Question about Philips 32PT5441/37 32" TV
Tv wont stay on
My tv power button blinks fast 3 times then a long blink and then 2 fast blinks please help i have the tv open and we dont know what we are looking at we were told something about a r3340 but we cant find it my tv is philips 32pt5441/37 its a 32 inch tv
    Genius:
  • 1,139 Answers
Hello annbower1125,
First I want you to put the back on the TV. The reason I say this is that you do not know electronics, I am not saying this to offend you, I say this because no matter what is wrong with that TV you are going to need a professional to do the actual troubleshooting and replacement of the part and or parts. Please take this TV to a qualified TV repair person, because it sounds like it has a power supply problem and that could mean a problem in the Horizontal circuitry and or the Low voltage power supply. These could expose you to dangerously high voltages.
I hope this helps,
Thank you,
Shuttle83
Posted on Aug 05, 2008
Sharp tv 70 inch wont turn on blinking 5 times fast 2 times slow
Which model do you have because the blink code differs from model to model. Did you try a hard reset? Meaning, unplug the unit, wait a minute or two, then holding the power switch down, plug the unit back in while still holding the power switch down. When it comes back on, release the button.
Jul 14, 2015 | Sharp Televison & Video
Push power button and it stays on for a couple seconds and then shuts back off. No picture comes on. Thank you Jeanette
To determine what your problem is:
UNPLUG TV ANDTHEN PLUG BACK IN---TURNON---GREEN POWER LIGHT COMES ON FOR A MOMENT ANDGOES OFF.
PRESS AND HOLD "device" and "menu"buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protectthe Convergence IC or IC's is blown---set will detect no voltage to convergenceIC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES ANDTHEN TO GET IT TO REPEAT MORE YOUHAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
let me know what you find--hope that you find 2 blinks, a pause and twoblinks--this is the most common and easiest to fix.
Let me know
SDTECH
Jul 29, 2011 | Mitsubishi WS-65819 TV
I replaced three cans. they were bulged on the top. i plugged the tv in and it did the same thing. i said it blinks 4 times fast but it is only three. blink code says 3=RESERVED. i pulled the the y-sustain...
Philips lists 3 models of your TV:
1) 50PFP5332D/37
2) 50PFP5332D/37B
3) 50PFP5332D/37E
User Manual for your TV (actually for the 50PFP5332D/37E):
http://download.p4c.philips.com/files/5/50pfp5332d_37e/50pfp5332d_37e_dfu_aen.pdf
The user manual doesn't document the logic board blink codes for errors.
What this tells me is that the TV went thru two revisions before reaching version E.
in case it helps: Philips Customer Support: 1-888-PHILIPS.
If they can't help otherwise, they can at least tell you if your set is eligible for warranty service.
Mar 24, 2011 | Philips 50PFP5332D 50 in. Plasma...
TV won"t stay on turns off in 3 seconds WS 55807
Do the self check when power light goes off.
On front of set press and hold both the menu and input buttons for 5 seconds or longer and release both buttons.
Power light will blink a error code like: 2 blinks, 2 blinks, a pause and repeat about 4 more times.
Let me know what error code you find and I will tell you what it means.
If this information told you something rate this solution as very helpful as I do this here for free.
SD TECH
Aug 28, 2010 | Mitsubishi WS-55807 TV
The tv just turns off after about 5 seconds and won't stay on. i've used the system reset and unplugged it already. no power surge, lightning storm, etc. Ideas?
If reset does not cure it and if after about 70 seconds of unplugging set the green power light stops blinking, do this:
When power light comes on and goes off, on the front of the set press and hold both the menu and input buttons at the same time for at least 5 seconds and RELEASE both buttons.
Power light should blink a two digit error code like 2 blinks, 2 blinks, a pause and repeat it four more times.
Let me know what error code you find and if this told you something you did not know, rate this solution as very helpful as I do this here for free.
SD TECH
Aug 24, 2010 | Mitsubishi WS-55511 55" Rear Projection...
My tv wont turn on.it sounds like its going to but
The 7 blinks are an error indication that is generated by protection circuitry inside the set. A problem has been detected and the set is shutdown to prevent further damage. The cilnking is the power relay that is attempting to turn on the set. I'll look up the eror code and update this with the likely solution later today.
Dan
Nov 03, 2009 | Sony FD Trinitron WEGA KV-32HS500 32" TV
Timer light blinks constantly
Is it Mitsubishi WD-52628 TV? please confirm model number.
Unplug TV from AC outlet for couple of minutes, replug back in, turn power ON and check, still same problem?
Lets read error code in TV, press Device and Menu buttons on front of TV at same time for 6 seconds that will activate error code read process. Led will flash in 2 sequence with half second pause. count it and let me know the error code to proceed.
Thanks.
Jun 29, 2009 | Mitsubishi WD-52628 52" Projection HDTV
The tv wont turn on
hello 2 blinks on this tv means you have this issue below
PT-44LCX65
2 blinks 5 secs you have your lamp cover open
check for this
hope this helps
Dec 14, 2008 | Panasonic PT-44LCX65 Television
I have a 53 inch wide screen Panasonic that is roughly 5 years old. It was working fine until I now hit the power button and the light stays on and then the picture comes on for 5 seconds then the TV...
whatsthe model number of your panasonic. Most panasonics mean convergence failure when the led blinks 3 times. Please respond to this post with your model number and I will post the correct ICs for your model and where you can get replacements with free instalation instructions
Jun 27, 2008 | Televison & Video
Philips 32PT5441/37 32" TV Logo
144 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
