Question about Dell wireless keyboard and Mouse ( t0179) combo U0097
Install mouse how can i install my new, wireless, dell mouse? i saw it once but something distracted me. help!
    Scholar:
  • 51 Answers
Most of the time, dell components (on a dell computer) will have the drivers pre-loaded on the system. follow the directions that should have come with the mouse for plugging in and synchronizing the component. Normally this involves plugging in the "connection" unit to a working USB port on your system and pressing the "sychronize" button on the unit. Make sure your mouse has good fresh batteries in it otherwise the sychronization will fail. You should get anywhere between 4 and 10 feet or range with your wireless mouse if it's operating correctly.
Also, if the drivers are NOT preloaded on the system, there should be a driver disc that came with the mouse, insert it and install the drivers for your mouse on your computer prior to following the above advice.
Posted on Jun 30, 2008
Keyboard & Mouse not inputting..Dell OptiPlex GX280.. OS, XP. Microsoft Wireless Desktop 3000 (keyboard/mouse) new.. Dell boots up and desktop appears, the cursor (arrow head) remains in middle of...
Check that batteries are charged and installed properly.--make sure driver disc is installed if applicable- check instructions as some wireless suites need you to push a small connect button to initialise them . Also try shifting the usb conector into another USB port if it is notm getting reconised.
I hope this helps
Andrew.A
Apr 09, 2011 | Dell OptiPlex GX280 PC Desktop
Wireless optical mouse (DELL) doesnt work on my windows 7 system
mcdevito75 here, The optical mouse should have instructions, or you can type in search from home page up-date drivers.
Jun 25, 2010 | Dell Wireless Keyboard Optical Mouse w0147
Dell wireless keyboard stopped working. Changed
I make oresumption that you have depressed the connection button under the keyboard to reset it?
If still a problem go to device manager and delete the wireeless keyboard so it can be discovered again.
Please rate my help++++Thanks for using FIXYA
Nov 17, 2009 | Dell Wireless Keyboard Optical Mouse w0147
My dell wireless keyboard doesn't work the mouse works. They are linked into the same USB reciever. There is a red light for the keyboard and green for the mouse....I have tried all windows diagnostics,...
try to delete the Bluetooth keyboard and mouse, then search/create a new device and see if they are detected. if yes, just follow the instruction on installation. else, there could be a problem on either of them. hope this helps
Oct 31, 2009 | Dell Wireless Keyboard Optical Mouse w0147
Wireless mouse and keyboard issues
If you have both sets of keyboard and mouse plugged in, turn off the computer and remove the old mouse and plug in the new mouse. Reboot and if necessary use the keyboard to login. Once windows is loaded let it detect the new mouse and then shut down again. Take out the old keyboard and reboot. You should now be able to use both new pieces without problems.
Jun 09, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
I have just installed a brand new microsoft wireless key board and mouse to my dell and the key board will not type the comand buttons do work the mouse works
Make sure you install the Intellipoint software that came with the keyboard. If you have done this then try resetting the keyboard by pushing the reset button that is either on the back or bottom depending on model. Hope this helps.
Jan 25, 2009 | Dell Wireless Keyboard Optical Mouse w0147
RT7D40
First start up your computer, then once started plug in the USB cable, after that you should wait for the drivers to automatically load, providing you are using Windows 2000 XP or Visita, build-in drivers should load,
After that you need to pair up the keyboard and mouse.
Under the Keyboad you will find battery slots, please make sure you have new batterys installed, then press you have to find a small button, once found, you will have to press that button togerther with the big button on the end of the USB cable bit.
Press and hold these two for about five secounds, then let go.
That should pair up the keyboard, now to the same for the mouse.
Thats all the is to it. you do not need the installation cd-rom at all.
Hope this information helps. Best of luck.
Jun 20, 2008 | Dell Wireless Keyboard Optical Mouse w0147
Dell wireless mouse/how to open case to install new batteries?
I cant look up the model number you gave. but check out this link. this might help. it contains all the manuals for dell peripherals.
http://support.dell.com/support/systemsinfo/documentation.aspx?c=us&l=en&s=gen&~subcat=6&~cat=1
Nov 26, 2007 | Dell Wireless Keyboard Optical Mouse w0147
Dell Wireless Mouse does not track and skips
Could be radio interference. I tracked my similar mouse problem down to emissions from the ethernet adapter that connects over the house mains wiring.
May 11, 2007 | Dell Wireless Keyboard Optical Mouse w0147
Mouse Wheel How can I get the mouse wheel to do "double click?" Help!!!
Download and install the latest driver/software for your mouse from the manufacturer's website. Once installed, you should be able to program the wheel through the software.
Jan 06, 2007 | Dell Wireless Keyboard Optical Mouse w0147
Computers & Internet Logo
150 people viewed this question
Alun Cox
