Question about TruTech PLV1615T 15 in. LCD Television
Lcd tv i have a lcd tv Can not turn on or off or any thing push any button it comes up whit local lock. tv won't turn on with power button or remote. Shows in standby or off with small red light
    Champion:
  • 367 Answers
Open the back of the TV,and look at the can shaped items on the board that the power cord is hooked to.If any of them have the tops,or bottoms bulged out,they need to be replaced.This should get it working again.So far I have fixed four of the same make,and model TV as this,and they all had either one,or two bad capacitors.I hope this helps.If you have any other questions,please let me know.Thank You very much!
Tyler
Posted on Aug 23, 2008
When we push the power button on the remote or on the tv the green light comes on for one second and then shuts off ... tv won't turn on
you have a short circuit in the power supply.
1) test the power cord very well
2) test the main swithc for short or open
3)test the power supply, look for a short in transformer+coil+filter+diode+rectifier. and replace
4)test the HVRECT+fLYBACK+ horizontal output for +125Vdc +vertical output for +80Vdc ALL this go to the CRT
color +12vdc+other circuit +12vdc. The first thing do you will have is RASTER, see the block. d
God bless you
Jul 31, 2012 | Mitsubishi WS-65819 TV
Mitsubishi tv won't turn on
did you try new batteries in the remote? if the tv has buttons on the side and one of them being power di you try to push that? did you push tv power or cable power holding the buttons longer? those things might work.
Jun 05, 2012 | Mitsubishi WS-55909 55" Rear Projection...
Lighting was bad in my area and my tv was plugged inns surge protector the tv turned on bit the power light blinks with the opc light my dish won't how up on the tv what do u think is wrong??? I turn...
The tv have a problems with the board that called the tv main Tuner signal board.That the board where the tv incomming broadcasting signal cable plug into it.This tv it still useable.I have one too a 46".Try tv unplug,replug it back like about an hour this problems will solved for a while evenually will return though.Every times POWER and OPC LED lights flashes,just push the tv power button ON again on the remote and have to wait,sometimes tv it will lite up and work right away.Sometimes it will have POWER and OPC LED lights flashes again.Just have to push the remote power button ON again and wait a while again eventually tv it will lite up and work.Have to this like 3 or 4 times power ON button pushes somtimes,tv will eventually work though.I know i do this manytimes before my tv have this problems off/on 3 1/2 years.But finally u will have to replace the tv main Tuner signal board sooner or later though this solution dosen't work for the rest of the tv life.U can do some basic mechnical works like take things aparts and putting back together again.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish tv Turner signal board for the replacement.
Sep 02, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
The tv's green light comes on but there is no picture and no sound. When I push any buttons on the remote the only thing that shows up is the volume thing. It doesn't respond to pushing the channel buttons...
your main board has gone bad. Can be fixed, in my shop it would cost about $250. It is a real shame on the industry that these things last about 2 years or less. Hope you held on to your old crt style tv.
Jun 17, 2010 | LG 42LC2D 42 in. LCD HDTV
No picture
Put new batteries in remote control.
Sep 14, 2009 | ViewSonic N2750w 27 in. HD-Ready LCD...
Can not turn off power lock
hold volume up and menu buttons at same time for 10 seconds - under left edge of tv
Jun 15, 2009 | ViewSonic N2230w 22 in. LCD TV
No response to any button on remote or tv except power button
Press the 'Favorite' button on the remote. You may have accidentally pressed it. It locks the channel. Pressing again unlocks.
Apr 22, 2009 | iLO 3200 32 in. LCD Television
I bought my Polaroid 373-B without a remote. I then bought a RCA universial remote that has worked until it dropped the codes. Now, I can't find the list of codes to re-program the remote. Can someone help...
Hi stevieb44, I am happy to help. Turn your TV on.
  1. Press and hold the TV button
  2. While holding the TV button press and hold the Power(on/off) button, the light will go out and then come back on.
  3. Release both buttons, the light should remain on.
  4. Point the remote at the TV.
  5. Press the power button repeatedly until TV turns off, wait about 5 seconds between pushes.
  6. When TV turns off press the Stop button at bottom of remote, that will lock in the code.
Let me know if this helps and please rate this solution. Lone99star
Jan 18, 2009 | Polaroid FLM-3734B 37 in. LCD HDTV
TruTech PLV1615T 15 in. LCD Television Logo
Top TruTech Televison & Video Experts
Jason Morris
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
