Question about Kitchen Appliances - Others
Looking for owners manual
I have a general electric side by side and i looked under the fridge door and got a model number it is a camco modal number tfxc24ekc i need a owners manual as it has an ice maker in it too thanks in advance
  • 489 Answers
SOURCE: Ice maker stopped after electric shutoff
You may have a problem with the computer control board in the ice maker.  Try this.  Turn off the icemaker for about 2 minutes.
Turn on the ice maker and press the clear button.  Press and hold this button for 12 seconds to get it to force extract.  This will confirm that the motors will work and push the ice cubes out.  Afterwards, let it run by itself.  If it still doesn't make ice, you will need to replace the icemaker.
Posted on Sep 30, 2008
duby1990
  • 370 Answers
SOURCE: ICE MAKER NOT WORKING
Check to make sure you freezer is at 0 to 5 degrees. If it is not the water valve to the ice maker will not even open.
Posted on Nov 20, 2008
  • 33 Answers
SOURCE: Amana Side-by-Side Fridge Model SBD21VPSE
If there is a reset button on your ice maker try pushing it. Many ice makers have two holes for reset. A general rule of thumb is if the ice maker fingers are stopped in a slightly vertical position then your ice maker unit is working. If the fingers are stopped anywhere else then it needs some sort of attention or replaced. Make sure there is water, or ice in the ice maker tray, if not then the problem is with water supply.
Posted on Nov 29, 2008
SOURCE: leaking fridge
my maytag had cloged defrost drain cleaned drain all ok
Posted on Jul 03, 2009
TheMobilian
  • 8220 Answers
SOURCE: Refrigerator Ice maker stopped working after power outage
Check THIS out
Posted on Jul 26, 2009
How do I turn the icemaker off, too much ice, GE model GSH25JFXN WW?
Move the feeler arm above the ice bin to the up(off) position.
Below is a link to a GE side by side refrigerator manual. It may not be the exact one for your fridge. Page 20 of General Electric Side by Side Refrigerator Owner Manual...
Aug 14, 2014 | Refrigerators
How do you install the fridge evenly in the alcove?
#1 is floor level?
#2 does it wobble?
#3 check owners manual-LEVELING THE UNIT there should be adjustable 'feet' that screw into the bottom frame of the unit.some have adjustable wheels at the front.remove the vent panel under the door and look under with a flashlight to see what you have.
Jan 22, 2013 | Fisher Refrigerators
Reverse doors freezer hinge
What is the model number of your unit?
Nov 28, 2012 | Refrigerators
Where is the model number?
For a Whirlpool refrigerator, look for the plaque with the model number inside the fridge on the wall. (Frequently on the right or left side near the top)
For a complete list of where to find the model number for Whirlpool appliances, see http://www.whirlpool.com/owners-center/owners-center-homepage.content.html . Click on the Where is my model number link http://www.whirlpool.com/webapp/wcs/stores/servlet/WHRPopUpContentDisplayView?catalogId=10561&langId=-1&storeID=10211&cid=owners-center_locate-model-number&KeepThis=true&TB_iframe=true&height=525&width=500&modal=false .
I hope this helps.
Jul 10, 2011 | Whirlpool GS5SHAXN Side by Side...
Freezer fan is noisey and can t find serial number
The number you will need is the model number. On side by side models there are a few places to look. 1- inside fridge on right or left wall. 2- Open fridge door and look up near the top front lip. 3- Open both doors and look on body of fridge under the doors. 4- Fridge door sometimes there is a sticker right when you open. Mostly you are looking for a silver sticker or silver plate. It gives you a model number and serial number. If you need further assistance please mail me back.
May 26, 2011 | Kenmore Side by Side Refrigerator
How do i gain access to the defrost timer in a kenmore side by side refrigerator model 106 9532?
what's the rest of the model number?open the fridge door,look up near the cieling on the right hand side and send the whole model number,if it's an older machine the model number could be down near the bottom hindge on the fridge door.send that and i can help you.some are behind the bottom kickplate and some are in the fridge side depending on the model.
Mar 03, 2011 | Refrigerators
I have a Maytag refrigerator similar to the current model (GS2625GEKS), I purchased mine in 2003. Serial number unknown. All of a sudden my freezer is way too cold and my refrigerator is not cold enough....
If the number is similar we will have to go with possibilities. Sound like the auto damper has frozen itself shut between the fresh food and freezer compartments. Some are controlled electrically some manually and others are controlled with a thermostat probe. Your thermostat for one side could be defective and not allowing the damper to open. Your refrigerator must have the correct model number to proceed. What I need you to do is look for the vent through the rear of the refrigerator compartment and sometimes leads directly from the same wall as freezer. Many Maytag brands fall under same series and model similarities. The serial number is not as important to the service Tech as the model number. Look around the door frame near floor and kick plate.I can help but I will need the correct model number, Thanks, Sea Breeze
Feb 13, 2010 | Refrigerators
I cannot find the model number for my maytag oven to download a manual. I've lived in my home for three years, the oven was there when I got there so I don't know much about it. Now the display is saying...
Unfortunately, there is no standardized location for the model # sticker. Look in all for side corners of the oven door, then look on all four sides of the oven opening.  Look on the inside of the oven for the name plate.  Look under the stove top where the burners are and finally look behind the oven.
As a last resort you can look on your sales contract to see if you can contact the previous owner for advice.
Oct 25, 2009 | Maytag MEW5530D Electric Single Oven
No model number on fridge
Open the door, crouch down, then look up - it's under the top on the left
Oct 18, 2009 | Refrigerators
I would like to know the model number for my hotpoint fridge
Without knowing the approximate age of your fridge, or the style, (top/bottom freezer, side-by-side, etc.) it makes it hard to give an exact answer. However, I'll provide you with some places to look for the model number.
You should look inside the fridge section of the unit and there should be a label either on the ceiling of the fridge section, on the upper side of the fridge (look at both sides), on the edge of the door opening located at the bottom of the fridge (when door is open) or behind the toe kick plate at the bottom of the fridge. Another place to look is at the back along the top edge.
Again, without more info, it is difficult to zero in on where the data plate is. Hope that helps, if you have more info, get back to me and I'll try to help you further.
Jul 13, 2009 | Hotpoint Refrigerators
Kitchen Appliances - Others Logo
49 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
