TOSHIBA M30 DISPLAY PROBLEM
Hi, one set of wires to the lcd bulb is pink and green and the other is pink and white.
Regards - Colin
  • 159 Answers
Connect two pink together and the green with the white
Posted on Jun 28, 2008
The display on my L675 S7048 is flickering badly. My whites turn pink, and my blues turn green. I see it when windows starts, even the Microsoft logo has tiny green dots all around it. When I connect an...
WHITE is a mixture of the three "primary" colours.
If one of the colours is not working, then WHITE turns PINK.
So, either your LCD display is malfunctioning,
or the "data" cable between the LCD and the motherboard is malfunctioning (not transmitting all 3 signals),
or the video-card embedded into the motherboard is malfunctioning (not sending all 3 signals).
This is nothing that you can fix by yourself; take your computer to a qualified technician, for trouble-shooting and repair.
Jan 19, 2011 | Toshiba Satellite L675-S7048 Notebook
Hi I have a ford radio 2006 rds 93FB-18K876-GB
maybe this will help you MEM
Green/Yellow
ACC
Yellow/Black
GND
Black
RF
White/Green
RF
Black/White
LF
Orange/Green
LF
Black/White
RR
Pink/Blue
RR
Green/Orange
LR
Pink Green
LR
Pink/Blue
Oct 16, 2009 | Radio Communications
Toshiba Satellite L35 screen color turned to pink.
If you have a LCD-screen, not an old-style CRT-screen, it is the data-cable, and its connections, that are not transmitting one of the 3 "primary" colours, e.g., mix red & blue & green to get white,
but mix only two of those colours, and you could get pink,
because the mixing is an "additive" process.
If you mix NONE of the 3 primary colours, you should get BLACK.
If you see GREEN, you're seeing ONE of the primary colours.
Sep 19, 2009 | Toshiba Satellite L35-S2366 Notebook
White turns to pink on acer laptop
The problem is CCFL light bulb in the screen. It is starting to die :( Can be replaced but that is not an easy task (easier is to replace screen as new bulb comes with it)
Jan 12, 2009 | Acer Aspire 5630 Notebook
Oem Radio installation
*** 91 park ave with delco bose =
black = ground
dark green = lights on input
grey = panel lights
pink = on input
yellow = power input
orange = battery power input
nca = shield ground
tan = left fr spkr +
orange/black = left & right spkr -neg
lite green = right fr spkr +
nca = shield ground
dark blue = right rear spkr +
dark green/yellow = right & left spkr - neg
brown = left rear spkr +
purple/white = display dim output
pink = vehicle speed input
**** 91 park ave without delco bose =
grey = left front - neg
tan = left front + pos
dark green = right front - neg
light green = right front + pos
black = ground
dark green = display dim signal
grey = panel lights
pink = power antanna
yellow = ign input
light blue = right rear - neg
dark blue = right rear + pos
yellow = left rear - neg
brown = left rear + pos .
there YA go
Dec 27, 2008 | 1991 Buick Park Avenue
just to be certain you could if the person for the other laptop dont mind of course cut the two wire off your back light (bulb) and do the same for the other laptop back light . but first are the two set of wires the same colour eg on your bulb its black wire and red wire the other bulb is black wire and red wire.
Jun 28, 2008 | Computers & Internet
the inverter only control the back light this is the bright or dim in the lcd the blurry or funny images would be the lcd or lcd cable the only other thing is the 1 in 100 shot of it being a motherboard issue (video on the motherboard). the best thing to do is take the lcd out and try a lcd from another laptop maybe a friends laptop that uses alike lcd this does not have to be the matching size just matching lcd cable connection. be careful the cable should go on with ease no force if you have to force the cable on to the try out lcd then it will not work.
Jun 28, 2008 | Toshiba Computers & Internet
Need wiring diagram for kenwood kdc-w4031
To my knowledge most Kenwood head units uses the following wiring/color scheme:
Yellow - always on B+12VDC such as the positive terminal of the battery;
Red - switched B+12VDC such as the ACC terminal of the IGN switch;
Black - Ground/chassis;
Pink - not available
Brown - mobile phone mute
Blue - power antenna
Blue / White - remote trigger for external device
Pink / Black - external amplifier control wire
Gray - Front Right +
Gray / White - Front Right -
White - Front Left +
White / White - Front Left -
Purple - Rear Right +
Purple / White - Rear Right -
Green - Rear Left +
Green / White - Rear Left -
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jun 02, 2008 | Kenwood Car Audio & Video
Car stereo wiring (1993 Ford Taurus GL)
My guess is that ford did not change that much in a year.
1994 Ford Taurus Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: Green/Yellow
Radio Ignition Switched 12V+ Wire: Yellow/Black
Radio Ground Wire: Black/Light Green
Radio Illumination Dimmer Wire: Light Blue/Red
Radio Antenna Trigger Wire: Orange/Blue
Radio Amplifier Trigger Wire: N/A
Front Speakers Size: 6 1/2′
Front Speakers Location: Doors
Left Front Speaker Wire (+): Orange/Light Green
Left Front Speaker Wire (-): Light Blue/White
Right Front Speaker Wire (+): White/Green
Right Front Speaker Wire (-): Green/Orange
Rear Speakers Size: 5′ x 7′
Rear Speakers Location: Rear Deck
Left Rear Speaker Wire (+): Pink/Light Green
Left Rear Speaker Wire (-): Dark Blue/Orange
Right Rear Speaker Wire (+): Pink/Light Blue
Right Rear Speaker Wire (-): Tan/White
Jan 13, 2008 | Car Audio & Video
Computers & Internet Logo
74 people viewed this question
David Payne
David Payne
