Question about Sony PlayStation Portable (PSP) Console
Connection error iv restored default settings and formated my memory stick now when i try to set up my connection it displays the same message a connection error has occurred the attempt to obtain the ip address timed out i have been online with it before and have followed the same way to set up my connection settings
  • lugnut74 Jun 28, 2008
    tried that still no joy cheers anyway antonowicz69
There may be a problem with the wireless router, not the actual PSP, try resetting the router by either pressing reset on the back of the router or unplug it for 30 seconds and plug it back in
Posted on Jun 28, 2008
Ti 83 will not power on replaced all batteries
When you clear memory, the contrast sometimes changes. If the screen
is faded or blank, adjust the contrast by pressing 2nd and up- arrow or down- arrow keys .
Resetting RAM restores RAM system variables to factory settings and
deletes all nonsystem variables and all programs. Resetting defaults
restores all system variables to default settings without deleting variables and programs in RAM. Resetting RAM or resetting defaults does not
affect variables and applications in user data archive.
Tip: Before you reset all RAM memory, consider restoring sufficient available
memory by deleting only selected data.
To reset all RAM memory or RAM defaults on the TI-83 Plus, follow these
steps.
1. From the RAM ARCHIVE ALL menu, select 1:ALL RAM to display the
RESET RAM menu or 2:Defaults to display the RESET DEFAULTS menu.
2. If you are resetting RAM, read the message below the RESET RAM
menu.
• To cancel the reset and return to the home screen, press .
• To erase RAM memory or reset defaults, select 2:Reset.
Depending on your choice, the message RAM cleared or Defaults
set is displayed on the home screen.
Mar 25, 2012 | Texas Instruments TI-83 Plus Calculator
When I switch it on, I get this error: Memory Stick error C 13:01 camera Sony cyber shot DSC-P73
Hello and Welcome to Fixya
C:13:01 memory stick error message indicates a Self diagnostic message.In C:13:01 the issue may be with the Internal Memory or with the Memory Stick.
To solve it try the following solutions
Format error with the Internal Memory which can be corrected by formatting the Internal Memory.
If it is issue with memory stick then turning the power off and on again or taking out and inserting the "Memory Stick" several times may help in resolving the issue. Error may be because of Unformatted "Memory Stick" which can be resolved by formatting the Memory Stick in the Camera If it not remove by formatting in the camera then connect it to PC and tried to format it again but either FAT instead of FAT32 which is the regular format and then reinserted the memory stick and formatted it with the camara. Now it will be solved if it still exist then it means Memory Stick is broken or not compatible which can be resolved by inserting a new compatible Memory stick
I hope it will help you
Your Rating as Four Thumbs which are given below to this solution will appreciate me
Thanks
Mar 02, 2011 | Sony Cyber-Shot DSC-P73 Digital Camera
Says error on formatting memory card.
The camera may display a FORMAT ERROR if the inserted media is not formatted or if the media was formatted on a computer. This error may also display if the inserted media is not supported by the camera.
Try to remove and re-insert the Memory Stick media several times.
Make sure that the inserted Memory Stick media is compatible with the camera. DSCW310 Camera is compatible with the Memory Stick Pro Duo upto 32 GB.
You may also try formatting the Memory Stick media to resolve the issue. Format the Memory Stick media using the FORMAT option in the camera menu.
Formatting will erase all stored data, images, movies, etc., from the Memory Stick media. FORMAT option is available in the Memory Card Tool Menu of the Camera which is in the Settings Menu. Please back up the data by inserting the Memory Stick in the Computer Memory Card slot.
This may also happen if the terminals on the Memory Stick media are dirty. Remove the Memory Stick media from the camera and use a soft dry cloth or pencil eraser to clean the contacts. Make sure there are no residual particles on the Memory Stick media before re-inserting it into the camera.
The data on the Memory Stick media or the Memory Stick media itself is damaged. Try using a different Memory Stick media in the camera.
This should resolve the issue. If the error continues to display, the media may need to be replaced or the camera may require service.
