Question about Whirlpool GGQ8831L Gas Dryer
Gas dryer runs for 3 mins and then no more hot air
I have a whirlpool dryer (gas) LFG7648KQ0; When I first turn it on the glow plug glows, flame ignites, hot air flows and it runs for approx 3m... The flame then goes out. Every minute afterward the glow plug goes "red" and then goes out (nothing lights)... If I let it sit and rest (cool-off) it then repeats the step's explained above... I've cleaned the lint and see that there is excellent air flow... Suggestions? thanks
  • mjm_III1 Jun 28, 2008
    After doing some further research this is what I'm noticing
    Dryer rusn fine for approx 3min (plenty of heat, flame visible, etc).
    Flame goes out. After approx. 2 minutes, the igniter glows hot, but no flame. Igniter goes out.
    Wait approx one minute, after which igniter glows again. Still no flame; igniter goes out.
    I watched the 'igniter glows, no flames.. this continues to the cow's come home...
    I'm thinking it's the coils--- But I"m no expert...
  • mjm_III1 Jun 29, 2008
    Yesterday I purchased a Gas Valve Solenoid Coil Kit. Replaced it and it's working again. For those of you not familiar with Dryers this is what I did;
    Took the top of the dryer in order to get to the front. You do this by taking off the two screws in the lint collection tray and using a puddy knife near the front and working it open. Unscrew the two bolts in the inside of the front and pull off the front (watch out for the drum, you will need to support it). The Selenoid is write in front and rather easy to change out...
    Remember to make sure you have the machine unplugged.
    Total job was about 15mins
    Good Luck---
Mjm_III1,I have the same problem and did what you did (replacing the gas valve solenoid coil). My problem is history.
Cheers!
Posted on Aug 27, 2008
Igniter starts to glow for 3-5 sec while making noise every minute or so
Check the thermocouple it is going bad or already has and that is why the gas valve is not staying open.
Jul 08, 2017 | Whirlpool GGW9200L Gas Dryer
I have an Amana Dryer Model # LGD20AW and when the dryer is first turned on the glow plug will heat up and ignite the gas but as the dry cycle continues the glow plug will heat up but no flame will ignite...
The glow coil or glow bar heats up and a sensor on the side reacts to the heat and then sends a signal to a gas valve.(solenoid valve) When the gas doesn't ignite when the coil is glowing... here are some reasons. 1. The sensor on the side of the burner assembly isn't working or sending power to the valve. 2. The valve is getting power but not opening. 3. The ignitor is not glowing hot enough to activate the flame sensor. Usually it is the sensor or the igniter not the valve.
Tom
Aug 10, 2010 | Amana Dryers
Hi i have a whirlpool gas dryer LGR8648LWO and
If your ignitor (glow bar) is glowing that indicates the thermal fuse is okay.
With the symptoms you are describing it is acting more like an air flow issue than a component failure. Make sure your door seal is good, your venting is connected properly and try it again. I would not install the thermal fuse.
Apr 23, 2010 | Whirlpool Dryers
Whirlpool gas dryer Model #WGD5530SQ0 not heating properly
If your dryer heats when you first turn it on and after a few minutes it does'nt. check the ignitor to see if it is glowing. It should glow bright then you will hear a click and the burner will light. If the ignitor glows bright but you hear a click but no flame and if you watch this for several minutes and this process continues of glow then glow goes out no flame, then you have a bad burner coil. There are 2 black solenoids sitting on top of gas valve. One of them is shorting out after it warms up. Replace both solenoids. You can usually get them as a kit from parts store.
Feb 04, 2010 | Dryers
My gas dryer is not heating up I checked to see if any flames is on when its running but its not coming on the timer is turning.what needs to change
All gas dryers have a gas module. The older models (very old) have a pilot light and the new ones have what is called a GLOW PLUG and it is made out of ceramic. If this glow plug is in any way broken, you will not have any heat. The GLOW PLUG is what comes on when you first turn the dryer on and it GLOWS until the gas module actually spits out a small amount of gas and an internal combustion occurs and the flames come on full power and this is what dries your clothes. If the GLOW PLUG is fine, then the gas module could be bad. ALSO, Always check for burnt wires and check any thermostats or fuses internally in the unit.
Nov 16, 2009 | Whirlpool Dryers
Glow igniter shuts down when dryer calls for gas
The very noisy part is a little bit odd...
Usually the igniter glows, the flame sensor detects the glow and sends power to the valve coils, which open the gas valve. There are some differences in that setup depending on the brand, but that is basically it.
It could be that the igniter isn't glowing hot enough (doubtful) or that the flame sensor (the rectangle thing on the side of the burner tube) isn't working (also unlikely, but still possible) or that the gas coils aren't working. Gas coils are the most common problem to go wrong on gas dryers, but when they go, they usually work at first, and then start to fail.
Do you have a volt/ohm meter?
Nov 14, 2009 | Whirlpool LGR4634J Gas Dryer
Series 80 gas dryer. Turn on and flame only lasts few mins.
Intermittent contact inside one of the gas valve coils. Replace. Part number 279834.
You can order them at AP Wagner. Use coupon "New10" for 10% off
Oct 16, 2009 | Kenmore 75944 Gas Dryer
Whirlpool gas dryer "ultimate Care 2" does not dry my clothes.
yes, the gs coil is not opening. Go to www.repairclinic.com put the model number in and get the gas valve.
Aug 31, 2009 | Whirlpool LGB6300 Gas Dryer
My kenmore gas dryer turns on and lights runs about five mins. hot and then starts blowing cold air and ignitor keeps glowing on and off but wont light flame
see if the thermal bulb is located in the path of the flame, and if it is you will have to change the gas thermal sensing bulb.
Aug 14, 2009 | Kenmore Dryers
Our whirpoolgas dryer is not hot.We changed the
when you start you dryer and it got hot little bit and then won't got hot again? if yes then you may need new flame sensor..or if you can see your dryer igniter turn on your dryer and watch..you heard click sound then igniter will glow then one more click sound and should see flame..ok watch for 10 min..if after click sound igniter glow and other click flame will not apper then you need new gas valve..good luck..let me know it help or not...thanks..
Jun 21, 2009 | Whirlpool LER4634J Electric Dryer
Whirlpool GGQ8831L Gas Dryer Logo
218 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
