebuilds, it tries again.
3. If the fins in the rear of the fridge are clogged with dust/debris, the system will not be efficient enough to cool. I doubt this is the case as the compressor would generally just stay on for a long time... longer than 2 minutes.
Try turning the thermostat to the coldest setting possible for both the fridge and the freezer. If the unit still cycles off after 2 minutes, consider repair.
Mar 14, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Freezer problems
remove back panel of freezer. check if there is excessive ice build-up preventing air flow. if there is, then defrost carefully with a hairdryer (with appliance switched off) if no ice or frosting on pipework, check if compressor is running. if it is or hot to the touch or clicking, then you have a compressor fault and replacement is not diy. if compressor not running, then probably module fault
Apr 15, 2007 | Smeg FAB32 Bottom Freezer Refrigerator
Smeg FAB28 Logo
331 people viewed this question
Top Smeg Refrigerators Experts
John Tripp
John Tripp
Michael Galve
Michael Galve
ashburton
Are you a Smeg Refrigerator Expert? Answer questions, earn points and help others
