Question about Kenmore 44102 Front Load Washer
Water is leaking into the main drum when the machine is not running.
I can see water trickling from the water outlet in the upper left of the inside rubber rim whent he machine is not even in use. Therefore waterpools in the drum or if a load is left it pools at the bottom and the clothes need to be rinsed and drained and spun again.
    President:
  • 1,462 Answers
Valve is leaking. replace valve
Posted on Jun 28, 2008
Iv got a Bendix BIW103W, water runs to machine from mains, no blockages, but only trickles into dispencer, doesnt take powder or fab softner into drum, otherwise works ok,
i would check the water inlet on machine............take the hose off there should be a small filter inside. might be blocked..................
cheers
Mar 31, 2011 | Tricity Bendix AW1000W Front Load Washer
Washer leaking water on floor
Hi
The water leaking on floor can be a serious issue as this may cause the inside parts to malfunction or in some cases rusting of the body. To check where exactly it is leaking; inspect the leak while it is running. After the cycle is complete quickly turn off the power, lie down the machine on left/right side and check from where the water is leaking. If it is the hose or drain pump then check whether hose is connected firmly and is not cut. If it not the hose/pump inspect if the leak is on the drum corner or anywhere on the upper side of the drum. If it is on upper side that means the drum is cracked and it is a costly affair. However, if it is leaking from the circumference then it is due to transmission seal. To replace the transmission seal you'll need to disassemble the washer and the drum assembly. Please post back in case of any issues. Hope this helps...
Daniel
Feb 11, 2011 | Frigidaire GLET1031WH Top Load Stacked...
Leaking
Hi
Water leaking on floor can be a serious issue as this may cause the inside parts to malfunction or in some cases rusting of the body. To check where exactly it is leaking; inspect the leak while it is running. After the cycle is complete quickly turn off the power, lie down the machine on left/right side and check from where the water is leaking. If it is the hose or drain pump then check whether hose is connected firmly and is not cut. If it not the hose/pump inspect if the leak is on the drum corner or anywhere on the upper side of the drum. If it is on upper side that means the drum is cracked and it is a costly affair. However, if it is leaking from the circumference then it is due to transmission seal. To replace the transmission seal you'll need to disassemble the washer and the drum assembly. Please post back in case of any issues. Hope this helps...
Daniel
Jan 01, 2011 | Washing Machines
Water leaking from bottom of washer between the washer and petestal
Hi
The water leaking on floor can be a serious issue as this may cause the inside parts to malfunction or in some cases rusting of the body. To check where exactly it is leaking; inspect the leak while it is running. After the cycle is complete quickly turn off the power, lie down the machine on left/right side and check from where the water is leaking. If it is the hose or drain pump then check whether hose is connected firmly and is not cut. If it not the hose/pump inspect if the leak is on the drum corner or anywhere on the upper side of the drum. If it is on upper side that means the drum is cracked and it is a costly affair. However, if it is leaking from the circumference then it is due to transmission seal. To replace the transmission seal you'll need to disassemble the washer and the drum assembly. Please post back in case of any issues. Hope this helps... Please post back if you need more information.
Daniel
Dec 11, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Leaks out the front of machine
Hi
Daniel
Sep 01, 2010 | Roper RAS8445KQ Top Load Washer
WATER IS COMING OUT FROM THE BOTTOM OF MY WASHER,IS THIS SOMETHING MAJOR?
Hi
The water leaking on floor can be a serious issue as this may cause the inside parts to malfunction or in some cases rusting of the body. To check where exactly is it leaking, inspect the leak while it is running. After the cycle is complete quickly turn off the power, lie down the machine on left/right side and check from where the water is leaking. If it is the hose or drain pump then check whether hose is connected firmly and is not cut. If it not the hose/pump inspect if the leak is on the drum corner or anywhere on the upper side of the drum. If it is on upper side that means the drum is cracked and it is a costly affair. However, if it is leaking from the circumference then it is due to transmission seal. to replace the transmission seal you'll need to disassemble the washer and the drum assembly. Please post back in case of any issues. Hope this helps...
Daniel
Aug 30, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Water leaking when machine is off
you need a new water valve. it is located at the back left hand side under the main top(the piece the hot and cold water hoses hook on to)
Feb 08, 2010 | Whirlpool GHW9300 Duet Washer
During the final spin cycle, water is leaking inside the machine
You have a problem with the pressure switch cutting in too early before all of the water has drained away from the outer drum
There is either an obstruction in the outlet pipe or pump which is not allowing the water to discharge fast enough.
The machine is then spinning with too much water left in the outer drum added to the water which is being expelled from the clothes equals leaking
Take the hose off the back of the machine and put it in a sink , make sure it is secure and do a rinse cycle
Watch the outlet and make sure it is a strong flow if it is weak then you have probably got an item of clothing stuck in the pipe from the drum to the pump and a strip down is required
One more thing there is a small plastic bottle attached to the back of the outer drum this has tube which leads to the pressure switch
Make sure there is no congealed soap in the Air Bell as it is called
Jul 05, 2009 | Fisher and Paykel WA37T26G Top Load Washer
Whirlpool duet washer leaking water into the drum when not used
water leakin in tho the drum is sign of a faulty water inlet valve, not shutting off water supply to machine, it continues to trickle in , in beween washes. you can turn off the water supply between washes see if this helps, and if it does then youll know its the water valve
Jan 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool washer machine
I suggest you remove the front of the washer and observe the base of the drum and all hoses while in operation, using a flashlight attempt to find the source of the leak. **USE CAUTION!** Moving parts, water and electrical components present a very real hazard! If you have a top loading washer which agitates the clothing back and forth, one possible cause is the transmission. There is an internal locking mechanism which sometimes fails and will not engage, allowing the drum to continue to spin in one direction. The water will rise as the drum gains speed until it reaches the overflow outlets at the upper portion of the drum. These overflow outlets allow the water to spill out inside the bottom of the washer and out onto the floor. To check this, run the washer with the lid open (to do so, use a plastic or dry wooden stick [something non-conductive] to push down and hold the safety interlock switch closed) if the washer does not agitate back and forth and only spins in one direction you have a transmission problem. JUST BE CAREFUL WHEN OPERATING WITH THE INTERLOCK BYPASSED AS YOU WILL HAVE EXPOSED MOVING PARTS! If you feel any hesitation or concern about doing this...STOP!!, get someone comfortable or certified to do this type of work. While it is not difficult to do these things, there are risks and a momentary distraction can be painful, disfiguring or deadly. In this case, a repairman can be cheaper than a trip to the emergency room. You be the judge of your own skills and abilities.
Good Luck
Jan 30, 2008 | Washing Machines
Kenmore 44102 Front Load Washer Logo
120 people viewed this question
Ron Lankford
Archaeology
Archaeology
2mikecurtis
