Question about Refrigerators
KitchenAid Superba refridgerator, two-years old; the metal jamb between the freezer and refrigerator compartments is very hot. put a meat thermometer on it and measured 132 degrees. white plastic liner on freezer side of jamb is turning brown full height of the freezer side. evrything works, just burns your hand when you touch the magnetic vinyl door gaskets.
  • 2 more comments
  • Val M Aug 24, 2008
    same problem. I'm assuming this is new since I've never noticed the metal jam being this hot until now & fridge is 4 yrs old.
  • dingo5 Nov 17, 2008
    door jamb gets very hot.
  • Anonymous Jan 11, 2009
    Were you ever able to locate and resolve the problem
  • IFraser May 17, 2009
    The strip of metal between the fridge and freezer sides on my Whirlpool side-by-side fridge freezer gets very hot sometimes and the fridge doesn't seem to be chilling as well as it should. Drip tray is dry, I have cleaned off the compressor. Can't understand it. Is there a cooling radiator along the door jamb or something?
They tried replacing the fan motor but that didn't help. It just burned out in 3 days. Had to wait for a new control board in the fridge.
Posted on Jan 17, 2009
Fan moter in back is out. I took my moter off and wd40 until it would spin free, and now it is fine.
Posted on Jan 15, 2009
Refridgerator compressor starts and stops, its a ten year old superba from kitchenaid. i want to think its a relay but if its the compressor, is it going to break the bank to fix?
check to see if the compressor is bad by putting your meter on the ohm setting. check each terminal togther and then also to ground if it beaps when it goes to ground it is a bad compressor. BUT it should beap when you check each termianl togerther. there is three leads one is start one is run and one is common. if you have contunity between these it is a good compressor. i
Jul 09, 2010 | KitchenAid Superba Architect KSCS25INSS...
The refridgerator portion gets too cold and freezes our food
If the two slide controls work and you can restrict airflow that would help. Usually a thermostat that does not respond to changes in temperatures are the cause. But we still need see if cahnces can be done to the airflow control. BRB with part numbers, Sea Breeze
Dec 19, 2009 | KitchenAid Superba KSRG25FK Side by Side...
Our refridgerator is old
in the toe kick
or in the upper right corner of the fridge
Oct 03, 2009 | KitchenAid Superba KSRG25FK Side by Side...
The jamb between the freezer & frig is very
It is common to be warm to the touch. If it is excessively hot then your door heater may be going out. Have a technician check it out. If this fails the doors will begin to sweat and drip onto the floor. Hope this helps. Good luck.
Aug 15, 2009 | KitchenAid Superba KSRS27CN Side by Side...
Kitchenaid side by side too cold. Freezes everything.
the damper motor on the refrigerator portion is not working properly
Apr 04, 2009 | KitchenAid Superba Architect KSCS25IN Side...
Drip/moisture tray inside base of kitchenaid superba refridgerator
need mor info,is there water in the bottom of your frig. or freezer,let me know more-mike
Oct 12, 2008 | KitchenAid Superba Architect KSCS25INSS...
Kitchenaid Freezer not freezing completley
sounds like you might have a sealed system issue(ie.compressor, sealed system. check your user guide for warr inf you might stil be covered by manufacture for this issue
Jan 06, 2008 | KitchenAid Superba Architect KSCS25INSS...
Kitchenaid superba refer side by side
its normal for the temperature to stay around 28 degrees farenheight int the bottom drawer. (fresh cut meat keeps better at his temp). you can adj the temp slide near the bottom of the refrig next to the botom drawer to help adj temp. veggies will almost always freeze in the bottom drawer. also adj the temp controls to a little bit warmer to help as well.
Keep in mind the mid point settings on your refrig is just a starting point for you to adj to where it works best for you and your usage..
Dec 17, 2007 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
140 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
