Question about Motorola Mobility V220
How do i clear the memory on my phone so that it doesn't show any used number that are not saved as contact?
When i try to send a message, i still shows me numbers that the previous owner used.
how do i get those number off the memory of my phone so that it doesn't show any used number that are not saved as contact?
    Brigadier General:
  • 7,752 Answers
Do a master reset of the phone
MENU/SETTINGS/INTIAL SETUP/master clear/reset - 000000
Posted on Jul 02, 2008
When people call me, their name or number doesn't show. I have tried everything. How do I fix this?????
Check the memory status if what memory-in-use preferred, might select both in-use memory,might double the save contacts that's why unable to recognized which contact to be in-use.choose either sim memory or phone memory and double check your contacts if there's a duplicate.
Jul 21, 2011 | Nokia E63 Cell Phone
When reciving text messages the phone number shows up instead of contact name
this may happn in two cases:
1) when contact is not saved in memory
2) contact is saved twice means
contace saved in phone memory as well as sim memory
so delete contact from both and sav that in any one memory either in sim memory or in phone memry :D
Mar 06, 2010 | Samsung Finesse SCHr810 Cell Phone
Hi my samsung D 900 soul drop and its not working im
It all depends on what type of phone you have, and I don't mean which brand. If you phones is a GSM technology phone the it requires a SIM card to work, all of your contacts should be already saved in your SIM card. The same goes for the messages. All of this is possible only if you had save all your contacts and messages in your SIM card, but if you saved your contacts and your messages in your phone, and your phone don't power on, then you lost it. Try the SIM card in another phone that uses the very same band as your old phone, and check in the phonebook, if it shows empty, then all your contacts were saved in the phone.
Oct 11, 2009 | Cell Phones
I have nokia 5320 xpressmusic and cant send SMS
Try to to soft-reset your unit. (6 steps)
1. BUT Make sure you backup your phone memory to your memory card. Soft-reset deletes all data saved in your phone memory, including factory settings and pre-stored music, videos, etc.
2. Dial *#7370#. This would take at least 2 minutes.
3. Try sending messages to your own number.
4. If sending messages is working, you may now restore your backup of phone memory.
5. After restoring phone memory backup, try to send messages again.
6. If sending messages is not working again, chances are, your original phone memory is full and you should delete messages and contacts. You have to repeat soft-reset (steps 1-3). But your previous data should be accessed directly from your memory card so as not to directly save to your phone memory.
******ciao*****this works for me. took me an hour to figure out how this works coz I really like my 5320. gotta find a way to tweak and fix this anyhow =)
Aug 09, 2009 | Nokia 5320 XpressMusic Cellular Phone
Wont recieve texts
u need to set the messege centre number correctly contact ur operator helpline or try deleting the messages in your outbox and saved items.
Jul 10, 2009 | Nokia 6120 classic Cellular Phone
Memory full. Please delete some data.
press *#7370# to reset phone but make a backup
Jun 30, 2009 | Nokia N73 Cellular Phone
I am using nokia n73 mobile..i am unable to send text message.it shows memory full.have flashed the phone memory in nokia care but later this problem repeated. suggest me a solution?is there any code for...
simply first be sure you are using the memory card memory
go message--other---setting---memory in use ---(chose memory card)
second go to sent message and clear it and from the setting chose donot save the sent
May 11, 2009 | Nokia N73 Cellular Phone
Names wont show up when contacts call
it may take awhile but you have to put a 1 infront of everyones numbers
i had the same problem but that solved it i didnt put a +1 just a one such as
12223334444
Dec 25, 2008 | Dual Electronics N99i Cellular Phone
Unable to send or receive picture messages
For saving setting you will have some free memory if free memory is not available then It will not install.
For installing please first release some memory from phone memory.
Let me know If I can help you further regards this problem
Regards
nidostyle
Nov 17, 2008 | Sony Ericsson K610i Cellular Phone
"Memory Low, Delete Some Data"
You might want to try a "Hard-Reset" To do this you turn of your phone, press and hold "Answer Call(Green)"+"3"+"*" and then turn it on. This should reset your phone completely and clear the memory. CAUTION, back up all your vital data before you do this, it clears EVERYTHING.
Dec 27, 2006 | Nokia 6682 Handheld
Motorola Mobility V220 Logo
32 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
