Question about Haier HLF11P 6 cu.ft. top load washer / dryer
Haier HLF11P won't start
It turns on and has power. cycle lights illuminate. but when I hit start the cycle lights just flash, it doesn't start
    Genius:
  • 1,122 Answers
Check the door switch ,also unplug it for a minute and see if it resets itseft,mike
Posted on Jun 28, 2008
Washing machine wont go
There is not enough info for me to help much. Be sure you have power coming to the electric receptacle. Plug something else in it to see of it works. If the machine is old, consider getting a new one. Other choice, call a repairman. I know you didn't want to hear that but sometime that is the only choice. Ask them what the service call would cost before they come.
May 14, 2015 | Haier HLF11P 6 cu.ft. top load washer /...
Why does check engine light blink when I accelerate?
Hi Ced ,
The malfunction indicator lamp (MIL) is located in the instrument panel cluster. The MIL will display as either SERVICE ENGINE SOON or one of the following symbols when commanded ON:
Check engine ! The MIL indicates that an emissions related fault has occurred and vehicle service is required.
The following is a list of the modes of operation for the MIL:
The MIL illuminates when the ignition is turned ON, with the engine OFF. This is a bulb test to ensure the MIL is able to illuminate.
The MIL turns OFF after the engine is started if a diagnostic fault is not present.
The MIL remains illuminated after the engine is started if the control module detects a fault. A diagnostic trouble code (DTC) is stored any time the control module illuminates the MIL due to an emissions related fault. The MIL turns OFF after three consecutive ignition cycles in which a Test Passed has been reported for the diagnostic test that originally caused the MIL to illuminate.
The MIL flashes if the control module detects a misfire condition which could damage the catalytic converter.
When the MIL is illuminated and the engine stalls, the MIL will remain illuminated as long as the ignition is ON.
When the MIL is not illuminated and the engine stalls, the MIL will not illuminate until the ignition is cycled OFF and then ON.
Trip
Mar 13, 2015 | 2003 Chevrolet Impala
Power available, but won,t start cycle
I would start by checking the door handle micro-switch.
If it cannot sense that the door is closed, the cycle will not start.
These switches are in a dodgy position in the door allowing them to get wet and corrode out.
Mar 23, 2014 | Haier DW12PFE2U Dishwasher
2006 Mercury Montego won't start. Not battery related, but just as it turns over and seems like it is going to start, it doesn't. Also, the check engine light stays illuminated. I don't know what to t
I have a Montero and it won't start with the key in the engine compartment but it will only start using my key pad what should I do i did just get another battery the other day could that be the problem
Dec 27, 2011 | 2006 Mercury Montego
I can't get the control panel to reset. The wash cycle light comes on but it just beeps and the dishwasher won't start. I press the start button and it stops beeping for a minute but it still...
II might need the actual model number. However, you can go to page 9 on this manual and check if the flashing options can fix the problem. I am assuming you have already tried to turn the power off and back on.
The ohter thing to try is the reset sequence. Within 6-7 secs press High Temp/ Heat Dry/ High Temp/ Heat Dry/ High Temp/ Heat Dry. All lights should light up, press Start button to exit.
Jun 24, 2011 | GE Nautilus 24" Built-in Dishwasher
Want to disable the alarm
To Set the Cycle Completion Signal Tone Level
• With the "CLEAN" and "SANITIZED" and "RINSE AGENT" Indicator
Lights flashing.
• Press the "Tone Level.
• As you press the "Indicator Lights illuminating and the Cycle Completion Signal
Tone level changing.
o If none of the Wash Cycle Indicator Lights are illuminated,
there will be no tone. The Cycle Completion Signal is turned
off.
o If one of the Wash Cycle Indicator Lights are illuminated,
there will be a low Cycle Completion Signal Tone Level.
o If two of the Wash Cycle Indicator Lights are illuminated,
there will be a medium Cycle Completion Signal Tone Level.
o If three of the Wash Cycle Indicator Lights are illuminated, you
will be at the maximum Cycle Completion Signal Tone Level.
• Press "START" to save your settings.
Dec 16, 2010 | Bosch SHX3AM05SS Stainless Steel 24 in....
My Haier Dryer Model #HLF11P will not heat at all and it will not stop tumbling.
http://www.diylife.com/2008/01/28/fixing-a-clothes-dryer-that-wont-dry/
Oct 17, 2010 | Haier GDZ5-1 Electric Dryer
My Haier waching machine has a slow spin cycle
I have the same problem with the same washer
Jan 26, 2010 | Haier Washing Machines
Hi my haier washing machine does not take water into softner compartment of draw but does take in water. would appreciate any help thanks.
Could be faulty fill solonoid valve coil/ has 2 coils one for cold rinse water other for softner. could also be dirty soap tray of course..Good luckl
Oct 24, 2009 | Haier HLF11P 6 cu.ft. top load washer /...
Won't start
you can also check you breaker, sometimes only one side of a 220v breaker will trip and the machine will still seem to have power but it does not have the full 220v. worth a try, turn your breaker off and then back on.
Jun 28, 2008 | Haier HLF11P 6 cu.ft. top load washer /...
Haier HLF11P 6 cu.ft. top load washer / dryer Logo
233 people viewed this question
Top Haier Washing Machines Experts
Gerry Harvey
Gerry Harvey
Owen Barnes
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
