Question about Sony DVP-FX810 Portable DVD Player
Not charging when i plug my dvd player in it works until i unplug it. when the dvd player is off the charge light does not light it up and it does not charge. i tided the car charger and the regular one and they worked until i unplugged the device.
  • cyosh1971 Aug 26, 2008
    I have the same problem.  Is there a fix out there?
  • www4 Aug 26, 2008
    i have the same issue with mine. It works fine when its plugged in, and its only a year old.
Hi ...well i got the same problem. Question is ....can this rechargeable battery pack np-fx110 drain itself where it can not recharge? I also wish to know ...to turn on the dvd. slide the power slide to on ,green light, disc is in screen opens says loading the goes blank. Duh what am I doin wrong?
Posted on Nov 23, 2008
Dont use this web site
Posted on Aug 07, 2008
How to charge battery, is there a charger that we have lost or does it charge while on player & plugged in
The player charges, with or without playing a disc on it,
First step to charging your battery is having it plugged without playing it for a while.
There should be a light that comes on when you plug it to a power source.
When it is full, there also is another light that comes on to signify it is full.
You can also charge it while playing a DVD on it.
But if it does not charge when you plug it without playing a Disc on it, then there is a problem that need to be fixed on it.
test if the battery is charging.
  1. plug the player to a power source for some time,
  2. wait for some time for it to have charged very well,
  3. unplug it from the power source,
  4. test a disc on it to see if it will play.
if it does not play, then it means there is a problem.
which could be that the battery may be faulty.
All you have to do is to replace the battery and it will work perfectly fine again.
take care
Jun 18, 2010 | Polaroid PDM-0723 Portable DVD Player
When I plug in the ac adaptor to charge unit,the instructions state the chg light will go off when charged. Is it possible that it is charged and the light stays on. I charged it (in the off position)...
The unit still,work?The battery when it low,the battery light turn yellow or red?Than when it fully charge it turn green?Just unplug the unit and use it dosen't matter,if the light don't turn off the light,that find.Or the battery is old and not taking full charged anymore that another resoan the charging light still on.
Jun 14, 2010 | Mintek MDP-1770 Portable DVD Player
Can't seem to get my dvd player to charge.
I have this model dvd player and it has worked very well for over a year. Lately it has not had a picture but has had sound when fully charged. When the green light is on, it is charging. When the light goes off, it is fully charged (or should be). I plugged the wall charger directly into the dvd player and it works fine with pic and sound. I think maybe the rechargable battery is on it last legs. I am looking for a longer cig lighter charger cord to reach the headrest so kids can watch from backseat. I will be able to keep it plugged in to charger at all times. Hope this helps!
Apr 06, 2009 | Spectroniq PDV-70X
Need help charging my mintek dvd player battery
The way the battery is usually charged is by plugging it into the player and plugging the player into the a/c outlet. Do not use the player, Just allow the player to charge the battery. The way you tell if the charging is working is the light on the front will usually be a red color and it will be steady color or blinking while charging. When the battery is fully charged, the light will turn green or turn off . This lets you know that the battery has fully charged.To test this try using the dvd player on the battery only. Play a dvd or cd and see if the battery is working properly. I hope this information helps you with your problem.
Apr 01, 2009 | Mintek MDP-1770 Portable DVD Player
Battery won't charge
Borrow or get a cheap volt meter to see if the power supply is working. Insert one probe on the inside, and one on the outside to see what is going on inside the power supply/charger.
Does the power supply hum or get warm? If not, it was probably made pre-broken at the factory in china. Either that or it's power lead has a break, it's power output jack or where it connects to the main board on your portable DVD player.
-Pro Hack
Aug 13, 2008 | TruTech PVS12701 Portable DVD Player
Portable DVD Player will not power up
This player should be charged up until the green light goes out to be fully charged. I usually leave them on over night.
Glenn
Mar 16, 2008 | Philips DCP855/37 Portable DVD Player
Mintek 8" TFT portable dvd player MDP1810
DO NOT continue to try to charge that battery. The company recalled those batteries because they explode or start on fire. Do a google search of "mintek" and you can read about the recall.
Jan 10, 2008 | Mintek MDP-1770 Portable DVD Player
How do I charge it? PLEASE HELP!!!!!
If you put the battery in the player and then plug in the player it should charge the battery. Be sure to leave it until the light in the front of the player shows green.
Nov 18, 2007 | Cyberhome CH-LDV 700B Portable DVD Player
Coby TF-DVD7006.
The second question, I couldnt work that one out at first, but now i think I understand. If you plug the player into the mains, turn it on, red light shows. Light turns green when battery charged. Do not use until light turns green (if plugged into mains). In other words dont use the player while the battery is charging. If it isnt plugged into the mains then the battery cant be charging and you can use. Until battery gets too low :)
Nov 13, 2007 | Coby TF-DVD7006
Insignia IS-PD040922 portable dvd player
The batteries are not being charge,it might be bacuse you have the wrong ac adapter,you should get the original to start then let the batterys charge for at least 5 hours or until the red light stopr blinking.You can find more inf.here http://www.insignia-products.com/p-31-insignia-7-169-widescreen-portable-dvd-player.aspx
Sep 25, 2006 | Insignia IS-PDO40922 Portable DVD Player
Sony DVP-FX810 Portable DVD Player Logo
186 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
