Question about Hotpoint First Edition FEW12 Front Load Washer
NOT FILLING PROPERLY
HOTPOINT FIRST EDITION WMA10. RECENTLY DISCONNECTED TO PUT IN NEW KITCHEN PIPES ALTERED WATER GOING THROUGH BUT NOT ENOUGH CLOTHES GET DAMP. CANT SEE THE WATER FILLING. IT SOUNDS LIKE ITS FILLING BUT WATER COMES STRAIGHT OUT AGAIN??? THEN SWITCHES ITSELF OFF. ANY IDEAS
Thanks so much for the solution I can't believe something so small could cause such problems. I really appreciate your quick reply
Posted on Jul 01, 2008
    President:
  • 1,462 Answers
Have you got the drain pipe going up to about worktop level of machine?
if the drain just goes downwards then the water just runs out as fast as it comes in. get a sililiar situation if you put drain pipe too far down a standpipe - then a syspon forms and water drains out
Posted on Jun 28, 2008
Fills when not being used
where the water pipes plugs into machine it has a water stop valve there. turn water off at mains and unscrew pipe. it may have a blockage of some sort keepng the valve open. hope this helps
Feb 14, 2012 | Hotpoint First Edition WMA22 Front Load...
Hi. is the front filter on hotpoint wma10 removeable. The machine is not draining properly after cycle but putting it on spin only cycle twice removes most of the water.
Most hotpoint filters are Located under the drum centre ..you need to remove the big sump hose/ clipe off then the filter is inside here . give it a good clean the water test machine for any leaks before using...Good Luck
Mar 19, 2011 | Washing Machines
Hotpoint first edition WMA10 making a bangin noise during wash programme. Cannot find filter in order to clean. trishisfit2000@yahoo.co.uk
I have the same model at work only under the frigidaire branding. The shock mounts for the
drum are made of plastic and can break (especially if the unit is moved without the
shipping screws) If one breaks the unit will make a clunking sound.
Dec 06, 2010 | Hotpoint First Edition WMA12 Front Load...
Hotpoint washing machine model WMA10
the filter is on the front bottom left or right. if this helps please rate joe
Nov 21, 2008 | Hotpoint First Edition WMA12 Front Load...
Washing maching won't rinse in cold water
hi is this hot and cold water piped machine? ie two connections on rear of machine for hot and cold pipes ? if so are your pipes connected properly on machine and the water supplies? if cold supply is connected to hot supply then wash inlet allows water in washer then washes in cold? but when rinse is due? the elec valve that has hot water pipe connected?? is failing to open allowing water flow of hot on rinse so advise recheck pipes for flow of water from both? when disconnected from machine if flow ok then possible valve blocked/faulty hope you can understand above? if you can give more info on your machine it would help to offer a remedy?
Nov 01, 2008 | Hotpoint Washing Machines
Washing machine WMA54 Hotpoint sticks on prewash
I realised that the washer was not filling properly with water!  So I pulled it out from the wall and noticed the cold water fill pipe had been squashed and had a kink in it so not enough water was getting through.  I remedied this by pulling the pipes through the under sink cupboard and securing them with gaffer tape,  Hey presto the machine now works again!  Hooray :D
Oct 06, 2008 | Hotpoint Aquarius WMA52 Front Load Washer
Not draining and flooding my kitchen!
hiya
first off norah, you will need to check the pump filter as there is probably a blockage in there.
secondly guest, sounds like a faulty pressure switch or even a small hole in the pressure pipe, thats why your machine will not stop filling.
hope these help
please dont forget to rate the helpfulness of this reply thanks kj
Jun 09, 2008 | Hotpoint First Edition FEW12 Front Load...
Hotpoint few12, machine not filling
the timer, electronic or mechanical is not advancing to the fill contact. if mechanical the cam contact may be burnt. if electronic the gated triac [solid state relay] is burned up [replace]
Sep 05, 2007 | Hotpoint First Edition FEW12 Front Load...
WMA10 abridged programme cycle
is the drum going round at all if not then most likely your carbon brushes which puts power to the motor there is 2 either side of the motor you will need some bent nosed pliers to take them out must have at least 8ml of carbon on them
Sep 26, 2006 | Hotpoint First Edition WMA12 Front Load...
Hotpoint First Edition FEW12 Front Load Washer Logo
105 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
