Question about Kodak EASYSHARE Printer Dock Thermal Photo
Printer only prints the top half
I've changed cartridge n paper still no help
Same problem-only prints half of the image
Posted on Nov 03, 2008
5 Suggested Answers
I am experiencing the problem with an HP Officejet 7410xi.
Posted on Feb 12, 2008
SOURCE: Samsung SPP-2040 Photo Printer
For me, alysse's method worked. The part did not look particularly broken, but was not firmly gripping the shaft. I moved it to where it should have been, tightened it as described, and now the printer works great again.
Are you sure that that cam is not slipping on the shaft?
Posted on Apr 07, 2009
  • 119 Answers
SOURCE: I have a Kodak Easy
Does the test print also print only half of the printer? If so, give Kodak a call - bad printer
If the test print works, try changing the usb cable.
Posted on Jul 11, 2009
  • 4 Answers
SOURCE: Printer is making rumbling sounds
Replace the paper pcik-up rolly assembly. MAKE SURE TO get a good look at how the existing one is installed before removing it. It needs a little tweeking to get the new one in and everything lined up correctly.
Also replace the separation page on the paper tray itself.
Look for part number PF-1 Kit or OEM PART #: LJ7920001
The only diagrams I could find on-line of the inside of the printer I found by searching for "brother pl-prn067". Look at pages 8-9.
Posted on Feb 02, 2010
My HP printer prints half on one page and half on another how can i fix it?
Pl share printer model number for better solution.. try this# go to printer menu select default settings..check# check paper size in proper size# un install existing drivers, re install once again..check# print from word or excel format..checkif no result share printer model number... for better solution...Vinay
Mar 30, 2012 | Office Equipment & Supplies
My hp 1010 prints only the first page. but from the second page it gives blank print. please help
shake the cartridge well and put it back & check, replace with another cartridge, check half test page if no print on paper check on image on cartridge drum( while printings approx half page open the door remove cartridge & paper check print on paper,on cartridge drum) check transfer roller & replace
If no image any ware replace "Power supply PCA"..
Sep 10, 2011 | HP LaserJet 1010 Printer
Kodak Easyshare Printer dock series 3 not printing full picture
throw out your printer and buy another brand. if you call18002356325 the call goes to manila and chances are you will be talking to some one who only speaks partial english and knows nothing about kodak products but will read to you from these internet instuctions that you just read !!! kodak has become a very anti-american company in so many ways!!!
Aug 04, 2009 | Kodak EASYSHARE Plus Series 3 Thermal...
Ghosting on HP2015 Printer
Hi gpeirce:
Ghosting is the result of a worn fuser assembly. Try to print a half page by printing a document and then try to open the top while the paper is going under the toner cartridge. You have to listen to the paper moving through the paper path.You will see that the paper has print on it but not the hole document. This will tell you if the toner cartridge is bad or the fuser assembly.
Hope this helps
May 30, 2009 | HP LaserJet P2015dn Printer
Konica Minolta PagePro 1350W laser printer. Have
your carteidge OPC duram is faulty .
so change cartedige
Apr 25, 2009 | Konica Minolta PagePro 1350W Laser Printer
Poor print quality - top half page okay, bottom print faded and skips top half page okay, bottom print faded and skips problem Just installed a new cartridge
check the wright cartridge model you installed and well pluged to the printer
if it is ok
try to change printer properties and fix it correct options with there tabs ( ex: paper, print quality etc)
all are well try to reinstall the printer driver
Jul 16, 2008 | HP PSC 1210 All-In-One InkJet Printer
Prints only the top half of some lines.
Take the offending cartridge out and get a piece of tissue paper on your finger. Gently run the print head of the cartridge over the tissue paper. You shold see full lines of ink coming out. If not, the cartridge is out. If you see a full line of ink, reinsert the cartridge and do a clean cartridge from the tools menu
This should work
May 09, 2008 | HP PSC 1610 All-In-One InkJet Printer
Kodak EASYSHARE Printer Dock Thermal Photo Logo
159 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