Jan 23, 2011 | Sony Cybershot DSCW310 Digital Camera
My FujiFilm FinePix F47 fd has an error message that keeps saying 'Read Error' Help Please!!!
The Read Error message displayed on the Camera when accessing the images which was not recorded correctly. This may also happen when the Memory Stick is corrupted to record or read the files. Please check if the message is displaying when accessing all the images. If it happens with all the images, then it may be an issue with the Camera or the Memory Stick.
To check if the issue is with the Memory Stick, try using a different Memory Stick and check if the message displays.This may also happen when an attempt was made to play back the image or the movie that was not recorded on this camera.
Try to wipe the contact area on the Memory Card with a soft, dry cloth. It may be necessary to format the Memory Card (Format option is available in the Setup 2 Menu of the Camera). If the message still appears, service may be required.
Thanks for using FixYa.
Jan 21, 2011 | Fuji FinePix F47fd Digital Camera
I have format error on my cybershot camera. I need to access photoc on camera
The Camera may display the FORMAT Error if the inserted media is not formatted or if the media was formatted on a computer. This error may also display if the inserted media is not supported by the Camera. The maximum supported capacity and media used is Memory Stick Pro Duo with 1 or 2 GB.
If you've already captured the images in the Camera and the error message displays, then try to open different images captured in the Camera and check if the message appears for all the images.
If this happens with all the images, then remove and reinsert the MS (Memory Stick) in the Camera and check if it works. You may also try cleaning the MS terminals and also check if the Internal Memory of the Camera displays the error. If the issue persists, then insert the MS in the Computer slot and transfer all the images to the Computer. If the images appear normally in the Computer, then Format the media in the Camera. To Format the Memory Stick, select the Format option in the Memory Stick Tool Menu of the Camera. (Menu-->Setup-->Memory Stick Tool-->Format)
Formatting the MS will delete all the files saved.
Formatting the MS should resolve the issue.
Jan 18, 2011 | Sony Cyber-shot DSC-S700 Digital Camera
MY SONY CYBER SHOR DSC-W270. IT SHOWS SYSTEM ERROR WHEN TURNED ON.
The System Error message displays when the files on the recording media have been copied or deleted repeatedly on a computer. Backup the files on your computer, then format the recording media in the camera to resolve this issue.
Formatting the Memory will erase all the data stored in the Memory Stick.
If the error message displays after formatting the Memory Stick, then try using a different Memory Stick media. Once the Memory Stick is inserted, perform manual power reset of the Camera.
To reset the Camera, turn off the Camera and remove the battery pack.
Then, allow the Camera to remain without power for 30 seconds.
Later, re-insert the Battery pack in the Camera to resolve the issue.
Jan 10, 2011 | Sony Cyber-shot DSC-W270 Digital Camera
Sony psp very slow
try updating it...if that does not work take evrything out and blowdry it with a blowdryer
Sep 21, 2009 | Sony PlayStation Portable (PSP) Console
My cybershot w120 keeps saying no space on internal memory when i have a new memory card in it which is empty. This happened with my last card so now i am thinkng its more a camera problem rather than the...
in your settings is it set to "shoot without card"? this could cause the camera to not use the memory card installed and rely on internal memory which is limited
Aug 26, 2009 | Sony Cyber-shot DSC-W120 Digital Camera
I was going to sell my PSP and I was wondering how to reset it. So that there are no saved games etc.
To RESET your PSP,
Note: you WILL lose all settings, but NOT the stuff on the Memory Stick.
Go to "System Settings" under "settings".
select "Restore Default Settings". Select OK for both screens.
To FORMAT your Memory Stick,
Go to "System Settings" Under "Settings".
select "Format Memory Stick". click OK for both screens.
your PSP is now free of all personal data and is like new.
Aug 18, 2008 | Sony PlayStation Portable (PSP) Console
Ipod problem
hi i can not transfer my fave music to my ipod
Nov 22, 2007 | Apple iPod MP3 Player
Sony PlayStation Portable (PSP) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
