Question about Canon ZR25MC Mini DV Digital Camcorder
Playback looks like shooting through horizontal blinds
My camera started giving me instructions to clean the heads when turned on. I saw that all tapes played back had horizontal blank lines which gave the appearance that the video was shot through blinds. I have run a head cleaner as instructed but there has been no change. Is there anything I can do besides take it in for repair?
  • Canon Master
  • 2,794 Answers
It could be a head adjustment or it could be the CCD unit. It should be taken in for repair to find the cause.
Posted on Jul 13, 2008
I own a Panasonic 3ccd nvgs mini dv i was shooting some footage...tape got horizontal lines on it... i really really need that tape... can it be fixed?...thx a milion
Sounds like dirty heads .
If the lines are recorded onto the tape, probaly not.
Try a head cleaning tape in the camera or use another playback device.
If the lines are recorded onto the tape then track down someone with a TBC (timebase corrector) and pipe the signal through that and record to another tape.
Apr 13, 2011 | Panasonic NVGS-200 DV Camcorder 3 CCD 2.32...
Horizontal equally spaced black bars accross the screen when in playback mode similar to looking through partially opened venetian blinds.
You may need to clean the head on the device. You can purchase head cleaning tapes from most stores that sell the tapes, or goto a specialist camera shop.
Failing that, open the tape slot, tape the tape out, and with a soft cloth see if you can clean the small silver heads very gently.
Oct 20, 2010 | Panasonic NV-GS15 Mini DV Digital...
During playback there are 5 horizontal blue lines that display. Can I fix this myself?
try with head cleaning cassette 2 or 3 times if problem presists change video head assembly
VEG1731
May 20, 2010 | Panasonic PV-GS150 Mini DV Digital...
CCD-TR705e Sony video recorder hi 8 playback 3 beams
the camcorder flickers when viewing playback - pictures flickering
Dec 10, 2008 | Pure Digital Point and Shoot Video...
Thick dark vertical lines appear on the video taken during playback.
It is problem of dirty / clogged video heads, use good quality video head cleaner in your camera and clean video head. Problem will be resolved.
Nov 10, 2008 | JVC GR-D250 Mini DV Digital Camcorder
Head cleaning required
i have the JVC MiniDV Digital Video Cleaning Cassette. I began having trouble when I was shooting DV24P and when I went to playback I noted audio dropouts. I'm using SONY Premium DVM60 tapes. I began having Head Cleaning Required message. I have ran the Cleaning Cassette and the message disappears, but even trying a brand new tape, switching to DV playback i get the error message. Luckily, the shoot i was on the master audio was being captured by a secondary device and we were able to simply use the video from my camera. Since then, I was able to play & capture both the video & audio previously recorded in HDV30P and I didnt receive an error message. Now though I cannot record any DV audio without dropouts. When I tested just moments ago, I was able to record HDV and both video & audio were clean, but during playback I still received the Head Cleaning message. Is the record head different from the playback head? Can you manually clean the heads by removing the plastic door cover with a lintfree cotton swab and rubbing alcohol (obviously disconnecting and removing all power & powering off prior to cleaning), the same way any previous machine heads were cleaned in our stations? I think I may have got a batch of bad tapes that may have gunked up one of the heads some where and its getting missed by the cleaning tape. Is is possible that the head has been scratched, and will require replacement. If yes, is there any way to look at the head and detect this?
May 31, 2008 | JVC GY-HD100 Mini DV Digital Camcorder
Blue Horizontal Lines
if you dont have time to get it fixed, tap on the side where the tape goes in. I had to tap it a couple of times before everything started work fine again.
May 06, 2008 | Panasonic Palmcorder PV-GS15 Mini DV...
Panasonic Digital Video Camera (Mini DV) - horizontal stripes
I am having the same problem with my Canon Optura 60. But only in playback.
Jan 08, 2008 | Video Cameras
Shooting mode will not operate
Your camera has a defective CCD imager. Please return the camera to Canon in New Jersey and they will replace the CCD at no charge to you. This is a known issue and should be covered under extended warranty. Good luck my friend. Joe Weibel customelectronics.org
Feb 27, 2007 | Canon PowerShot A75 Digital Camera
Canon ZR25MC Mini DV Digital Camcorder Logo
126 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
