Question about Roper RES7646KQ Electric Dryer
Dryer stopped why did my dryer just stop. it was working just fine
  • catawba Aug 31, 2008
    Dryer stopped, Have power at plug, have power from start button to timer. have power to the motor plug in and the drive motor thermal fuse has continuity. Is the problem a bad motor or the drive motor switching block that the plug goes into at the drive motor? remember the thermal fuse on the black block on the motor has continuity and all other fuses have continuity. I have bypassed the door switch and have power to the 5 prong plug at that black block but no operation of the motor.
  • 525 Answers
This link, http://www.repairclinic.com/SmartSearch/SmartSearch.aspx, provides exploded view imagery, belt routing diagrams, parts imagery and function, parts ordering and shipping information, error code details, just about anything you need to get your appliance up and running again. Just follow the links to navigate through the site.
You will need to enter the model number stamped on the manufacturers product information data tag, located on the unit, and not in the User’s Manual. to access your product information.
Here are some common solutions to help resolve the issue with your appliance.
Clicking on the underlined links will take you directly to that page.
If your dryer doesn't work at all, or just stopped working, it could be because of problems with:
Power from the house
Door switch
Thermal fuse
Wiring
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker.
Door switch If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch.
Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Wiring Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
For parts or diagrams, follow this link:
http://www.repairclinic.com/0003.asp
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jul 11, 2008
How do I fix dryer that stopped working?
Check the little button that the door pushes in when you close the door (door switch).
May 01, 2014 | Bosch Axxis WTL 5410 Electric Dryer
Turn table stops turning, then motor shuts off
George A Faria,
I understand that the turntable stops turning and then the motor shuts off. I also see that you're stating the appliance works fine without the belt on it. My suggestion would be not to run the dryer without the belt. This can cause wear on the motor itself. What I would suggest is to put the belt back on. If it still stops turning and the motor is shutting off, I suggest contacting either the manufacturer or a local authorized technician. This way the root of the issue will be found and your dryer will last longer.
-Best Regards-
Jan 15, 2014 | Frigidaire GLEQ2152ES Electric Dryer
Yes my dryer just stopped working .. Was working fine then just stopped..
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Jan 28, 2011 | Maytag Dryers
Dryer stops but the timer continues on
Fixed! The "push to start" button was stuck. Must have been some dust. I pushed the knob a few times and that's all it took. Works fine now.
Dec 12, 2009 | Kenmore Dryers
Dryers stopped working during cycle
My dryer stopped working during a cycle last night and won't start again. The light is no longer coming on either. The first thing I checked was the circuit breaker which was fine. Can anyone tell me other possibilities? What is the anser
Jul 17, 2009 | Magic Chef CYE4000AWW Electric Dryer
Dryer will stop about 10 to 15 minutes into heat cycle.
HI, The timer mech is malfunctioning. i would replace this defective timer mechanism asap.
Jun 20, 2009 | Kenmore Dryers
My electric dryer won't run
99c99e1.jpgThis dude mounts on the heater housing, if it is open the dryer will NOT run. It blows when the vent is stopped up.
Dec 31, 2008 | Dryers
Maytag Dryer Working Fine Stops Working
Take off the top of the dryer and you will find somewhere near or at the drum a fuse. Try bypassing it first to see if it works. If so, go get one for about $10.00. There may be a wire that has burned off at the connection in the back of the dryer also.
Oct 18, 2008 | Maytag PYE2300AY Electric Dryer
Kenmore dryer stopped working, start button does nothing
need the model # from the unit should be where the door closes to the CYE4000AWW is not a Kenmore Model
Jan 21, 2008 | Magic Chef CYE4000AWW Electric Dryer
Roper RES7646KQ Electric Dryer Logo
151 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Roper Dryer Expert? Answer questions, earn points and help others
