Question about Refrigerators
I have a fridgedaire refrigerator that isn't cooling in the fridge section but works well in the freezer. The model number is FRT1583AW6
  • tsliger Mar 26, 2009
    the back wall of the freezer is covered in frost and is always running. The refridgerator (bottom) is not cooling at all.
    Genius:
  • 1,122 Answers
First check to see if freezer fan is running,then check to see if there is frost on back wall,then check to see if the duct going to the freezer has iced up.let me know-mike
Posted on Jun 28, 2008
I had ge refrigerator and the fridge is not cooling well
For starters a year and model number would be helpful. Do you have turn dials to contol temp of freezer and fridge or electonic pushbuttons? The fridges with manual rotating dials use a "dampner" between the freezer and fridge section. In short the freezer evap fan blows air in the freezer but also has a passage from the freezer to the fridge section which aloows a controled amount of air from the feezer section to cool the fridge section. IThis passage may be obstructed by ice build up or some other blockage. Units prior to 2002 are not controled by circuit boards and the ones after 2002 are. For more specific help give me the GE fridge model please.
Sep 24, 2012 | GE Refrigerators
I have a Dometic fridge model number RM2612 in a camper that i just purchased used and the fridge isn't cooling. The freezer section seems to be okay. The metal plate in the freezer gets cold but
Make sure it is level, has proper airflow out through top vent. Also check baffle, or stack where flame sits under and blow it out good with compressed air to make sure it's clean. If you smell a hint or strong smell of ammonia, shut it off, it has a leak in cooling unit. If all ok in that area, shut it off, disconnect and plug propane line, disconnect power and remove the fridge. Turn the fridge upside down for a day or 2, then re-install and let it sit 24 hrs before turning it back on. Quite often that will take care of any blockage in flow of cooling liquid, and get things back to normal if cooling unit is still good.
May 22, 2012 | Dometic RM2620 Refrigerator
Freezer side seems to work but the refrigerator side isn't
Its defrost problem, the freezer should cool, then freeze, then defrost cycle should start. In your case freezer is cooling, then freezing, but its not defrosting. That's why fridge section is not cooling.-------
Click this link below and follow the troubleshooting:----
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
This will help.Thanks.Helpmech/.
Sep 11, 2011 | Maytag Refrigerators
I have a sharp refrigerator - freezer. SJ-48L-SL1 The freezer is colding but the refrigerator section isn't.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jul 26, 2011 | Refrigerators
Freezer appears to be working, but not the refrigerator section - at most that will only get to 50 degrees. Manually switching to propane makes no difference.
Sounds like your cooling fan is out. If the freezer is fine and the fridge isn't, then the cooling fan isn't blowing the cold air the the fridge. Or you could have ice obstructing the airflow.
Jul 01, 2011 | Refrigerators
I have an older side by side GE refridgerator model number TFXC222J. The freezer section is working but the fridge side is not cooling. light works.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 16, 2011 | GE Refrigerators
Top half of fridge and freezer are not working
I need that model number of the Frigidaire refrigerator so I will able to help you better. Thanks, Sea Breeze Here is my email should you not be able to contact me. seabreezehvac@yahoo.com
Apr 21, 2009 | Refrigerators
Amana BX22A2W - freezer works, fridge not cooling
Check the damper in the top back of the fresh food section. make sure that it is open and air is coming through it.
Oct 29, 2008 | Amana ABB2227DE Bottom Freezer...
Fridgedaire side by side fan working, compressor hot, refridgerator and freezer not cooling
def sounds like a compressor issue/ sealed system issue, hopefully under 5 years old and you still have coverage
Oct 27, 2008 | Kenmore 50522 / 50524 Side by Side...
FRIDGE NOT WORKING
Most side by side and other models of refrigerator freezer combinations are of one basic design. The freezer section does the cooling for both compartments. The refrigerator section gets it cold air from the freezer compartment. Therefore check for frost on the back wall of the freezer compartment. If frost is present there you have a defrost problem and it is cutting off the air that cools the refrigerator section.
I think this problem may already be resolved in some manor because of the date of post. Posts should expire after an unreasonable time period.
Mar 19, 2008 | Smeg FA561X Side by Side Refrigerator
Refrigerators Logo
94 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
