Question about Fisher and Paykel Active Smart E522B Bottom Freezer Refrigerator
Fridge freezer keeps beeping - Fisher and Paykel Active Smart E522B Bottom Freezer Refrigerator
  • 2 more comments
  • Anonymous Sep 12, 2008
    It emits a high pitch beep and runs constantly
  • enancarrow Nov 18, 2008
    freezer has an alarm that beeps & we dont know how to turn it off
  • mj_britton Dec 19, 2008
    I have a KitchenAid KCS25INS01 side-by-side counter depth refrigerator that keeps beeping. There are three consecutive short beeps that are heard 3-10 minutes apart from one another. There's no consistency to the timing between beeps. Sometimes the fridge will go on for hours without beeping. Once the beeping starts, all internal dome lights and digital displays go out.
    What stops the unit from beeping is either opening the door several times and closing it, turning off the fridge with the hard buttons inside the fridge and waiting 10-20 seconds before turning it back on, or unplugging the fridge for a few minutes and plugging it back in. This only stops the problem for a few hours if we're lucky. Once the beeping has stopped, the internal dome and digital displays come back on again.
    The concern is that the unit is beeping because the temperature inside the fridge has reached an unsafe level. This is not what I expected for an 18-month old fridge that cost me $2800.
  • dcoates1 May 27, 2010
    I have a hotpoint fridge freezer model ff175bp and it keeps beeping what can i do
I think I may have the solution, after having suffered through the same problem for months. I have a Kenmore Elite side-by-side which is really the same as KitchenAid and Whirlpool. Having thought of complicated solutions first, I have finally gotten back to step 1, simple solution. Tape the switch on the top of the freezer compartment and see if that works for you. I believe the door while seemingly closed is not pushing the switch in far enough. If that works for you, you can probably glue something to the top of freezer door so it can push in the door switch a little better. The reason that it beeps is that the switch is not pushed in enough and the light is still on inside while the door is closed. The refrigerator then thinks the door is still open. I really hope this works for you as I can sympathize with you having listened to the beeps for months. I feel sorry for people who have changed one circuit board after another to no avail. And there are so many stupid repairmen out there offering dumb advices and perform needless repairs.
Posted on Jul 16, 2009
  • maofun Jul 16, 2009
3 Suggested Answers
watugot
  • 290 Answers
SOURCE: Freezer keeps beeping and switching off
Next time this happens unplug it for about 10 minutes. When you plug it back up you should be able to turn it back on normally. This resets the board, much like restarting your computer. If the problem happens again, you will probably have to replace the board. You also want to make sure you have a good ground on the circuit and a steady power supply without too much fluctuation. Hope this helps.
Posted on Oct 07, 2007
  • 117 Answers
SOURCE: SAMSUNG SR L3928B FRIDGE/FREEZER KEEPS
samsung fridge freezer problem">
Posted on Jan 16, 2011
Zanussi zenb9950si
What is the beep for ? Temperature sensor ? Power sensor ? Door open sensor ?
Oct 30, 2013 | Zanussi & Electrolux Fridge Freezer Handle...
FRIG KEEPS BEEPING BUT DOORS R CLOSED TIGHT
Not knowing the make and model of your fridge, I would suggest reseting the fridge and freezer temperature settings, inside your fridge. With some fridges like Fisher & Paykel, when the power is cut to the fridge, it will beep until you select the temperature level inside the fridge.
Failing that, a constant beep is a warning code to alert that a fridge component has failed.
Ash
Sep 11, 2011 | Refrigerators
Fridge is making a beeping sound. The digital indicator for fridge area is saying Hi
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jul 17, 2011 | Frigidaire FRS3R5EMB Side by Side...
Frigidaire alarm for fridge keeps beeping
I would try switching the breaker. That will probably work.
May 15, 2017 | Frigidaire 22.5 Cu. Ft. Counter-Depth...
Bosch Fridge Freezer KGU3200GB/01 alarm beeping temp rising
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Jan 26, 2010 | Freezers
Westinghouse fridge freezer alarms keep going off
Try a different web site, where are the solutions on this one????? Great site..... not
Dec 30, 2009 | Freezers
Fisher & Paykel active smart fridge keeps beeping for no apparent reason, while door closed
press the select button ( the button that you choose the temperature on the fridge and freezer) and check that the fan on both fridge and freezer are working.
Nov 04, 2009 | Fisher and Paykel Active Smart® E522BR...
Freezer not working on ariston fridge freezer 2 orange lights on top of fridge keep beeping every two hours causing fridge not to work is there a reset button
freezer not working on ariston... Solve freezer not working on ariston fridge freezer 2 orange lights on top of fridge keep beeping every... (More) freezer not working on ariston fridge freezer 2 orange lights on top of fridge keep beeping every two hours causing fridge not to work is there a reset button
Sep 13, 2009 | Freezers
AEG SANTO 3790-6 KG
hi i have got a fridgefreezer and it keeps beeping and also inside my fridge is warm but my freezer is ok what could this be
Dec 11, 2007 | AEG Refrigerators
Fisher and Paykel Active Smart E522B Bottom Freezer Refrigerator Logo
2,413 people viewed this question
Top Fisher and Paykel Refrigerators Experts
Brian Coughlan
Charles T Nevin
Charles T Nevin
Are you a Fisher and Paykel Refrigerator Expert? Answer questions, earn points and help others
