Question about RCA 34000RE3 Handheld Digital Voice Recorder
Rca34000re3 how do i delete recorded clips on the rca 34000re3
Hi I own a RCA digital voice recorder, model #rp5030A. I cannot figure out how to delete the recordings, can you help me?
Plug it into your computer via USB cable, open file(s), right-click with your mouse on the one(s) you want to delete, one the dropdown menu, go down to the word delete and left-click your mouse. POOF, recording gone.
Sep 29, 2010 | RCA Audio Players & Recorders
I have rca recorder rp5120-a. i have deleted everything but it still says full whenever i try to perform new recording. what should i do?
Try removing the batteries for 5 minutes then format or delete everything on the recorder.If that doesnt work, send it to rca for service,
Apr 19, 2010 | RCA RP5012 Digital Voice Recorder
Cant delete folders
You can delete a file by
1.push menu
2.select folder
3.select file
4.press erase once and "delete" will blink on screen
5.press and hold erase to confirm deleting (or press stop to cancel)
Erase All Folders
1.select folder
2.press erase once and "delete" will blink on screen
3.press and hold record for 2 secs.(Folder/All/Delete will flash at the same time)
4.press and hold erase for 2 secs. again to confirm delete
If you want to erase all the files in a particular folder will leaving other folders files intact.
1.select folder
2.press forward repeatedly until "All" appears on screen
3.press erase-"Delete" will blink on screen
4.Press and hold erase for 2 secs. and all files in that folder will be deleted
good luck
Apr 08, 2009 | RCA RP5012 Digital Voice Recorder
How do you erase
press erase where it will say delete then press erase again and it will delete the file
Sep 03, 2008 | RCA RP5020 Digital Voice Recorder
How do you delete old recordings?
find the recording you want
press the erase button (front of the recorder(top left))
after pressing it let it go
then press it again
that recording is then gone
voila
Jan 22, 2008 | RCA RP5010 Digital Voice Recorder
Can't get the delete menu to come up
Delete menu only works for voice recordings - if you have no voice recordings, it will not show up. Use Windows Media Player to delete songs.
-Tha Mp3 Doctor
Dec 30, 2007 | RCA TH1101 MP3 Player
Instructions for usage and operation
there's a link to a PDF of the full user's/instruction manual under the "Production Details" section here
http://www.amazon.com/RCA-RP5010-Digital-Voice-Recorder/dp/B00006LEJ9
Aug 08, 2007 | RCA RP5010 Digital Voice Recorder
Deleting Files
1. Select folder (A/B/C/D)
2. Select file.
3. Press ERASE once and DELETE will
blink on the screen.
4. Press and hold ERASE for 3 seconds
to confirm deleting. (or press STOP to
cancel erasing file)
Aug 04, 2007 | RCA RP5015 Digital Voice Recorder
Voice recorder 5007A
press the erase button, it should flash delete at you, if you let it do that to long it will go back to the way it was before you hit the erase button. to delete, hit erase on the folder you want then hit erase and hold it untill it deletes the file. continue this proccess untill all files are deleted
Jun 17, 2007 | RCA RP5007 Handheld Digital Voice Recorder
RCA 34000RE3 Handheld Digital Voice Recorder Logo
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
