Symphonic SR90VE Logo
Posted on Dec 07, 2010
I have a SR90VE recorder, when I insert a blank DVD or DVD RW I get error E24 - disk is not recordable, HEEEEEEEEELP!!!
5 Related Answers
A
Anonymous
  • Posted on Jun 02, 2007
SOURCE: Emerson DVD Recorder EWR20V
The problem is likely that you are using 8x/2x media. Though the booklet does not say it, the burner does not support anything above 4x for DVD-R and 1x for DVD-RW. Calling their tech support can (possibly) get an update for this problem. Otherwise, the burner cannot use anything but outdated media.
Anonymous
  • Posted on Jul 01, 2007
SOURCE: DVD Recorder Does Not Record
It took about 45 minutes, without a manual. Carefully disconnecting all cables and marking them so the would go back in the right place later. Carefully Disassembling the unit, removing the cover - 6 screws, noting all screws and where they came from, pulling the front panel using the plastic tabs, removing the top front edge cover - two screws, removing the disk assembly - 4 screws, pulling the two thin leads so I could pull the entire assembly out. Removing the back plastic cover from the DVD assembly and identifying the Optical Disc Lense. Spraying some LENSE CLEANER on the same cloth that I clean my glasses with, and carefully wiping across - gentle stroke in same direction, then opposite direction - a few times. Spray lense cleaner on the cloth not on the lense. Reassemble. Reverse order of above. Works great now. BEST OF LUCK....Or you can find almost any DVD repair facility. This is not a unique process. Robert
Anonymous
  • 4402 Answers
  • Posted on Jan 24, 2008
SOURCE: dvd recorder won't record
I would try cleaning the laser first!
http://www.ehow.com/how_2036275_clean-lens-dvd.html
if that doesn't work try another brand of dvd's
if still doesn't work i would think the laser is weak.
aewins
  • Posted on Apr 19, 2008
SOURCE: Recording problem with LG RH266 Recorder..
Just bought unit. Had same problem.Tried lots of different types of disks with no luck. Tried to play already written +R disk. Worked OK. Then took out and replaced with blank -R. Came up with new screen asking me if I wanted to initialize disk. Answered yes and it took about 20 seconds. Then tried to DUB from HDD to DVD again. This time it came up with the dubbing menu, I hadn't seen before, and worked.
Hardly ideal, but the trick was to get it to recognise it as a blank and initialize. Currently burning my first disk. Didnt realise about 'FAST' mode, so taking ages.
Anonymous
  • Posted on Apr 22, 2008
SOURCE: Problem dubbing VCR - DVD
I have 3 of these machines. I do not think it likes theRW disc's. Two of my machines are 4X & one is 8X. I have very great success with 4X DVD-R & 8X DVD-R disc's. I hear they have a fix for upgrading to 8X speed. Here is the link with the information:
http://www.videohelp.com/dvdplayers/symphonic-sr90ve/4861
You can still buy the 8X speed disc's on the internet. Hope you can get the machine to work, because I love the ones I have.
Error E24 when trying to record on symphonic vhs/dvd recorder have tried multiple brands of disc using dvd-r like directions say....arg
My BBK DW9937S dead too. But I changed its DVDWriter to NEC5170 (and now I've got an DW9938 because I can burn even DVD-R/RW disks too).
As I mentioned above almost any combo VHS/DVDwriter has the IDE DVDRW inside (I hope you guess how to fix it)
4answers
1helpful
7answers
FUNAI SV2000 WV10D6 DVD recorder Recording errors on new DVD +RW discs
HI,
You can try cleaning the dvd lens with a commercialy available cd/dvd cleaner.
8helpful
3answers
Won't record and never has. get disk error e24
Anyone know where I could get a free download for a Emerson Dvd/vcr combo firmware upgrade??? (Ewr20v4) I need it right away . Emerson will charge to mail me one.
1helpful
2answers
CD/DVD will not burn DVD
Did you tell CDBurnerXP that you want to burn a CD? or to burn a DVD?
Does this happen with _EVERY_ "blank" disk that you insert, or just one disk?
Can your DVD-RW _read_ a previously-recorded CD? DVD?
If not, then that hardware is suspect.
2helpful
2answers
Recording error
Refer to your user manual for error codes and troubleshooting tips.
If you cant find the error code then please kindly forward the following:
Disk Type:
Recording Device:
Hardeware Specifications:
1helpful
Will not record dvd's
There are different kinds of DVD recorders and different kinds of recordable DVD disks.   Your disk must match the format of your recorder.  (eg DVD -rw, dvd -r, dvd +rw, dvd +r).  Look on the front panel of the emerson recorder and see what emblems are printed on it.  Your dvd must match the kind.  Also, if a dvd is of the -r or +r variety and has been finalized you cannot overwrite/rewrite to it.  (From a quick web search it appears your dvd uses dvd -r.)
2answers
Dvd do not record
The unit is saying that its an "Un-format disc" problem. Is this the only error code you are getting? Also, what types of DVDs are being used? As in, DVD-R DVD-RW DVD+R DVD-RW and what speeds? 1x 2x 4x 8x 16x?
Top Symphonic Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Symphonic Televison and Video Expert? Answer questions, earn points and help others
