Top load washer will not spin or drain
Please help washer will not pump or drain
  • Anonymous Jul 07, 2008
    I have the same problem, mine is a kenmore model top load
    Genius:
  • 1,122 Answers
What brand of machine
Posted on Jul 01, 2008
Help my washer wont spin
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 13, 2011 | Maytag PAV2300 Top Load Washer
Hi there, my washing machine will not spin dry and the machine wont empty, i have tryed turning it off at the wall and nothing! please help
heatman101
Jun 30, 2011 | Fisher and Paykel IWL12 Top Load Washer
Dose not spin oll the water out. jpnixsr@yahoo.com
Hi
If the lid switch is fine and the washer will spin fine then the issue is with the drain pump, something is either stuck inside or the drain pump is bad and should be replaced. Please check this video for cleaning/replacing your washer drain pump assembly:
Hope this helps...please post back for further assistance.
Daniel
May 04, 2011 | Roper RAX4232KQ Top Load Washer
Washer fills with water but does not spin or drain.
heatman101
Apr 03, 2011 | Washing Machines
Washer won't drain or spin. pump not clogged. I hear ticking on back panel electric control box
heatman101
Mar 20, 2011 | Kenmore 2203x Top Load Washer
The washer isn't draining and spinning. Washer has message coming up- OE and it stops working. We were thinking it was the water pump? Please help.
heatman101
Oct 12, 2010 | LG WM1812C Front Load Washer
This was will go through the whole wash cycle until it come to spin the clothes out then it will just stop it will not ring the close out. What can be the problem?? Please help me so that I don't have to...
heatman101
Sep 30, 2010 | Maytag Legacy MAV208DAWW Top Load Washer
My kenmore top load washer works well, however when the spin cycle runs...the water drains but the clothes are still soaked. It sounds like it is spinning (but Im not sure if it actually is) and there is...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Sep 01, 2010 | Kenmore 24032\24036 Top Load Washer
Washer will nor drain or spin.
Lil, start by checking the drain pump. Remove the front panel by pushing in on the clips on the left and right side just below the top. The panel will pull toward you. You will see the pump on the right. Start the washer in spin and with a meter see if you have 120V to the drain pump. If you do and its not draining, you have a bad pump. Part number for the pump is WH23X10013. Catriver..post back.
Oct 19, 2006 | GE WDSR2080D Top Load Washer
Washing Machines Logo
35 people viewed this question
Top Washing Machines Experts
