Question about D-Link RangeBooster G WBR-2310 Wireless Router (WBR2310)
No wireless connection
I have the wbr-2310....its been working fine for over a year. Lost power here and bright house had to reset modem...I have not been able to access wireless since then...bright house said they didnt detect my dlink. this is making me crazy as I am no expert on computers...tried to reset d link and start over but that hasnt helped. Im using windows xp dell lap top.
  • 4 more comments
  • boscoeee Sep 30, 2008
    Router begin to require reboot often at least every hour, now it will not allow wired or wireless connection.
  • efren94 Oct 05, 2008
    Same. Suddenly it stopped workin the wireless connection. By the way, i couldnt put password nor username on it. Thanks in advance.
    e-mail: efechivas_5@hotmail.com
    will appreciate if someone solves the problem and will mail it to me.
  • datacecily Oct 09, 2008
    I ve had the same problem after a power cut! and cannot connect the wifi after that.
  • texanbooks Oct 20, 2008
    Re-set helped once yesterday but problem came back today and now not even reset will get it going.
  • Anonymous Nov 24, 2008
    The router will not work as a wireless access point, only wired.
  • Anonymous Jan 07, 2009
    Had access two days ago and not nothing on my lap top.
    All other computers that are not wireless don't have a
    problem. Have tried everything..
Are you presently using cable or dsl service?
Posted on Oct 28, 2008
  • bpfine Oct 28, 2008
    I can tell now that you have a DSL service. I switched from DSL to CABLE because I had the same problem as you........ The problem is in your phone line !!!! Bright House may be able to reconfigure your modem but they can't fix a spike in your phone line.
Did you hold down the reset button for at least 10 seconds on the back? that should reset it to factory settings
Posted on Jul 02, 2008
After cable co. split cable and installed another modem, D-Link WBR 2310 router no longer works with its original modem. Tried resetting, unplugging, etc. Can't get wireless.
Use an Ethernet cable to connect your computer to one of the LAN ports.
Click Start
Click Run
Type CMD
Press Enter
Type IPCONFIG
Press Enter
Look for a line of output like:
Default Gateway . . . . . . . . . : 123.468.32.1
Start Internet Explorer
Type http://123.468.32.1
Press Enter
Login to your router
Click to run the "Wireless Networking Setup Wizard", to:
1. set an SSID
2. set an encryption-level, e.g., 'WPA' or 'WPA2'
3. set a password for your network
Click OK to restart your computer
Use your wireless device to connect to that SSID, using that password that you set.]
Jun 06, 2011 | D-Link RangeBooster G WBR-2310 Wireless...
I have a WBR-2310 D-Link wireless router. Yesterday it started not getting the signal from the Comcast cable modem. I can connect the cable modum direct to this computer and it works fine. But the gold...
If ever I have had a problem with my D-Link I have contacted them directly and they have solved it over the phone for me. There is an initial answer message that states that you MAY be charged $40 for the help ... but I have never been charged. It is a brilliant service.
phone 0800 900900. I hope that this helps you.
Oct 29, 2010 | D-Link RangeBooster G WBR-2310 Wireless...
My wireless router is not transmitting a signal. It appears that the connection from boadband modem is working fine. But cannot connect to internet via the router. Need help! krazy_glue
If the router is not transmitting signal the best thing to do here to correct the problem is to reset and and reconfigure the router, to reset it press and hold the reset button of the router for 10 seconds while power is ON and then after that power it OFF for 10 seconds and reconfigure it back.......
Dec 05, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
Wbr-2310 error 112
Check your physical connection first. From the modem, it should be connected to the router's Internet port, then your computer must be connected to port 1 on the back of the router. Then do a power cycle, no need to run the setup CD. If it doesn't work, you need to manually configure the router. You may need assistance from D-Link tech support. Call their toll free number
Jun 20, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
How to set up vonage my wbr-2310 router and 2wire ATnT modem
2wire routers will only work with another device (router) if you will set it up to bridge mode. you need to go to the ip address of 2wire and check the box to enable routing.
Mar 25, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
WBR2310 messes up my Wireless card...
reset yoru modem and wireless then after that go to windows explorer and type in the default ip which is 192.168.0.1 then it should be able to connect to your router an you setup everything from there, it worked for me.
Jan 25, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
D-link WBR-2310 has serious drop out problems
I'm pretty sure that downgrading the firmware to 1.0.3 will work. I had been running at this level for quite some time and for some reason I decided to upgrade to the latest version which started the problems for me. I am downgrading to this now and I expect better results. All of the firmware versions are available at http://www.dlink.com/products/support.asp?pid=470&sec=0. You pick the right hardware revision. PLEASE NOTE: Save off/remember your settings as when you change the firmware it resets all of them back to system defaults.
Dec 12, 2008 | D-Link RangeBooster G WBR-2310 Wireless...
D-link WBR-2310 Stop working
Sounds like a defective modem/modem failure if, it does not reset or if you take all of the other wires out and just leave the power in and none of the other lights go off then that is definitely a defective mode, I suggest either returning the modem to where you purchased it from or calling D link it should be covered under there warranty for replacement.
Nov 14, 2008 | D-Link RangeBooster G WBR-2310 Wireless...
D-LINK WBR-2310 SET-UP
Sounds like you need to 'copy' the mac address of the computer it was orginally hooked to before and put it into the router. Some routers have an option to do this in the settings menu of the router with one click.
May 15, 2008 | D-Link RangeBooster G WBR-2310 Wireless...
D-Link RangeBooster G  WBR-2310 Wireless Router (WBR2310) Logo
158 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
