Question about Mitsubishi WS-55809 55" Rear Projection Television
Mitsubishi WS-65711 HDTV
I just upgraded to Verizon Fios with HD receiver. Connected RCA Y.Pr,Pb from reciver to INP-DTV, this should allow me to get 1080i but it appears that i can only get 480 and the pictures is smaller than the screen. Can you please explain what I need to do to get the 1080i full screen
The Verizon installer did not set the reciever to 1080i, had to set reciever to 1080i and then push 3 buttons in order on the reciever to take me to the nonstandard menu to check a box so that all channels without 1080 would automatically fill the screen.
Posted on Jun 30, 2008
Tip
Mitsubishi WS-65711 Manual Download
Download Mitsubishi WS-65711 HDTV Manual
Models: WS-B55 / WS-48511 / WS-55511 / WS-55711 / WS-65511
Models: WS-65611 / WS-65711 / WS-65712 / WS-73711
Have you misplaced your Mitsubishi WS-65711 HDTV Owners Manual?
Would you like a digital, searchable, pdf version of the Mitsubishi WS-65711 HDTV Users Guide?
Follow this link to download a pdf version of the operations manual.
I hope that helps.
__________________________________________
Reset Mitsubishi WS-65711 VChip Password
Bypass Mitsubishi WS-65711 Front Lock
on May 04, 2010 | Televison & Video
Tip
I hope that helps.
on May 04, 2010 | Mitsubishi WS-65711 65" Rear Projection...
I am attempting to connect a Verizon Fios QIP6200-2 HD set top box to my Mitsubishi WT-46805 HD TV using the Y, Pr and Pb RCA connections (no HDMI port on TV) I cannot get any HD channels to work.
The set will have two component inputs, one is NOT HD.
You want to connect to the DTV input which if you look from the back will be marked 480/1080 I .
Also double check the connections to be sure blue-red-red and green to green.
SD TECH
Aug 18, 2010 | Mitsubishi WT-46805 46" Rear Projection...
HDTV goes blank when connected to Fios HD-DVR or Fios DTV recvr.
If you can first connect the Fios box via component and that will rectify the issue and still allow HD. HDMI is funny, if there is anykind of communication issues between the TV or the Fios box you see what happens. You might also call Samsung to see if there is ANY firmware/software updated for your TV specifically to fix such an issue with the Fios/Mortorola connection. If there isn't then the issue is the cable box since the TV works ok on HDMI with other devices.
Jul 23, 2009 | Televison & Video
Mitsubishi WS-65315 plug in HD comp shows as 480i
Greetings,
In the input assignment menu make sure that the DTV (the only 1080 input on this tv) is set to Y/Pb/Pr and see if that fixes your issue with at least the HD-DVR.
BTW- the HDMI information "1080i HD can only be selected if TV has HDMI inputs". is not correct.
Feb 25, 2009 | Mitsubishi WS-65315 65" Rear Projection...
1080i
Using the DTV input on the back via component cables to an HD source you then need to make sure the input assignment menu is adjusted to Y/Pb/Pr
Feb 25, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Mitsubishi WS-65711 green tint only with DVD via Component
there should be a setting in the menu that you need to make sure is set to YpPbPr not RGB if set to RGB it will give you a green pic on the DTV Input.
Jan 03, 2008 | Mitsubishi WS-65711 65" Rear Projection...
Can't display 1080i from DTV
you may have to go to setup and turn on this setting
Aug 28, 2007 | Mitsubishi WS-55807 TV
Mitsubishi WT-46809 Problem getting HD from DirecTV
I have the same exact problem. Same model, etc. Is there a resolution?
Sep 16, 2006 | Mitsubishi WT-46809 46" Rear Projection...
Mitsubishi WS-55809 55" Rear Projection Television Logo
148 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
